查看: 97|回复: 1
分离式钢筋混凝土的一个例子,不知道哪里错了?
发表于 2011-9-9 19:51:36 | 显示全部楼层 |阅读模式 来自 江苏南京
/PREP7
ET,1,SOLID65
ET,2,PIPE20
ET,3,PLANE42
R,1,18,8.99,
R,2,8,3.99,
R,3, , , , , , ,
RMORE, , , , , , ,
RMORE, ,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.4e4
MPDATA,PRXY,1,,0.2
TB,CONC,1,1,9,
TBTEMP,0
TBDATA,,0.4,1,3,-1,,
TBDATA,,,,,,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,2e5
MPDATA,PRXY,2,,0.3
TB,BKIN,2,1,2,1
TBTEMP,0
TBDATA,,350,,,,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,3,,2e5
MPDATA,PRXY,3,,0.25
TB,BKIN,3,1,2,1
TBTEMP,0
TBDATA,,200,,,,,
N,1,0,0,0,,,,
N,9,150,0,0,,,,
FILL,1,9,7, , ,1,1,1,
FLST,4,9,1,ORDE,2
FITEM,4,1
FITEM,4,-9
NGEN,11,9,P51X, , , ,30, ,1,
FLST,4,99,1,ORDE,2
FITEM,4,1
FITEM,4,-99
NGEN,19,1000,P51X, , , , ,-75,1,
/VIEW,1,1,1,1
/ANG,1
/REP,FAST
type,2
real,2
mat,3
SAVE
*do,ii,11,16,1
e,ii,ii+1
*enddo
*do,ii,83,88,1
e,ii,ii+1
*enddo
*do,ii,11,74,9
e,ii,ii+9
*enddo
*do,ii,17,80,9
e,ii,ii+9
*enddo
egen,19,1000,1,28,1
*do,ii,83,17083,1000
e,ii,ii+1000
*enddo
*do,ii,89,17089,1000
e,ii,ii+1000
*enddo
type,2
real,1
mat,2
*do,ii,11,17011,1000
e,ii,ii+1000
*enddo
*do,ii,17,17017,1000
e,ii,ii+1000
*enddo
/eshape,1
eplot
K,1,,,,
K,2,150,,,
K,3,150,300,,
K,4,0,300,,
FLST,2,4,3
FITEM,2,1
FITEM,2,2
FITEM,2,3
FITEM,2,4
A,P51X
TYPE,   3
MAT,       2
REAL,       1
ESYS,       0
SECNUM,
TYPE,   3
MAT,       2
REAL,       1
ESYS,       0
SECNUM,
FLST,5,2,4,ORDE,2
FITEM,5,2
FITEM,5,4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,S,_Y
FLST,5,2,4,ORDE,2
FITEM,5,2
FITEM,5,4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,8, , , , ,1
CM,_Y,AREA
ASEL, , , ,       1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
MSHKEY,1
AMESH,_Y1
MSHKEY,0
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/DIST,1,1.08222638492,1
/REP,FAST
/REP,FAST
/DIST,1,0.924021086472,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
TYPE,   1
EXTOPT,ESIZE,18,0,
EXTOPT,ACLEAR,1
EXTOPT,ATTR,0,0,0
MAT,1
REAL,3
ESYS,0
FLST,2,1,5,ORDE,1
FITEM,2,1
VEXT,P51X, , ,0,0,-1350,,,,
EPLOT
NUMMRG,ALL, , , ,LOW
NUMCMP,ALL
ANTYPE,0
DA,       1,SYMM
/VIEW,1,1
/ANG,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
FLST,2,9,1,ORDE,2
FITEM,2,1684
FITEM,2,-1692
/GO
D,P51X, , , , , ,UX,UY, , , ,
FLST,2,9,1,ORDE,2
FITEM,2,982
FITEM,2,-990
/GO
D,P51X, ,-5, , , ,UY, , , , ,
FINISH
/SOL
ANTYPE,0
NLGEOM,1
NSUBST,200,0,0
OUTRES,ERASE
OUTRES,ALL,ALL
NEQIT,50
ALLSEL,ALL
/STATUS,SOLU
SOLVE
发表于 2012-4-25 08:06:36 | 显示全部楼层 来自 陕西西安
这是做的混凝土的分离式分析吧?
GMT+8, 2024-4-16 23:58 , Processed in 0.027648 second(s), 11 queries , Gzip On, MemCache On.
