- 2004-4-21
在联想启天M系列台式机上安装了SUSE LINUX 11 后,安装COMSOL42A 软件,安装过程正常,但是在启动时遇到了问题, 正常登陆界面 一闪 而过, comsol 自动退出。 但是在HPZ800工作站上 按照相同过程安装SUSE LINUX 及 comsol42a 就能正常启动,不知是什么原因,特此请教!
下面显示为 不能正常启动 comsol 时 ,给出的一个文件(hs_err_pid1139.log)的内容。 看看哪位大侠 能指教一下。
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fb7a9c300ab, pid=1139, tid=140428674086640
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode linux-amd64 )
# Problematic frame:
# C [libflgraphics_common.so+0x1a20ab] _ZNK12flgraphics3d12RendererInfo21getMultisampleSettingEi+0xb
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x000000000050f000): JavaThread "main" [_thread_in_native, id=1139, stack(0x00007fff21304000,0x00007fff21504000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0xfffffffffffffffc
Registers:
RAX=0x00007fb7a9e65028, RBX=0x00007fb7a7228320, RCX=0xffffffffffffffff, RDX=0x0000000000000000
RSP=0x00007fff21501230, RBP=0x00007fff21501230, RSI=0x00000000ffffffff, RDI=0x00007fb7be2c2f70
R8 =0x00007fb7bcc70bd0, R9 =0x000000000000008a, R10=0x00007fb7a72282d0, R11=0x00007fb7a9c1c388
R12=0x00007fff215013c8, R13=0x000000000000024e, R14=0x00000000007384a0, R15=0x000000000050f000
RIP=0x00007fb7a9c300ab, EFL=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000005
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007fff21501230)
0x00007fff21501230: 00007fff21501240 00007fb7a9c19229
0x00007fff21501240: 00007fff215012b0 00007fb7a715c33a
0x00007fff21501250: 00007fff215012b0 000000000050fe80
0x00007fff21501260: 0000004a00000000 000000000050fe78
0x00007fff21501270: b7026e2800000042 000000000050f000
0x00007fff21501280: 00000000000001e5 000000000000024e
0x00007fff21501290: 00007fff215013c8 00000000007384a0
0x00007fff215012a0: 000000000050f000 00007fff215013c8
0x00007fff215012b0: 00007fff21501350 00007fb7a715b7ba
0x00007fff215012c0: 00007fb7a72282d0 000000000000024e
0x00007fff215012d0: 00007fb7000001e5 00007fff215014c0
0x00007fff215012e0: 000000000050f000 00007fb818be5891
0x00007fff215012f0: 00007fff215014c0 00007fb7ac4890be
0x00007fff21501300: 00000000005689b0 00007fb7a64a8ddd
0x00007fff21501310: 000000000050f1b8 00000000005689b0
0x00007fff21501320: 00000000000001e5 000000000000024e
0x00007fff21501330: 00007fff215014b8 00007fb7a7393368
0x00007fff21501340: 000000000050f000 00007fff215014b8
0x00007fff21501350: 00007fff21501410 00007fb7a7159506
0x00007fff21501360: 000000000050fe70 00007fb81859b72a
0x00007fff21501370: 000000000050d6e0 000000000050fec0
0x00007fff21501380: 00007fff215013d0 000000000050f000
0x00007fff21501390: 00007fb7c828ece0 00007fb7c828ecd8
0x00007fff215013a0: 00007fff215014c0 000000000050f000
0x00007fff215013b0: 00007fff21501400 00007fb8183b6720
0x00007fff215013c0: 00007fff215014a8 00007fb7a7393368
0x00007fff215013d0: 00007fb7bccee4b0 000000000050f1b8
0x00007fff215013e0: 000000000050f000 00007fff215014c0
0x00007fff215013f0: 00007fb7c828ecd8 00007fb7c7190708
0x00007fff21501400: 00007fb7c828ece0 00007fb814520ae6
0x00007fff21501410: 00007fff21501488 00007fb814520c48
0x00007fff21501420: 0000000700000000 000000000050f000
Instructions: (pc=0x00007fb7a9c300ab)
0x00007fb7a9c3009b: 66 90 66 66 90 55 48 89 e5 48 8b 57 50 48 63 ce
0x00007fb7a9c300ab: 8b 04 8a 48 89 ec 5d c3 66 66 66 90 66 66 90 66
Stack: [0x00007fff21304000,0x00007fff21504000], sp=0x00007fff21501230, free space=7f40000000000000018k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libflgraphics_common.so+0x18b229] _ZNK12flgraphics3d22Canvas3dGlobalSettings25getMultisampleSettingDataEv+0x19
C [libflgraphics_swt_ogl.so+0x4f33a]
C [libflgraphics_swt_ogl.so+0x4e7ba]
C [libflgraphics_swt_ogl.so+0x4c506] Java_com_comsol_graphics3d_swt_SWTCanvas3dDirectCanvas_renderScene+0xb6
j com.comsol.graphics3d.swt.SWTCanvas3dDirectCanvas.renderScene(Lcom/comsol/nativejni/CPointer;II)V+0
j com.comsol.graphics3d.swt.SWTCanvas3dDirectCanvas.a(Lcom/comsol/graphics3d/swt/SWTCanvas3dDirectCanvas;Lcom/comsol/nativejni/CPointer;II)V+4
j com.comsol.graphics3d.swt.SWTCanvas3dDirectCanvas$c.run()V+65
j org.eclipse.swt.widgets.RunnableLock.run()V+11
j org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Z)Z+29
j org.eclipse.swt.widgets.Display.runAsyncMessages(Z)Z+5
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+58
j org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
j org.eclipse.ui.internal.Workbench.runUI()I+555
j org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j org.eclipse.ui.internal.Workbench$7.run()V+55
j org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j com.comsol.gui.swt.SWTDesktop.open()V+38
j com.comsol.gui.DesktopWindow.open()V+4
j com.comsol.gui.CsApplication.startApplication()Lcom/comsol/gui/DesktopWindow;+21
j com.comsol.gui.CsApplication.doStart([Ljava/lang/String;)Ljava/lang/Object;+32
j com.comsol.guimph.MphApplication.doStart([Ljava/lang/String;)Ljava/lang/Object;+22
j com.comsol.util.application.ComsolApplication.doStart([Ljava/lang/String;)Ljava/lang/Object;+504
j com.comsol.util.application.CsBaseApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+704
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v ~StubRoutines::call_stub
V [libjvm.so+0x3d66cd]
V [libjvm.so+0x5d9ea9]
V [libjvm.so+0x3d6505]
V [libjvm.so+0x62fa51]
V [libjvm.so+0x6337c2]
V [libjvm.so+0x4606db]
C [libjava.so+0x19715] Java_sun_reflect_NativeMethodAccessorImpl_invoke0+0x15
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
V [libjvm.so+0x40fbc4]
V [libjvm.so+0x3ed385]
C [comsol_1312.so+0x977a] startJavaJNI+0x4ec
C [comsol_1312.so+0xaf94] startJavaVM+0x2d
C [comsol_1312.so+0x4c6e] run+0x6b9
C [comsollauncher+0x15ab]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000000000cc2000 JavaThread "Worker-1" [_thread_blocked, id=1173, stack(0x00007fb7a4376000,0x00007fb7a4777000)]
