- 1
- 2006-3-24
发表于 2011-12-27 15:41:01
来自 广东深圳
这是我的warning信息
OUTPUT AT EXACT, PREDEFINED TIME POINTS WAS REQUESTED IN THIS STEP. Abaqus MIGHT ADJUST THE TIME INCREMENTATION BUT WILL NOT VIOLATE THE MINIMUM TIME INCREMENT ALLOWED IN THE STEP IN ORDER TO WRITE OUTPUT AT THOSE POINTS. CONSEQUENTLY, IN SOME CASES Abaqus MIGHTWRITE OUTPUT IMMEDIATELY AFTER THE SPECIFIED TIME POINTS, INSTEAD OF AT THE TIME POINTS. IN ADDITION, THE NUMBER OF INCREMENTS REQUIRED TO COMPLETE THE STEP WILL IN GENERAL INCREASE.
There are 2 unconnected regions in the model.
There is zero FORCE everywhere in the model based on the default criterion. please check the value of the average FORCE during the current iteration to verify that the FORCE is small enough to be treated as zero. if not, please use the solution controls to reset the criterion for zero FORCE.
The strain increment has exceeded fifty times the strain to cause first yield at 20 points
The strain increment has exceeded fifty times the strain to cause first yield at 54 points
The strain increment has exceeded fifty times the strain to cause first yield at 4 points
The strain increment has exceeded fifty times the strain to cause first yield at 6 points
The strain increment has exceeded fifty times the strain to cause first yield at 118 points
The strain increment has exceeded fifty times the strain to cause first yield at 10 points
The strain increment has exceeded fifty times the strain to cause first yield at 28 points
The strain increment has exceeded fifty times the strain to cause first yield at 2 points
The strain increment has exceeded fifty times the strain to cause first yield at 42 points
The strain increment has exceeded fifty times the strain to cause first yield at 14 points
The strain increment has exceeded fifty times the strain to cause first yield at 140 points
The strain increment has exceeded fifty times the strain to cause first yield at 22 points
