你的问题说得不太清楚,最好能把命令流贴出来。下面的例子好好研究一下,对照着做可能会有帮助
/prep7
/view,,1,2,3
/plopts,info,1
/pnum,mat,1
/num,1
et,1,SHELL163
keyopt,1,1,10 ! 10th element formulation recommended for springback
r,1,,3,0.05
edshell,,,1 ! membrane straining causes thickness change (default)
et,2,SOLID164
r,2
et,3,SOLID164
r,3
mp,ex,1,30e6
mp,nuxy,1,0.29
mp,dens,1,2.28e-3
tb,biso,1,1
tbdata,1,30e3,100e3
edmp,hgls,1,5
mp,ex,2,30e6
mp,nuxy,2,0.29
mp,dens,2,2.28e-3
edmp,rigid,2,6,7
mp,ex,3,30e6
mp,nuxy,3,0.29
mp,dens,3,2.28e-3
edmp,rigid,3,7,7
wpoffs,,-0.069
wprota,,-90
rectng,-0.99,-0.01,0.01,0.49
type,1
mat,1
real,1
lesize,1,,,10,1
lesize,2,,,5,1
lesize,3,,,10,1
lesize,4,,,5,1
amesh,1
wpcsys,-1,0
wpstyl
esize,0.1
k, 11, 0.00, 0.00, 0.00
k, 12, 0.00, 0.50, 0.00
k, 13,-1.00, 0.50, 0.00
k, 14,-1.00, 0.10, 0.00
k, 15, 0.50, 0.05, 0.00
k, 16, 0.00,-0.50, 0.00
k, 17, 0.00,-0.20, 0.00
k, 18,-1.00,-0.10, 0.00
k, 19,-1.00,-0.50, 0.00
k, 20, 0.50,-0.15, 0.00
l,11,12
l,12,13
l,13,14
larc,14,11,15,6
al,5,6,7,8
mat,2
amesh,2
l,16,17
larc,17,18,20,6
l,18,19
l,19,16
al,9,10,11,12
mat,3
amesh,3
esize,,5
mat,2
type,2
voffst,2,-0.5
aclear,2
mat,3
type,3
voffst,3,-0.5
aclear,3
eplot
edwrite,pcreate
edwrite,plist
edcgen,assc
fini
/solu
esel,s,mat,,1
cm,eblank,elem
nsle
cm,nblank,node
nsel,r,loc,x,-0.995,-0.985
nsel,u,loc,z,-0.485,-0.015
d,all,ux,0.0
nsel,r,loc,z,-0.495,-0.485
d,all,uz,0.0
esel,s,mat,,2
cm,epunch,elem
nsle
cm,npunch,node
esel,s,mat,,3
cm,edie,elem
nsle
cm,ndie,node
nsel,all
esel,all
! Punch displacement function = (amplitude*cos(omega*time))-amplitude
*dim,time1,,101,1,1 ! dimension array for time
*dim,disp1,,101,1,1 ! dimension array for punch displacement
curtime=0.0 ! initialize current time to zero
tottime=0.0101 ! total load curve time, seconds
deltime=tottime/100.0 ! time increment, seconds
amp1=0.0825 ! displacement amplitude, inches
omega1=180.0/tottime ! product of this constant and time = wt
*afun,deg ! work in degrees
*do,i,1,101,1
time1(i,1,1)=curtime
disp1(i,1,1)=(amp1*cos(omega1*curtime))-amp1 ! maximum uy = -0.165"
curtime=curtime+deltime
*enddo
edload,add,rbuy,,2,time1,disp1,0 ! punch = part number 2
time,0.01
edrst,50
edhtime,100
edhist,nblank
edhist,eblank
edenergy,1,1,1,1
edout,glstat
save
eplot
SAVE
/STAT,SOLU
SOLVE
ESEL,S,MAT,,1
NSLE,S
FINISH
/POST1
SET,LAST
/DSCALE,1,1.0
/REPLOT
PLNS,S,EQV
ANDATA,0.5, ,0,1,51,5,0,0
FINISH
/POST26
NUMVAR,30,
FILE,stamp,his,
NSOL,2,2,U,Y,node2uy
STORE,MERGE, ,
PLVAR,2, , , , , , , , , ,
ALLSEL,ALL
SAVE
FINISH
/FILNAM,spring
/PREP7
ETCHG,ETI
TBDELE,ALL,ALL, ,
SHPP,OFF
UPGEOM,1,1,51,stamp,rst,
EPLOT
ESEL,S,MAT,,1
NSLE,S
EPLOT
FINISH
/SOLU
FLST,2,2,1,ORDE,2
FITEM,2,1
FITEM,2,17
/GO
D,P51X, ,0.0, , , ,UY, , , , ,
RIMPORT,DYNA,STRESS,ELEM,1,51,stamp,rst,
NLGEOM,1
NROPT,AUTO, ,
LUMPM,0
EQSLV,SPAR, ,0,
PREC,0
PIVCHECK,1
SSTIF
PSTRES
TOFFST,0,
SAVE
/STAT,SOLU
SOLVE
FINISH
/POST1
SET,LAST
/DSCALE,1,10.0
/REPLOT
*SET,_ZF,1
AVPRIN,0,0,
/EFACE,_ZF
PLNSOL,U,SUM,2,1
FINISH
! /EXIT,NOSAV |