0x00007fb7bcb0f000 JavaThread "State Saver" [_thread_blocked, id=1172, stack(0x00007fb7a4777000,0x00007fb7a4b78000)]
0x00007fb7bd3e1000 JavaThread "Thread-10" [_thread_in_native, id=1171, stack(0x00007fb7a4b78000,0x00007fb7a4f79000)]
0x00007fb7bd3df800 JavaThread "Timer-0" [_thread_blocked, id=1170, stack(0x00007fb7a69a0000,0x00007fb7a6da1000)]
0x0000000000c56800 JavaThread "com.comsol.logger.b@3bc486f2" daemon [_thread_blocked, id=1166, stack(0x00007fb7b7699000,0x00007fb7b7a9a000)]
0x00007fb7b031f800 JavaThread "pool-1-thread-1" [_thread_blocked, id=1163, stack(0x00007fb7b5022000,0x00007fb7b5423000)]
0x00007fb7b04b2000 JavaThread "Worker-0" [_thread_blocked, id=1160, stack(0x00007fb7a968d000,0x00007fb7a9a8e000)]
0x00007fb7bc9dd000 JavaThread "AWT-XAWT" daemon [_thread_in_native, id=1158, stack(0x00007fb7b5423000,0x00007fb7b5824000)]
0x00007fb7bc167800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=1157, stack(0x00007fb7b5824000,0x00007fb7b5c25000)]
0x0000000000cf5000 JavaThread "Worker-JM" [_thread_blocked, id=1156, stack(0x00007fb7b637f000,0x00007fb7b6780000)]
0x0000000001043800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=1154, stack(0x00007fb7b6a96000,0x00007fb7b6e97000)]
0x00007fb7b0019000 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=1152, stack(0x00007fb7b6e97000,0x00007fb7b7298000)]
0x00007fb7b001d000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=1151, stack(0x00007fb7b7298000,0x00007fb7b7699000)]
0x0000000000598000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1148, stack(0x00007fb7c26a3000,0x00007fb7c2aa4000)]
0x0000000000596000 JavaThread "CompilerThread1" daemon [_thread_in_native, id=1147, stack(0x00007fb7c2aa4000,0x00007fb7c2ba5000)]
0x0000000000591000 JavaThread "CompilerThread0" daemon [_thread_in_native, id=1146, stack(0x00007fb7c2ba5000,0x00007fb7c2ca6000)]
0x000000000058f000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1145, stack(0x00007fb7c2ca6000,0x00007fb7c30a7000)]
0x0000000000573000 JavaThread "Finalizer" daemon [_thread_blocked, id=1144, stack(0x00007fb7c30a7000,0x00007fb7c34a8000)]
0x000000000056b800 JavaThread "Reference Handler" daemon [_thread_blocked, id=1143, stack(0x00007fb7c34a8000,0x00007fb7c38a9000)]
=>0x000000000050f000 JavaThread "main" [_thread_in_native, id=1139, stack(0x00007fff21304000,0x00007fff21504000)]
Other Threads:
0x0000000000567000 VMThread [stack: 0x00007fb7c38a9000,0x00007fb7c39aa000] [id=1142]
0x000000000059b000 WatcherThread [stack: 0x00007fb7c25a2000,0x00007fb7c26a3000] [id=1149]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 255488K, used 227067K [0x00007fb7fef00000, 0x00007fb814450000, 0x00007fb814450000)
eden space 231360K, 87% used [0x00007fb7fef00000,0x00007fb80b536d50,0x00007fb80d0f0000)
from space 24128K, 99% used [0x00007fb80f2d0000,0x00007fb810a58030,0x00007fb810a60000)
to space 34688K, 0% used [0x00007fb80d0f0000,0x00007fb80d0f0000,0x00007fb80f2d0000)
PSOldGen total 90240K, used 36402K [0x00007fb7d4450000, 0x00007fb7d9c70000, 0x00007fb7fef00000)
object space 90240K, 40% used [0x00007fb7d4450000,0x00007fb7d67dcb78,0x00007fb7d9c70000)
PSPermGen total 92800K, used 67261K [0x00007fb7c4450000, 0x00007fb7c9ef0000, 0x00007fb7d4450000)
object space 92800K, 72% used [0x00007fb7c4450000,0x00007fb7c85ff5d8,0x00007fb7c9ef0000)
Dynamic libraries:
00400000-00405000 r-xp 00000000 08:04 21626888 /usr/local/comsol42a/bin/glnxa64/comsollauncher
00504000-00505000 rw-p 00004000 08:04 21626888 /usr/local/comsol42a/bin/glnxa64/comsollauncher
00505000-03aee000 rw-p 00505000 00:00 0 [heap]
7fb7a3374000-7fb7a3375000 ---p 7fb7a3374000 00:00 0
7fb7a3375000-7fb7a3b75000 rwxp 7fb7a3375000 00:00 0
7fb7a3b75000-7fb7a3b76000 ---p 7fb7a3b75000 00:00 0
7fb7a3b76000-7fb7a4376000 rwxp 7fb7a3b76000 00:00 0
7fb7a4376000-7fb7a4379000 ---p 7fb7a4376000 00:00 0
7fb7a4379000-7fb7a4777000 rwxp 7fb7a4379000 00:00 0
7fb7a4777000-7fb7a477a000 ---p 7fb7a4777000 00:00 0
7fb7a477a000-7fb7a4b78000 rwxp 7fb7a477a000 00:00 0
7fb7a4b78000-7fb7a4b7b000 ---p 7fb7a4b78000 00:00 0
7fb7a4b7b000-7fb7a4f79000 rwxp 7fb7a4b7b000 00:00 0
7fb7a4f79000-7fb7a4f7a000 ---p 7fb7a4f79000 00:00 0
7fb7a4f7a000-7fb7a577a000 rwxp 7fb7a4f7a000 00:00 0
7fb7a577a000-7fb7a598a000 r-xp 00000000 08:04 21381380 /usr/lib64/dri/swrast_dri.so
7fb7a598a000-7fb7a5b8a000 ---p 00210000 08:04 21381380 /usr/lib64/dri/swrast_dri.so
7fb7a5b8a000-7fb7a5b93000 r--p 00210000 08:04 21381380 /usr/lib64/dri/swrast_dri.so
7fb7a5b93000-7fb7a5ba2000 rw-p 00219000 08:04 21381380 /usr/lib64/dri/swrast_dri.so
7fb7a5ba2000-7fb7a5bae000 rw-p 7fb7a5ba2000 00:00 0
7fb7a5bae000-7fb7a5bb6000 r-xp 00000000 08:04 20912321 /usr/lib64/libdrm.so.2.3.0
7fb7a5bb6000-7fb7a5db5000 ---p 00008000 08:04 20912321 /usr/lib64/libdrm.so.2.3.0
7fb7a5db5000-7fb7a5db6000 r--p 00007000 08:04 20912321 /usr/lib64/libdrm.so.2.3.0
7fb7a5db6000-7fb7a5db7000 rw-p 00008000 08:04 20912321 /usr/lib64/libdrm.so.2.3.0
7fb7a5db7000-7fb7a5dbc000 r-xp 00000000 08:04 23061023 /usr/lib64/libXxf86vm.so.1.0.0
7fb7a5dbc000-7fb7a5fbb000 ---p 00005000 08:04 23061023 /usr/lib64/libXxf86vm.so.1.0.0
7fb7a5fbb000-7fb7a5fbc000 r--p 00004000 08:04 23061023 /usr/lib64/libXxf86vm.so.1.0.0
7fb7a5fbc000-7fb7a5fbd000 rw-p 00005000 08:04 23061023 /usr/lib64/libXxf86vm.so.1.0.0
7fb7a5fbd000-7fb7a6033000 r-xp 00000000 08:04 23061129 /usr/lib64/libGL.so.1.2
7fb7a6033000-7fb7a6232000 ---p 00076000 08:04 23061129 /usr/lib64/libGL.so.1.2
7fb7a6232000-7fb7a623a000 r--p 00075000 08:04 23061129 /usr/lib64/libGL.so.1.2
7fb7a623a000-7fb7a623d000 rw-p 0007d000 08:04 23061129 /usr/lib64/libGL.so.1.2
7fb7a623d000-7fb7a6354000 r-xp 00000000 08:04 21708901 /usr/local/comsol42a/lib/glnxa64/libfltextrenderer.so
7fb7a6354000-7fb7a6454000 ---p 00117000 08:04 21708901 /usr/local/comsol42a/lib/glnxa64/libfltextrenderer.so
