看到论坛里的圆柱相贯划分网格,我先画一个圆,然后中心放置正方形,最后extrue形成圆柱,接着用两个与轴线成45度得平面分割,但是出现错误Unable to create a B-Rep solid broken from the original B-Rep solid because some edges on the faces in the solid are not matched. This usually happens when a Parasolid B-Rep body is to be broken, since it requires some topological changes to comply with the conventional Patran 2010 B-Rep topology.
