Inserted Commands for Wet Modal Analysis:
! Commands inserted into this file will be executed just prior to the Ansys SOLVE command.
! These commands may supersede command settings set by Workbench.
! Active UNIT system in Workbench when this object was created: Metric (mm, kg, N, s, mV, mA)
finish
/prep7
allsel,all
*get,etmax,etyp,,num,max,
*get,matmax,mat,,num,max,
*set,hetid,etmax+1
*set,tetid,etmax+2
*set,matid,matmax+1
et,hetid,fluid220
keyopt,hetid,2,1
et,tetid,fluid221
keyopt,tetid,2,1
mp,dens,matid,1000e-9
mp,sonc,matid,1400e3
cmsel,s,water,
emodif,all,mat,matid,
esel,r,ename,,solid186
emodif,all,type,hetid,
allsel,all
cmsel,s,water,
esel,r,ename,,solid187
emodif,all,type,tetid,
allsel,all
*set,hetid,etmax+1
*set,tetid,etmax+2
et,hetid,fluid220
et,tetid,fluid221
cmsel,s,present,
esln,r
esel,r,ename,,fluid220
allsel,all
cmsel,s,present,
esln,r
esel,r,ename,,fluid221
allsel,all
finish
/solu
modopt,unsym,10,
sf,present,fsi
d,pressure,pres,0
allsel,all