7fb7a6454000-7fb7a6461000 rw-p 00117000 08:04 21708901 /usr/local/comsol42a/lib/glnxa64/libfltextrenderer.so
7fb7a6461000-7fb7a6808000 r-xp 00000000 08:04 21708903 /usr/local/comsol42a/lib/glnxa64/libfl3d_direct_swt_ogl.so
7fb7a6808000-7fb7a6908000 ---p 003a7000 08:04 21708903 /usr/local/comsol42a/lib/glnxa64/libfl3d_direct_swt_ogl.so
7fb7a6908000-7fb7a6933000 rw-p 003a7000 08:04 21708903 /usr/local/comsol42a/lib/glnxa64/libfl3d_direct_swt_ogl.so
7fb7a6933000-7fb7a6943000 rw-p 7fb7a6933000 00:00 0
7fb7a69a0000-7fb7a69a3000 ---p 7fb7a69a0000 00:00 0
7fb7a69a3000-7fb7a6da1000 rwxp 7fb7a69a3000 00:00 0
7fb7a6da1000-7fb7a6da7000 r-xp 00000000 08:04 21406213 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7fb7a6da7000-7fb7a6fa6000 ---p 00006000 08:04 21406213 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7fb7a6fa6000-7fb7a6fa7000 r--p 00005000 08:04 21406213 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7fb7a6fa7000-7fb7a6fa8000 rw-p 00006000 08:04 21406213 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7fb7a708e000-7fb7a70ee000 rw-s 00000000 00:0a 2719760 /SYSV00000000 (deleted)
7fb7a70ee000-7fb7a710d000 r--p 00000000 08:04 21186629 /usr/share/fonts/Type1/courbi.pfa
7fb7a710d000-7fb7a7291000 r-xp 00000000 08:04 21708907 /usr/local/comsol42a/lib/glnxa64/libflgraphics_swt_ogl.so
7fb7a7291000-7fb7a7391000 ---p 00184000 08:04 21708907 /usr/local/comsol42a/lib/glnxa64/libflgraphics_swt_ogl.so
7fb7a7391000-7fb7a73a2000 rw-p 00184000 08:04 21708907 /usr/local/comsol42a/lib/glnxa64/libflgraphics_swt_ogl.so
7fb7a73a2000-7fb7a73a5000 ---p 7fb7a73a2000 00:00 0
7fb7a73a5000-7fb7a77a3000 rwxp 7fb7a73a5000 00:00 0
7fb7a77b8000-7fb7a77d6000 r--p 00000000 08:04 21186631 /usr/share/fonts/Type1/couri.pfa
7fb7a77d6000-7fb7a77f5000 r--p 00000000 08:04 21186627 /usr/share/fonts/Type1/courb.pfa
7fb7a77f5000-7fb7a7814000 r--p 00000000 08:04 21186625 /usr/share/fonts/Type1/cour.pfa
7fb7a7814000-7fb7a783f000 r--p 00000000 08:04 21079841 /usr/share/fonts/truetype/albwbi.ttf
7fb7a783f000-7fb7a786c000 r--p 00000000 08:04 21079842 /usr/share/fonts/truetype/albwi.ttf
7fb7a786c000-7fb7a7896000 r--p 00000000 08:04 21079840 /usr/share/fonts/truetype/albwb.ttf
7fb7a7896000-7fb7a78a2000 r-xp 00000000 08:04 21708899 /usr/local/comsol42a/lib/glnxa64/libfljnitextrenderer.so
7fb7a78a2000-7fb7a79a1000 ---p 0000c000 08:04 21708899 /usr/local/comsol42a/lib/glnxa64/libfljnitextrenderer.so
7fb7a79a1000-7fb7a79a2000 rw-p 0000b000 08:04 21708899 /usr/local/comsol42a/lib/glnxa64/libfljnitextrenderer.so
7fb7a79a2000-7fb7a79c8000 r--s 0020a000 08:04 20932848 /usr/local/comsol42a/plugins/org.eclipse.ui.ide_3.6.0.I20100601-0800.jar
7fb7a79c8000-7fb7a79d3000 r-xp 00000000 08:04 25288868 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-atk-gtk-3659.so
7fb7a79d3000-7fb7a7ad2000 ---p 0000b000 08:04 25288868 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-atk-gtk-3659.so
7fb7a7ad2000-7fb7a7ad3000 rw-p 0000a000 08:04 25288868 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-atk-gtk-3659.so
7fb7a7ad3000-7fb7a7ad5000 r-xp 00000000 08:04 21399124 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7fb7a7ad5000-7fb7a7cd4000 ---p 00002000 08:04 21399124 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7fb7a7cd4000-7fb7a7cd5000 r--p 00001000 08:04 21399124 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7fb7a7cd5000-7fb7a7cd6000 rw-p 00002000 08:04 21399124 /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7fb7a7cd6000-7fb7a7d00000 r--p 00000000 08:04 21079839 /usr/share/fonts/truetype/albw.ttf
7fb7a7d00000-7fb7a7d5c000 r--s 00000000 08:04 21799629 /var/cache/fontconfig/df311e82a1a24c41a75c2c930223552e-x86-64.cache-2
7fb7a7d5c000-7fb7a7d5d000 r-xp 00000000 08:04 21406200 /usr/lib64/gtk-2.0/2.10.0/immodules/im-cedilla.so
7fb7a7d5d000-7fb7a7f5d000 ---p 00001000 08:04 21406200 /usr/lib64/gtk-2.0/2.10.0/immodules/im-cedilla.so
7fb7a7f5d000-7fb7a7f5e000 r--p 00001000 08:04 21406200 /usr/lib64/gtk-2.0/2.10.0/immodules/im-cedilla.so
7fb7a7f5e000-7fb7a7f5f000 rw-p 00002000 08:04 21406200 /usr/lib64/gtk-2.0/2.10.0/immodules/im-cedilla.so
7fb7a7f5f000-7fb7a7f63000 r-xp 00000000 08:04 21406219 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7fb7a7f63000-7fb7a8163000 ---p 00004000 08:04 21406219 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7fb7a8163000-7fb7a8164000 r--p 00004000 08:04 21406219 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7fb7a8164000-7fb7a8165000 rw-p 00005000 08:04 21406219 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7fb7a8165000-7fb7a81d7000 r-xp 00000000 08:04 25288861 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-pi-gtk-3659.so
7fb7a81d7000-7fb7a82d6000 ---p 00072000 08:04 25288861 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-pi-gtk-3659.so
7fb7a82d6000-7fb7a82d9000 rw-p 00071000 08:04 25288861 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-pi-gtk-3659.so
7fb7a82d9000-7fb7a82db000 rw-p 7fb7a82d9000 00:00 0
7fb7a82db000-7fb7a8359000 r-xp 00000000 08:04 25288860 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-gtk-3659.so
7fb7a8359000-7fb7a8458000 ---p 0007e000 08:04 25288860 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-gtk-3659.so
7fb7a8458000-7fb7a845f000 rw-p 0007d000 08:04 25288860 /home/appl/.comsol/v42a/configuration/comsol/org.eclipse.osgi/bundles/56/1/.cp/libswt-gtk-3659.so
7fb7a845f000-7fb7a8462000 rw-p 7fb7a845f000 00:00 0
7fb7a8462000-7fb7a8465000 ---p 7fb7a8462000 00:00 0
7fb7a8465000-7fb7a8863000 rwxp 7fb7a8465000 00:00 0
7fb7a8863000-7fb7a8876000 r-xp 00000000 08:04 13238309 /lib64/libresolv-2.9.so
7fb7a8876000-7fb7a8a76000 ---p 00013000 08:04 13238309 /lib64/libresolv-2.9.so
7fb7a8a76000-7fb7a8a77000 r--p 00013000 08:04 13238309 /lib64/libresolv-2.9.so
