- 22
- 2010-10-7
发表于 2011-9-14 16:26:35
来自 河北秦皇岛
Name | Definition | O | R | EL | Element number and name | Y | Y | NODES | Nodes - I, J, K, L | - | Y | MAT | Material number | - | Y | THICK | Average thickness | - | Y | VOLU: | Volume | - | Y | XC, YC, ZC | Location where results are reported | - | 4 | PRES | Pressures P1 at nodes I, J, K, L; P2 at I, J, K, L; P3 at J,I; P4 at K,J; P5 at L,K; P6 at I,L | - | Y | TEMP | T1, T2, T3, T4 at bottom of layer 1, T5, T6, T7, T8 between layers 1-2, similarly for between next layers, ending with temperatures at top of layer NL(4*(NL+1) maximum) | - | Y | LOC | TOP, MID, BOT, or integration point location | - | 1 | S:X, Y, Z, XY, YZ, XZ | Stresses | 3 | 1 | S:1, 2, 3 | Principal stresses | - | 1 | S:INT | Stress intensity | - | 1 | S:EQV | Equivalent stress | - | 1 | EPEL:X, Y, Z, XY | Elastic strains | 3 | 1 | EPEL:EQV | Equivalent elastic strains [7] | - | 1 | EPTH:X, Y, Z, XY | Thermal strains | 3 | 1 | EPTH:EQV | Equivalent thermal strains [7] | - | 1 | EPPL:X, Y, Z, XY | Average plastic strains | 3 | 2 | EPPL:EQV | Equivalent plastic strains [7] | - | 2 | EPCR:X, Y, Z, XY | Average creep strains | 3 | 2 | EPCR:EQV | Equivalent creep strains [7] | - | 2 | EPTO:X, Y, Z, XY | Total mechanical strains (EPEL + EPPL + EPCR) | 3 | - | EPTO:EQV | Total equivalent mechanical strains (EPEL + EPPL + EPCR) | - | - | NL:EPEQ | Accumulated equivalent plastic strain | - | 2 | NL:CREQ | Accumulated equivalent creep strain | - | 2 | NL:SRAT | Plastic yielding (1 = actively yielding, 0 = not yielding) | - | 2 | NLLWK | Plastic work | - | 2 | NL:HPRES | Hydrostatic pressure | - | 2 | SEND:ELASTIC, PLASTIC, CREEP | Strain energy densities | - | 2 | N11, N22, N12 | In-plane forces (per unit length) | - | Y | M11, M22, M12 | Out-of-plane moments (per unit length) | - | 8 | Q13, Q23 | Transverse shear forces (per unit length) | - | 8 | ε11, ε22, ε12 | Membrane strains | - | Y | k11, k22, k12 | Curvatures | - | 8 | γ13, γ23 | Transverse shear strains | - | 8 | LOCI:X, Y, Z | Integration point locations | - | 5 | SVAR:1, 2, ... , N | State variables | - | 6 | ILSXZ | SXZ interlaminar shear stress | - | Y | ILSYZ | SYZ interlaminar shear stress | - | Y | ILSUM | Magnitude of the interlaminar shear stress vector | - | Y | ILANG | Angle of interlaminar shear stress vector (measured from the element x-axis toward the element y-axis in degrees) | - | Y | Sm: 11, 22, 12 | Membrane stresses | - | Y | Sb: 11, 22, 12 | Bending stresses | - | Y | Sp: 11, 22, 12 | Peak stresses | - | Y | St: 13, 23 | Averaged transverse shear stresses | - | Y |
Output Quantity Name | ETABLE and ESOL Command Input | Item | E | I | J | K | L | N11 | SMISC | 1 | - | - | - | - | N22 | SMISC | 2 | - | - | - | - | N12 | SMISC | 3 | - | - | - | - | M11 | SMISC | 4 | - | - | - | - | M22 | SMISC | 5 | - | - | - | - | M12 | SMISC | 6 | - | - | - | - | Q13 | SMISC | 7 | - | - | - | - | Q23 | SMISC | 8 | - | - | - | - | ε11 | SMISC | 9 | - | - | - | - | ε22 | SMISC | 10 | - | - | - | - | ε12 | SMISC | 11 | - | - | - | - | k11 | SMISC | 12 | - | - | - | - | k22 | SMISC | 13 | - | - | - | - | k12 | SMISC | 14 | - | - | - | - | γ13 | SMISC | 15 | - | - | - | - | γ23 | SMISC | 16 | - | - | - | - | THICK | SMISC | 17 | - | - | - | - | P1 | SMISC | - | 18 | 19 | 20 | 21 | P2 | SMISC | - | 22 | 23 | 24 | 25 | P3 | SMISC | - | 27 | 26 | - | - | P4 | SMISC | - | - | 29 | 28 | - | P5 | SMISC | - | - | - | 31 | 30 | P6 | SMISC | - | 32 | - | - | 33 | Sm: 11 | SMISC | 34 | - | - | - | - | Sm: 22 | SMISC | 35 | - | - | - | - | Sm: 12 | SMISC | 36 | - | - | - | - | Sb: 11 | SMISC | 37 | - | - | - | - | Sb: 22 | SMISC | 38 | - | - | - | - | Sb: 12 | SMISC | 39 | - | - | - | - | Sp: 11 (at shell bottom) | SMISC | 40 | - | - | - | - | Sp: 22 (at shell bottom) | SMISC | 41 | - | - | - | - | Sp: 12 (at shell bottom) | SMISC | 42 | - | - | - | - | Sp: 11 (at shell top) | SMISC | 43 | - | - | - | - | Sp: 22 (at shell top) | SMISC | 44 | - | - | - | - | Sp: 12 (at shell top) | SMISC | 45 | - | - | - | - | St: 13 | SMISC | 46 | - | - | - | - | St: 23 | SMISC | 47 | - | - | - | - |
具体见帮助文档 |
