- 2008-3-13
发表于 2011-12-7 08:46:24
来自 美国
Simple restart: This option assumes that the database has not been altered
Small restart: This option can be used when minor changes in the database are necessary. For example, you can reset the termination time, reset the output interval, add displacement constraints, change initial velocities, switch parts from a deformable to rigid state, etc
Full restart: A full restart is appropriate when many modifications to the database are required. For example, you can change the model geometry, apply different loading conditions,
如full restart所述,增加荷载得用完全重启动了。