7fb7a8a77000-7fb7a8a78000 rw-p 00014000 08:04 13238309 /lib64/libresolv-2.9.so
7fb7a8a78000-7fb7a8a7a000 rw-p 7fb7a8a78000 00:00 0
7fb7a8a7a000-7fb7a8a7f000 r-xp 00000000 08:04 13238296 /lib64/libnss_dns-2.9.so
7fb7a8a7f000-7fb7a8c7e000 ---p 00005000 08:04 13238296 /lib64/libnss_dns-2.9.so
7fb7a8c7e000-7fb7a8c7f000 r--p 00004000 08:04 13238296 /lib64/libnss_dns-2.9.so
7fb7a8c7f000-7fb7a8c80000 rw-p 00005000 08:04 13238296 /lib64/libnss_dns-2.9.so
7fb7a8c80000-7fb7a8c8b000 r-xp 00000000 08:04 13238298 /lib64/libnss_files-2.9.so
7fb7a8c8b000-7fb7a8e8a000 ---p 0000b000 08:04 13238298 /lib64/libnss_files-2.9.so
7fb7a8e8a000-7fb7a8e8b000 r--p 0000a000 08:04 13238298 /lib64/libnss_files-2.9.so
7fb7a8e8b000-7fb7a8e8c000 rw-p 0000b000 08:04 13238298 /lib64/libnss_files-2.9.so
7fb7a8e8c000-7fb7a8e8d000 ---p 7fb7a8e8c000 00:00 0
7fb7a8e8d000-7fb7a968d000 rwxp 7fb7a8e8d000 00:00 0
7fb7a968d000-7fb7a9690000 ---p 7fb7a968d000 00:00 0
7fb7a9690000-7fb7a9a8e000 rwxp 7fb7a9690000 00:00 0
7fb7a9a8e000-7fb7a9d57000 r-xp 00000000 08:04 21708931 /usr/local/comsol42a/lib/glnxa64/libflgraphics_common.so
7fb7a9d57000-7fb7a9e57000 ---p 002c9000 08:04 21708931 /usr/local/comsol42a/lib/glnxa64/libflgraphics_common.so
7fb7a9e57000-7fb7a9e65000 rw-p 002c9000 08:04 21708931 /usr/local/comsol42a/lib/glnxa64/libflgraphics_common.so
7fb7a9e65000-7fb7a9e66000 rw-p 7fb7a9e65000 00:00 0
7fb7a9e66000-7fb7ab21f000 r-xp 00000000 08:04 21708902 /usr/local/comsol42a/lib/glnxa64/libflmklblas.so
7fb7ab21f000-7fb7ab31e000 ---p 013b9000 08:04 21708902 /usr/local/comsol42a/lib/glnxa64/libflmklblas.so
7fb7ab31e000-7fb7ab34a000 rw-p 013b8000 08:04 21708902 /usr/local/comsol42a/lib/glnxa64/libflmklblas.so
7fb7ab34a000-7fb7ab34f000 rw-p 7fb7ab34a000 00:00 0
7fb7ab34f000-7fb7ab41e000 r-xp 00000000 08:04 21708920 /usr/local/comsol42a/lib/glnxa64/libflfftw3.so.3.1.2
7fb7ab41e000-7fb7ab51d000 ---p 000cf000 08:04 21708920 /usr/local/comsol42a/lib/glnxa64/libflfftw3.so.3.1.2
7fb7ab51d000-7fb7ab526000 rw-p 000ce000 08:04 21708920 /usr/local/comsol42a/lib/glnxa64/libflfftw3.so.3.1.2
7fb7ab526000-7fb7ab538000 r-xp 00000000 08:04 21708898 /usr/local/comsol42a/lib/glnxa64/libclmpi.so
7fb7ab538000-7fb7ab638000 ---p 00012000 08:04 21708898 /usr/local/comsol42a/lib/glnxa64/libclmpi.so
7fb7ab638000-7fb7ab639000 rw-p 00012000 08:04 21708898 /usr/local/comsol42a/lib/glnxa64/libclmpi.so
7fb7ab639000-7fb7ab797000 r-xp 00000000 08:04 21708922 /usr/local/comsol42a/lib/glnxa64/libifcoremt.so.5
7fb7ab797000-7fb7ab896000 ---p 0015e000 08:04 21708922 /usr/local/comsol42a/lib/glnxa64/libifcoremt.so.5
7fb7ab896000-7fb7ab8a7000 rw-p 0015d000 08:04 21708922 /usr/local/comsol42a/lib/glnxa64/libifcoremt.so.5
7fb7ab8a7000-7fb7ab8d8000 rw-p 7fb7ab8a7000 00:00 0
7fb7ab8d8000-7fb7ab909000 r-xp 00000000 08:04 21708921 /usr/local/comsol42a/lib/glnxa64/libifport.so.5
7fb7ab909000-7fb7aba08000 ---p 00031000 08:04 21708921 /usr/local/comsol42a/lib/glnxa64/libifport.so.5
7fb7aba08000-7fb7aba0b000 rw-p 00030000 08:04 21708921 /usr/local/comsol42a/lib/glnxa64/libifport.so.5
7fb7aba0b000-7fb7aba11000 rw-p 7fb7aba0b000 00:00 0
7fb7aba11000-7fb7aba26000 r-xp 00000000 08:04 21708894 /usr/local/comsol42a/lib/glnxa64/libsundials.so
7fb7aba26000-7fb7abb26000 ---p 00015000 08:04 21708894 /usr/local/comsol42a/lib/glnxa64/libsundials.so
7fb7abb26000-7fb7abb27000 rw-p 00015000 08:04 21708894 /usr/local/comsol42a/lib/glnxa64/libsundials.so
7fb7abb27000-7fb7abb4c000 r-xp 00000000 08:04 21708942 /usr/local/comsol42a/lib/glnxa64/libflblas.so
7fb7abb4c000-7fb7abc4c000 ---p 00025000 08:04 21708942 /usr/local/comsol42a/lib/glnxa64/libflblas.so
7fb7abc4c000-7fb7abc4d000 rw-p 00025000 08:04 21708942 /usr/local/comsol42a/lib/glnxa64/libflblas.so
7fb7abc4d000-7fb7abc7e000 r-xp 00000000 08:04 21708917 /usr/local/comsol42a/lib/glnxa64/libflspecfun.so
7fb7abc7e000-7fb7abd7e000 ---p 00031000 08:04 21708917 /usr/local/comsol42a/lib/glnxa64/libflspecfun.so
7fb7abd7e000-7fb7abd7f000 rw-p 00031000 08:04 21708917 /usr/local/comsol42a/lib/glnxa64/libflspecfun.so
7fb7abd7f000-7fb7abd83000 r-xp 00000000 08:04 21708897 /usr/local/comsol42a/lib/glnxa64/libflcutil.so
7fb7abd83000-7fb7abe83000 ---p 00004000 08:04 21708897 /usr/local/comsol42a/lib/glnxa64/libflcutil.so
7fb7abe83000-7fb7abe85000 rw-p 00004000 08:04 21708897 /usr/local/comsol42a/lib/glnxa64/libflcutil.so
7fb7abe85000-7fb7abeec000 rw-p 7fb7abe85000 00:00 0
7fb7abeec000-7fb7abfbe000 r-xp 00000000 08:04 21716994 /usr/local/comsol42a/lib/glnxa64/ipv4/libflnutil.so
7fb7abfbe000-7fb7ac0bd000 ---p 000d2000 08:04 21716994 /usr/local/comsol42a/lib/glnxa64/ipv4/libflnutil.so
7fb7ac0bd000-7fb7ac0c2000 rw-p 000d1000 08:04 21716994 /usr/local/comsol42a/lib/glnxa64/ipv4/libflnutil.so
7fb7ac0c2000-7fb7ac0d1000 rw-p 7fb7ac0c2000 00:00 0
7fb7ac0d1000-7fb7ac207000 r-xp 00000000 08:04 21708936 /usr/local/comsol42a/lib/glnxa64/libflspooles.so
7fb7ac207000-7fb7ac307000 ---p 00136000 08:04 21708936 /usr/local/comsol42a/lib/glnxa64/libflspooles.so
7fb7ac307000-7fb7ac30b000 rw-p 00136000 08:04 21708936 /usr/local/comsol42a/lib/glnxa64/libflspooles.so
7fb7ac30b000-7fb7ac333000 r-xp 00000000 08:04 21708932 /usr/local/comsol42a/lib/glnxa64/libflarpack.so
7fb7ac333000-7fb7ac432000 ---p 00028000 08:04 21708932 /usr/local/comsol42a/lib/glnxa64/libflarpack.so
7fb7ac432000-7fb7ac434000 rw-p 00027000 08:04 21708932 /usr/local/comsol42a/lib/glnxa64/libflarpack.so
7fb7ac434000-7fb7ac435000 rw-p 7fb7ac434000 00:00 0
7fb7ac435000-7fb7ac575000 r-xp 00000000 08:04 21708937 /usr/local/comsol42a/lib/glnxa64/libflutil.so
7fb7ac575000-7fb7ac674000 ---p 00140000 08:04 21708937 /usr/local/comsol42a/lib/glnxa64/libflutil.so
7fb7ac674000-7fb7ac67b000 rw-p 0013f000 08:04 21708937 /usr/local/comsol42a/lib/glnxa64/libflutil.so
