- 2010-12-9
MIT的公开课 Finite Element Analysis of Solids and Fluids I(http://ocw.mit.edu/courses/mechanical-engineering/2-092-finite-element-analysis-of-solids-and-fluids-i-fall-2009/)Finite Element Analysis of Solids and FluidsII (http://ocw.mit.edu/courses/mechanical-engineering/2-094-finite-element-analysis-of-solids-and-fluids-ii-spring-2011/download-course-materials/)Course DescriptionThis course introduces finite element methods for the analysis of solid, structural, fluid, field, and heat transfer problems. Steady-state, transient, and dynamic conditions are considered. Finite element methods and solution procedures for linear and nonlinear analyses are presented using largely physical arguments. The homework and a term project (for graduate students) involve use of the general purpose finite element analysis program ADINA. Applications include finite element analyses, modeling of problems, and interpretation of numerical results.
Lecture Notes
The lecture notes on this page were written by the teaching assistant, Seounghyun Ham, typed by Chang-Yoon Park, and proofread by Seounghyun Ham and Daniel J. Payen.
Course lectures.SES #TOPICSNOTES
1Introduction: why to study FEA(PDF - 7.3MB)
2The finite element analysis process(PDF)
3Analysis of solids/structures and fluids(PDF)
4The principle of virtual work(PDF)
5The finite element formulation(PDF)
6Finite element solution process(PDF)
7Finite element solution process, cont'd(PDF)
8Demonstration on using ADINA, part 1 none
9Demonstration on using ADINA, part 2 none
10Nonlinear finite element analysis of solids and structures(PDF)
11Heat transfer analysis(PDF)
12Finite element analysis of heat transfer and incompressible fluid flow(PDF)
13Physical explanation of Gauss elimination(PDF)
14Exam 1 none
15Solution of dynamic equilibrium equations(PDF)
16Solution of dynamic equilibrium equations, cont'd(PDF)
17Demonstration on finite element methods in ADINA; focus on student projects none
18Modeling for dynamic analysis and solution(PDF)
19Modeling for dynamic analysis and solution, cont'd(PDF)
20Wave propagation response(PDF)
21Solution of the generalized eigenvalue problem(PDF)
22Exam 2 none
23Solution of Kφ = λMφ(PDF)
24Wrap up, review none
25Wrap up, review, cont'd none
