- 3
- 2007-12-17
楼主 |
发表于 2011-9-7 15:08:50
来自 荷兰
417332551 发表于 2011-9-7 08:18
sph是什么分析类型呢/
PC3D单元不知道怎么添加,inp文件运行不了。
Smoothed particle hydrodynamics (SPH) is a numerical method that is part of the larger family of meshless (or mesh-free) methods. For these methods you do not define nodes and elements as you would normally define in a finite element analysis; instead, only a collection of points are necessary to represent a given body. In smoothed particle hydrodynamics these nodes are commonly referred to as particles or pseudo-particles.
Smoothed particle hydrodynamics is a fully Lagrangian modeling scheme permitting the discretization of a prescribed set of continuum equations by interpolating the properties directly at a discrete set of points distributed over the solution domain without the need to define a spatial mesh. The method's Lagrangian nature, associated with the absence of a fixed mesh, is its main strength. Difficulties associated with fluid flow and structural problems involving large deformations and free surfaces are resolved in a relatively natural way. The method has received substantial theoretical support since its inception (Gingold and Monaghan, 1977), and the number of publications related to the method is now very large.
相信你可以在网上查到N多的相关学术文献
不能把该inp文件通过model导入,因为有些选项是CAE所不支持的。直接建立job,将inp导入即可计算。我最初就犯了这个错误。 |