7fb7ac67b000-7fb7ac699000 r-xp 00000000 08:04 21708924 /usr/local/comsol42a/lib/glnxa64/libflcluster.so
7fb7ac699000-7fb7ac799000 ---p 0001e000 08:04 21708924 /usr/local/comsol42a/lib/glnxa64/libflcluster.so
7fb7ac799000-7fb7ac79a000 rw-p 0001e000 08:04 21708924 /usr/local/comsol42a/lib/glnxa64/libflcluster.so
7fb7ac79a000-7fb7acce5000 r-xp 00000000 08:04 21708890 /usr/local/comsol42a/lib/glnxa64/libflarray.so
7fb7acce5000-7fb7acde5000 ---p 0054b000 08:04 21708890 /usr/local/comsol42a/lib/glnxa64/libflarray.so
7fb7acde5000-7fb7ace50000 rw-p 0054b000 08:04 21708890 /usr/local/comsol42a/lib/glnxa64/libflarray.so
7fb7ace50000-7fb7ace51000 rw-p 7fb7ace50000 00:00 0
7fb7ace51000-7fb7acee9000 r-xp 00000000 08:04 21708935 /usr/local/comsol42a/lib/glnxa64/libflclusterarray.so
7fb7acee9000-7fb7acfe8000 ---p 00098000 08:04 21708935 /usr/local/comsol42a/lib/glnxa64/libflclusterarray.so
7fb7acfe8000-7fb7acfeb000 rw-p 00097000 08:04 21708935 /usr/local/comsol42a/lib/glnxa64/libflclusterarray.so
7fb7acfeb000-7fb7ad84f000 r-xp 00000000 08:04 21708915 /usr/local/comsol42a/lib/glnxa64/libflgeom.so
7fb7ad84f000-7fb7ad94f000 ---p 00864000 08:04 21708915 /usr/local/comsol42a/lib/glnxa64/libflgeom.so
7fb7ad94f000-7fb7ad987000 rw-p 00864000 08:04 21708915 /usr/local/comsol42a/lib/glnxa64/libflgeom.so
7fb7ad987000-7fb7ad9cc000 r-xp 00000000 08:04 21708943 /usr/local/comsol42a/lib/glnxa64/libfldatacarrier.so
7fb7ad9cc000-7fb7adacb000 ---p 00045000 08:04 21708943 /usr/local/comsol42a/lib/glnxa64/libfldatacarrier.so
7fb7adacb000-7fb7adacd000 rw-p 00044000 08:04 21708943 /usr/local/comsol42a/lib/glnxa64/libfldatacarrier.so
7fb7adacd000-7fb7ae153000 r-xp 00000000 08:04 21708911 /usr/local/comsol42a/lib/glnxa64/libflmesh.so
7fb7ae153000-7fb7ae253000 ---p 00686000 08:04 21708911 /usr/local/comsol42a/lib/glnxa64/libflmesh.so
7fb7ae253000-7fb7ae267000 rw-p 00686000 08:04 21708911 /usr/local/comsol42a/lib/glnxa64/libflmesh.so
7fb7ae267000-7fb7af514000 r-xp 00000000 08:04 21708918 /usr/local/comsol42a/lib/glnxa64/libflxmesh.so
7fb7af514000-7fb7af614000 ---p 012ad000 08:04 21708918 /usr/local/comsol42a/lib/glnxa64/libflxmesh.so
7fb7af614000-7fb7af667000 rw-p 012ad000 08:04 21708918 /usr/local/comsol42a/lib/glnxa64/libflxmesh.so
7fb7af667000-7fb7afaa9000 r-xp 00000000 08:04 21708900 /usr/local/comsol42a/lib/glnxa64/libflsolver.so
7fb7afaa9000-7fb7afba9000 ---p 00442000 08:04 21708900 /usr/local/comsol42a/lib/glnxa64/libflsolver.so
7fb7afba9000-7fb7afbc3000 rw-p 00442000 08:04 21708900 /usr/local/comsol42a/lib/glnxa64/libflsolver.so
7fb7afbc3000-7fb7afef9000 r-xp 00000000 08:04 21708926 /usr/local/comsol42a/lib/glnxa64/libfljni.so
7fb7afef9000-7fb7afff8000 ---p 00336000 08:04 21708926 /usr/local/comsol42a/lib/glnxa64/libfljni.so
7fb7afff8000-7fb7b0000000 rw-p 00335000 08:04 21708926 /usr/local/comsol42a/lib/glnxa64/libfljni.so
7fb7b0000000-7fb7b07d0000 rw-p 7fb7b0000000 00:00 0
7fb7b07d0000-7fb7b4000000 ---p 7fb7b07d0000 00:00 0
7fb7b4005000-7fb7b4010000 r--s 0007d000 08:04 20932801 /usr/local/comsol42a/plugins/org.eclipse.ui.editors_3.6.0.v20100520-0800.jar
7fb7b4010000-7fb7b406c000 r--s 00000000 08:04 21799630 /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-x86-64.cache-2
7fb7b406c000-7fb7b409a000 r--s 00000000 08:04 21799637 /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-x86-64.cache-2
7fb7b409a000-7fb7b40a3000 r--s 000b1000 08:04 20932793 /usr/local/comsol42a/plugins/com.comsol.solid_1.0.0.jar
7fb7b40a3000-7fb7b40e4000 r-xp 00000000 08:04 21708934 /usr/local/comsol42a/lib/glnxa64/libflpost.so
7fb7b40e4000-7fb7b41e3000 ---p 00041000 08:04 21708934 /usr/local/comsol42a/lib/glnxa64/libflpost.so
7fb7b41e3000-7fb7b41e5000 rw-p 00040000 08:04 21708934 /usr/local/comsol42a/lib/glnxa64/libflpost.so
7fb7b41e5000-7fb7b41fb000 r-xp 00000000 08:04 13238380 /lib64/libgcc_s.so.1
7fb7b41fb000-7fb7b43fb000 ---p 00016000 08:04 13238380 /lib64/libgcc_s.so.1
7fb7b43fb000-7fb7b43fc000 r--p 00016000 08:04 13238380 /lib64/libgcc_s.so.1
7fb7b43fc000-7fb7b43fd000 rw-p 00017000 08:04 13238380 /lib64/libgcc_s.so.1
7fb7b43fd000-7fb7b4437000 r-xp 00000000 08:04 21708933 /usr/local/comsol42a/lib/glnxa64/libintlc.so.5
7fb7b4437000-7fb7b4536000 ---p 0003a000 08:04 21708933 /usr/local/comsol42a/lib/glnxa64/libintlc.so.5
7fb7b4536000-7fb7b4539000 rw-p 00039000 08:04 21708933 /usr/local/comsol42a/lib/glnxa64/libintlc.so.5
7fb7b4539000-7fb7b453a000 rw-p 7fb7b4539000 00:00 0
7fb7b453a000-7fb7b462b000 r-xp 00000000 08:04 23060531 /usr/lib64/libstdc++.so.6.0.10
7fb7b462b000-7fb7b482a000 ---p 000f1000 08:04 23060531 /usr/lib64/libstdc++.so.6.0.10
7fb7b482a000-7fb7b4831000 r--p 000f0000 08:04 23060531 /usr/lib64/libstdc++.so.6.0.10
7fb7b4831000-7fb7b4833000 rw-p 000f7000 08:04 23060531 /usr/lib64/libstdc++.so.6.0.10
7fb7b4833000-7fb7b4846000 rw-p 7fb7b4833000 00:00 0
7fb7b484a000-7fb7b487e000 r--s 00258000 08:04 20932958 /usr/local/comsol42a/plugins/com.comsol.model_1.0.0.jar
7fb7b487e000-7fb7b4904000 r-xp 00000000 08:04 21708896 /usr/local/comsol42a/lib/glnxa64/libiomp5.so
7fb7b4904000-7fb7b4a04000 ---p 00086000 08:04 21708896 /usr/local/comsol42a/lib/glnxa64/libiomp5.so
7fb7b4a04000-7fb7b4a0a000 rw-p 00086000 08:04 21708896 /usr/local/comsol42a/lib/glnxa64/libiomp5.so
7fb7b4a0a000-7fb7b4a11000 rw-p 7fb7b4a0a000 00:00 0
7fb7b4a11000-7fb7b4acd000 r-xp 00000000 08:04 21708945 /usr/local/comsol42a/lib/glnxa64/libsvml.so
7fb7b4acd000-7fb7b4bcd000 ---p 000bc000 08:04 21708945 /usr/local/comsol42a/lib/glnxa64/libsvml.so
7fb7b4bcd000-7fb7b4bce000 rw-p 000bc000 08:04 21708945 /usr/local/comsol42a/lib/glnxa64/libsvml.so
7fb7b4bce000-7fb7b4e1d000 r-xp 00000000 08:04 21708912 /usr/local/comsol42a/lib/glnxa64/libimf.so
7fb7b4e1d000-7fb7b4f1c000 ---p 0024f000 08:04 21708912 /usr/local/comsol42a/lib/glnxa64/libimf.so
7fb7b4f1c000-7fb7b4f21000 rw-p 0024e000 08:04 21708912 /usr/local/comsol42a/lib/glnxa64/libimf.so
7fb7b4f21000-7fb7b4f22000 r-xp 00000000 08:04 21708910 /usr/local/comsol42a/lib/glnxa64/libfldynload.so
7fb7b4f22000-7fb7b5021000 ---p 00001000 08:04 21708910 /usr/local/comsol42a/lib/glnxa64/libfldynload.so
7fb7b5021000-7fb7b5022000 rw-p 00000000 08:04 21708910 /usr/local/comsol42a/lib/glnxa64/libfldynload.so
7fb7b5022000-7fb7b5025000 ---p 7fb7b5022000 00:00 0
7fb7b5025000-7fb7b5423000 rwxp 7fb7b5025000 00:00 0
7fb7b5423000-7fb7b5426000 ---p 7fb7b5423000 00:00 0
7fb7b5426000-7fb7b5824000 rwxp 7fb7b5426000 00:00 0
7fb7b5824000-7fb7b5827000 ---p 7fb7b5824000 00:00 0
7fb7b5827000-7fb7b5c25000 rwxp 7fb7b5827000 00:00 0
7fb7b5c25000-7fb7b5ca3000 r-xp 00000000 08:04 21693213 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libfontmanager.so
7fb7b5ca3000-7fb7b5da2000 ---p 0007e000 08:04 21693213 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libfontmanager.so
7fb7b5da2000-7fb7b5db8000 rw-p 0007d000 08:04 21693213 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libfontmanager.so
7fb7b5db8000-7fb7b5dc9000 rw-p 7fb7b5db8000 00:00 0
7fb7b5dc9000-7fb7b5dce000 r-xp 00000000 08:04 23061013 /usr/lib64/libXtst.so.6.1.0
7fb7b5dce000-7fb7b5fce000 ---p 00005000 08:04 23061013 /usr/lib64/libXtst.so.6.1.0
7fb7b5fce000-7fb7b5fcf000 r--p 00005000 08:04 23061013 /usr/lib64/libXtst.so.6.1.0
7fb7b5fcf000-7fb7b5fd0000 rw-p 00006000 08:04 23061013 /usr/lib64/libXtst.so.6.1.0
7fb7b5fd0000-7fb7b6012000 r-xp 00000000 08:04 21693180 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/xawt/libmawt.so
7fb7b6012000-7fb7b6111000 ---p 00042000 08:04 21693180 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/xawt/libmawt.so
7fb7b6111000-7fb7b611c000 rw-p 00041000 08:04 21693180 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/xawt/libmawt.so
7fb7b611c000-7fb7b611e000 rw-p 7fb7b611c000 00:00 0
7fb7b611e000-7fb7b61b0000 r-xp 00000000 08:04 21693188 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libawt.so
7fb7b61b0000-7fb7b62af000 ---p 00092000 08:04 21693188 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libawt.so
7fb7b62af000-7fb7b62c8000 rw-p 00091000 08:04 21693188 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libawt.so
7fb7b62c8000-7fb7b62ed000 rw-p 7fb7b62c8000 00:00 0
7fb7b62f1000-7fb7b62fa000 r--s 00069000 08:04 20932919 /usr/local/comsol42a/plugins/org.eclipse.search_3.6.0.v20100520-0800.jar
7fb7b62fa000-7fb7b6317000 r--s 00000000 08:04 21799638 /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-x86-64.cache-2
7fb7b6317000-7fb7b6338000 r--s 00607000 08:04 20932770 /usr/local/comsol42a/plugins/com.ibm.icu_4.2.1.v20100412.jar
7fb7b6338000-7fb7b637f000 r--s 003ab000 08:04 20932796 /usr/local/comsol42a/plugins/org.eclipse.ui.workbench_3.6.2.M20110210-1200.jar
7fb7b637f000-7fb7b6382000 ---p 7fb7b637f000 00:00 0
7fb7b6382000-7fb7b6780000 rwxp 7fb7b6382000 00:00 0
7fb7b6781000-7fb7b678d000 r--s 000cd000 08:04 20932779 /usr/local/comsol42a/plugins/com.comsol.post_1.0.0.jar
7fb7b678d000-7fb7b6794000 r--s 0007c000 08:04 20932809 /usr/local/comsol42a/plugins/com.comsol.maxwell_1.0.0.jar
7fb7b6794000-7fb7b6796000 r--s 00001000 08:04 20932759 /usr/local/comsol42a/plugins/com.comsol.modelresources_1.0.0.jar
7fb7b6796000-7fb7b679c000 r--s 0008a000 08:04 20932789 /usr/local/comsol42a/plugins/com.comsol.geommesh_1.0.0.jar
7fb7b679c000-7fb7b67a7000 r-xp 00000000 08:04 21708946 /usr/local/comsol42a/lib/glnxa64/libcssystemutil.so
7fb7b67a7000-7fb7b68a7000 ---p 0000b000 08:04 21708946 /usr/local/comsol42a/lib/glnxa64/libcssystemutil.so
7fb7b68a7000-7fb7b68a8000 rw-p 0000b000 08:04 21708946 /usr/local/comsol42a/lib/glnxa64/libcssystemutil.so
7fb7b68a8000-7fb7b68a9000 rw-p 7fb7b68a8000 00:00 0
7fb7b68ac000-7fb7b68b6000 r--s 0006e000 08:04 20932912 /usr/local/comsol42a/plugins/org.eclipse.help.ui_3.5.3.r36_20101116.jar
7fb7b68b6000-7fb7b68c0000 r--s 00000000 08:04 21799633 /var/cache/fontconfig/77e41c5059666d75f92e318d4be8c21e-x86-64.cache-2
7fb7b68c0000-7fb7b68c7000 r--s 00000000 08:04 21799632 /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-x86-64.cache-2
7fb7b68c7000-7fb7b68cb000 r--s 0002b000 08:04 20932907 /usr/local/comsol42a/plugins/com.comsol.sme_1.0.0.jar
7fb7b68db000-7fb7b68e0000 r--s 00044000 08:04 20932926 /usr/local/comsol42a/plugins/org.eclipse.ui.forms_3.5.2.r36_v20100702.jar
7fb7b68e0000-7fb7b68e8000 r--s 0003b000 08:04 20932761 /usr/local/comsol42a/plugins/org.eclipse.core.databinding.observable_1.3.0.I20100601-0800.jar
7fb7b68e8000-7fb7b68f0000 r--s 0003a000 08:04 20932899 /usr/local/comsol42a/plugins/org.eclipse.jface.databinding_1.4.0.I20100601-0800.jar
7fb7b68f0000-7fb7b68f7000 r--s 00031000 08:04 20932831 /usr/local/comsol42a/plugins/com.comsol.widgets.swt_1.0.0.jar
7fb7b68f7000-7fb7b68fb000 r--s 00017000 08:04 20932776 /usr/local/comsol42a/plugins/org.eclipse.core.commands_3.6.0.I20100512-1500.jar
7fb7b68fb000-7fb7b6910000 r--s 0023e000 08:04 20932904 /usr/local/comsol42a/plugins/org.eclipse.swt.gtk.linux.x86_64_3.6.2.v3659b.jar
7fb7b6910000-7fb7b6915000 r--s 0003d000 08:04 20932913 /usr/local/comsol42a/plugins/com.comsol.bfc_1.0.0.jar
7fb7b6915000-7fb7b691a000 r--s 00039000 08:04 20932823 /usr/local/comsol42a/plugins/com.comsol.nativemph_1.0.0.jar
7fb7b691a000-7fb7b6921000 r--s 00031000 08:04 20932938 /usr/local/comsol42a/plugins/com.comsol.nativeutil_1.0.0.jar
7fb7b6921000-7fb7b6923000 r--s 00008000 08:04 20932935 /usr/local/comsol42a/plugins/com.comsol.guiswt_1.0.0.jar
7fb7b6923000-7fb7b692a000 r--s 00076000 08:04 20932739 /usr/local/comsol42a/plugins/com.comsol.applapi_1.0.0.jar
7fb7b692a000-7fb7b692f000 r--s 0003d000 08:04 20932925 /usr/local/comsol42a/plugins/com.comsol.core_1.0.0.jar
7fb7b692f000-7fb7b6964000 r--s 00000000 08:04 21799695 /var/run/nscd/db47na6u (deleted)
7fb7b6964000-7fb7b6967000 r--s 00027000 08:04 21692514 /usr/local/comsol42a/java/glnxa64/jre/lib/ext/sunjce_provider.jar
7fb7b6967000-7fb7b696e000 r--s 00083000 08:04 21692512 /usr/local/comsol42a/java/glnxa64/jre/lib/jsse.jar
7fb7b696e000-7fb7b6972000 r--s 00032000 08:04 20932746 /usr/local/comsol42a/plugins/org.eclipse.emf.ecore.xmi_2.5.0.v200906151043.jar
7fb7b6975000-7fb7b6978000 r--s 00013000 08:04 21693031 /usr/local/comsol42a/java/glnxa64/jre/lib/jce.jar
7fb7b6978000-7fb7b697e000 r--s 0007f000 08:04 20932799 /usr/local/comsol42a/plugins/com.comsol.migration_1.0.0.jar
7fb7b697e000-7fb7b6993000 r--s 000f1000 08:04 20932818 /usr/local/comsol42a/plugins/org.eclipse.jface_3.6.2.M20110210-1200.jar
7fb7b6993000-7fb7b6997000 r--s 0003b000 08:04 20932894 /usr/local/comsol42a/plugins/org.eclipse.help_3.5.0.v20100524.jar
7fb7b6997000-7fb7b69a2000 r--s 0006f000 08:04 20932855 /usr/local/comsol42a/plugins/com.comsol.model.edit_1.0.0.jar
7fb7b69a2000-7fb7b69a5000 r--s 00262000 08:04 20932921 /usr/local/comsol42a/plugins/com.comsol.ssf_1.0.0.jar
7fb7b69a5000-7fb7b69c7000 r--s 002fb000 08:04 20932764 /usr/local/comsol42a/plugins/com.comsol.resources_1.0.0.jar
7fb7b69c9000-7fb7b69cb000 r--s 00157000 08:04 26230882 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.plasma.argon_gec_icp.jar
7fb7b69cd000-7fb7b69d3000 r--s 0008b000 08:04 20932780 /usr/local/comsol42a/plugins/com.comsol.solver_1.0.0.jar
7fb7b69d3000-7fb7b69e7000 r--s 001bb000 08:04 20932754 /usr/local/comsol42a/plugins/com.comsol.transport_1.0.0.jar
7fb7b69fc000-7fb7b69fe000 r--s 00096000 08:04 20965250 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.acdc.permanent_magnet.jar
7fb7b69fe000-7fb7b6a0d000 r--s 000f3000 08:04 20932903 /usr/local/comsol42a/plugins/org.eclipse.emf.ecore_2.5.0.v200906151043.jar
7fb7b6a0d000-7fb7b6a12000 r--s 0003b000 08:04 20932743 /usr/local/comsol42a/plugins/org.eclipse.emf.edit_2.5.0.v200906151043.jar
7fb7b6a16000-7fb7b6a18000 r--s 00058000 08:04 20965395 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.mph.shock_tube.jar
7fb7b6a18000-7fb7b6a1b000 r--s 00014000 08:04 20932742 /usr/local/comsol42a/plugins/org.eclipse.core.jobs_3.5.1.R36x_v20100824.jar
7fb7b6a1b000-7fb7b6a1d000 r--s 0001f000 08:04 20965405 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.mph.black_scholes_put.jar
7fb7b6a1e000-7fb7b6a20000 r--s 000f3000 08:04 20965486 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.geomech.deep_excavation.jar
7fb7b6a20000-7fb7b6a22000 r--s 000ad000 08:04 20965298 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.aco.horn_shape_optimization.jar
7fb7b6a22000-7fb7b6a24000 r--s 0007b000 08:04 26230886 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.plasma.argon_gec_ccp_1d.jar
7fb7b6a24000-7fb7b6a26000 r--s 0007d000 08:04 26230836 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.mems.gecko_foot.jar
7fb7b6a26000-7fb7b6a28000 r--s 000a5000 08:04 20965367 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.mph.transport_and_adsorption.jar
7fb7b6a28000-7fb7b6a2d000 r--s 00019000 08:04 20932836 /usr/local/comsol42a/plugins/com.comsol.clientserver_1.0.0.jar
7fb7b6a2d000-7fb7b6a31000 r--s 00018000 08:04 20932811 /usr/local/comsol42a/plugins/com.comsol.nativejni_1.0.0.jar
7fb7b6a31000-7fb7b6a3e000 r--s 00061000 08:04 20932906 /usr/local/comsol42a/plugins/com.comsol.widgets_1.0.0.jar
7fb7b6a3e000-7fb7b6a51000 r--s 000f9000 08:04 20932941 /usr/local/comsol42a/plugins/com.comsol.guimph_1.0.0.jar
7fb7b6a52000-7fb7b6a59000 r--s 00053000 08:04 20932947 /usr/local/comsol42a/plugins/com.comsol.util_1.0.0.jar
7fb7b6a5a000-7fb7b6a5c000 r--s 00066000 08:04 26230961 /usr/local/comsol42a/doc/plugins/com.comsol.help.models.sme.cylinder_roller_contact.jar
7fb7b6a5c000-7fb7b6a5f000 r--s 00019000 08:04 20932882 /usr/local/comsol42a/plugins/org.eclipse.equinox.preferences_3.3.0.v20100503.jar
7fb7b6a5f000-7fb7b6a61000 r--s 00017000 08:04 20932747 /usr/local/comsol42a/plugins/org.eclipse.equinox.common_3.6.0.v20100503.jar
7fb7b6a61000-7fb7b6a6c000 r--s 0006e000 08:04 20932851 /usr/local/comsol42a/plugins/truezip-6.jar
7fb7b6a6c000-7fb7b6a70000 r--s 0002e000 08:04 20932846 /usr/local/comsol42a/plugins/org.eclipse.emf.common_2.5.0.v200906151043.jar
7fb7b6a70000-7fb7b6a72000 r--s 001f6000 08:04 20932771 /usr/local/comsol42a/plugins/com.comsol.cefs_1.0.0.jar
7fb7b6a72000-7fb7b6a76000 r--s 00024000 08:04 20932875 /usr/local/comsol42a/plugins/org.eclipse.emf.edit.ui_2.5.0.v200906151043.jar
7fb7b6a76000-7fb7b6a7b000 r--s 00035000 08:04 20932917 /usr/local/comsol42a/plugins/com.comsol.physics_1.0.0.jar
7fb7b6a7b000-7fb7b6a7c000 r--s 00005000 08:04 20932819 /usr/local/comsol42a/plugins/com.comsol.reaction_1.0.0.jar
7fb7b6a7c000-7fb7b6a7f000 r--s 00013000 08:04 20932864 /usr/local/comsol42a/plugins/org.eclipse.ui.views_3.5.1.M20110202-0800.jar
7fb7b6a7f000-7fb7b6a82000 r--s 0000f000 08:04 20932911 /usr/local/comsol42a/plugins/com.comsol.swtext_1.0.0.jar
7fb7b6a82000-7fb7b6a85000 rw-s 00000000 00:0a 2686990 /SYSV00000000 (deleted)
7fb7b6a85000-7fb7b6a90000 r--s 000ce000 08:04 20932741 /usr/local/comsol42a/plugins/com.comsol.design_1.0.0.jar
7fb7b6a90000-7fb7b6a93000 r--s 0001c000 08:04 20932817 /usr/local/comsol42a/plugins/org.eclipse.emf.common.ui_2.5.0.v200906151043.jar
7fb7b6a93000-7fb7b6a96000 r--s 00013000 08:04 20932905 /usr/local/comsol42a/plugins/org.eclipse.core.expressions_3.4.200.v20100505.jar
7fb7b6a96000-7fb7b6a99000 ---p 7fb7b6a96000 00:00 0
7fb7b6a99000-7fb7b6e97000 rwxp 7fb7b6a99000 00:00 0
7fb7b6e97000-7fb7b6e9a000 ---p 7fb7b6e97000 00:00 0
7fb7b6e9a000-7fb7b7298000 rwxp 7fb7b6e9a000 00:00 0
7fb7b7298000-7fb7b729b000 ---p 7fb7b7298000 00:00 0
7fb7b729b000-7fb7b7699000 rwxp 7fb7b729b000 00:00 0
7fb7b7699000-7fb7b769c000 ---p 7fb7b7699000 00:00 0
7fb7b769c000-7fb7b7a9a000 rwxp 7fb7b769c000 00:00 0
7fb7b7a9a000-7fb7b7aa1000 r-xp 00000000 08:04 21693172 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libnio.so
7fb7b7aa1000-7fb7b7ba0000 ---p 00007000 08:04 21693172 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libnio.so
7fb7b7ba0000-7fb7b7ba2000 rw-p 00006000 08:04 21693172 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libnio.so
7fb7b7ba2000-7fb7b7bb5000 r-xp 00000000 08:04 21693190 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libnet.so
7fb7b7bb5000-7fb7b7cb6000 ---p 00013000 08:04 21693190 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libnet.so
7fb7b7cb6000-7fb7b7cb9000 rw-p 00014000 08:04 21693190 /usr/local/comsol42a/java/glnxa64/jre/lib/amd64/libnet.so
7fb7b7cb9000-7fb7b7cbd000 r-xp 00000000 08:04 21406212 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7fb7b7cbd000-7fb7b7ebc000 ---p 00004000 08:04 21406212 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7fb7b7ebc000-7fb7b7ebd000 r--p 00003000 08:04 21406212 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7fb7b7ebd000-7fb7b7ebe000 rw-p 00004000 08:04 21406212 /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7fb7b7ebe000-7fb7b7ec3000 r-xp 00000000 08:04 20912380 /usr/lib64/libogg.so.0.5.3
7fb7b7ec3000-7fb7b80c2000 ---p 00005000 08:04 20912380 /usr/lib64/libogg.so.0.5.3
7fb7b80c2000-7fb7b80c3000 r--p 00004000 08:04 20912380 /usr/lib64/libogg.so.0.5.3
7fb7b80c3000-7fb7b80c4000 rw-p 00005000 08:04 20912380 /usr/lib64/libogg.so.0.5.3
7fb7b80c4000-7fb7b80e6000 r-xp 00000000 08:04 20912788 /usr/lib64/libvorbis.so.0.4.0
7fb7b80e6000-7fb7b82e5000 ---p 00022000 08:04 20912788 /usr/lib64/libvorbis.so.0.4.0
7fb7b82e5000-7fb7b82e6000 r--p 00021000 08:04 20912788 /usr/lib64/libvorbis.so.0.4.0
7fb7b82e6000-7fb7b82f4000 rw-p 00022000 08:04 20912788 /usr/lib64/libvorbis.so.0.4.0
7fb7b82f4000-7fb7b82fd000 r-xp 00000000 08:04 20912415 /usr/lib64/libltdl.so.7.2.0
7fb7b82fd000-7fb7b84fc000 ---p 00009000 08:04 20912415 /usr/lib64/libltdl.so.7.2.0
7fb7b84fc000-7fb7b84fd000 r--p 00008000 08:04 20912415 /usr/lib64/libltdl.so.7.2.0
7fb7b84fd000-7fb7b84fe000 rw-p 00009000 08:04 20912415 /usr/lib64/libltdl.so.7.2.0
7fb7b84fe000-7fb7b8505000 r-xp 00000000 08:04 20912792 /usr/lib64/libvorbisfile.so.3.2.0
7fb7b8505000-7fb7b8704000 ---p 00007000 08:04 20912792 /usr/lib64/libvorbisfile.so.3.2.0
7fb7b8704000-7fb7b8705000 r--p 00006000 08:04 20912792 /usr/lib64/libvorbisfile.so.3.2.0
7fb7b8705000-7fb7b8706000 rw-p 00007000 08:04 20912792 /usr/lib64/libvorbisfile.so.3.2.0
7fb7b8706000-7fb7b8709000 r-xp 00000000 08:04 23076975 /usr/lib64/libcanberra-gtk.so.0.0.4
7fb7b8709000-7fb7b8908000 ---p 00003000 08:04 23076975 /usr/lib64/libcanberra-gtk.so.0.0.4
7fb7b8908000-7fb7b8909000 r--p 00002000 08:04 23076975 /usr/lib64/libcanberra-gtk.so.0.0.4
7fb7b8909000-7fb7b890a000 rw-p 00003000 08:04 23076975 /usr/lib64/libcanberra-gtk.so.0.0.4
7fb7b890a000-7fb7b8917000 r-xp 00000000 08:04 23061124 /usr/lib64/libcanberra.so.0.1.3
7fb7b8917000-7fb7b8b17000 ---p 0000d000 08:04 23061124 /usr/lib64/libcanberra.so.0.1.3
7fb7b8b17000-7fb7b8b18000 r--p 0000d000 08:04 23061124 /usr/lib64/libcanberra.so.0.1.3
7fb7b8b18000-7fb7b8b19000 rw-p 0000e000 08:04 23061124 /usr/lib64/libcanberra.so.0.1.3
7fb7b8b19000-7fb7b8b1d000 r-xp 00000000 08:04 23060888 /usr/lib64/libgthread-2.0.so.0.1800.2
7fb7b8b1d000-7fb7b8d1c000 ---p 00004000 08:04 23060888 /usr/lib64/libgthread-2.0.so.0.1800.2
7fb7b8d1c000-7fb7b8d1d000 r--p 00003000 08:04 23060888 /usr/lib64/libgthread-2.0.so.0.1800.2
7fb7b8d1d000-7fb7b8d1e000 rw-p 00004000 08:04 23060888 /usr/lib64/libgthread-2.0.so.0.1800.2
7fb7b8d1e000-7fb7b8d23000 r-xp 00000000 08:04 21406767 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7fb7b8d23000-7fb7b8f22000 ---p 00005000 08:04 21406767 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7fb7b8f22000-7fb7b8f23000 r--p 00004000 08:04 21406767 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7fb7b8f23000-7fb7b8f24000 rw-p 00005000 08:04 21406767 /usr/lib64/gtk-2.0/modules/libcanberra-gtk-module.so
7fb7b8f24000-7fb7b8f2d000 r-xp 00000000 08:04 21406196 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7fb7b8f2d000-7fb7b912d000 ---p 00009000 08:04 21406196 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7fb7b912d000-7fb7b912e000 r--p 00009000 08:04 21406196 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7fb7b912e000-7fb7b912f000 rw-p 0000a000 08:04 21406196 /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7fb7b912f000-7fb7b9157000 r-xp 00000000 08:04 21406755 /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7fb7b9157000-7fb7b9356000 ---p 00028000 08:04 21406755 /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7fb7b9356000-7fb7b9357000 r--p 00027000 08:04 21406755 /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7fb7b9357000-7fb7b9358000 rw-p 00028000 08:04 21406755 /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7fb7b9358000-7fb7b9376000 r-xp 00000000 08:04 23060952 /usr/lib64/libatk-1.0.so.0.2409.1
7fb7b9376000-7fb7b9575000 ---p 0001e000 08:04 23060952 /usr/lib64/libatk-1.0.so.0.2409.1
7fb7b9575000-7fb7b9578000 r--p 0001d000 08:04 23060952 /usr/lib64/libatk-1.0.so.0.2409.1
7fb7b9578000-7fb7b9579000 rw-p 00020000 08:04 23060952 /usr/lib64/libatk-1.0.so.0.2409.1
7fb7b9579000-7fb7b9950000 r-xp 00000000 08:04 23061309 /usr/lib64/libgtk-x11-2.0.so.0.1400.4
7fb7b9950000-7fb7b9b50000 ---p 003d7000 08:04 23061309 /usr/lib64/libgtk-x11-2.0.so.0.1400.4
7fb7b9b50000-7fb7b9b57000 r--p 003d7000 08:04 23061309 /usr/lib64/libgtk-x11-2.0.so.0.1400.4
7fb7b9b57000-7fb7b9b5b000 rw-p 003de000 08:04 23061309 /usr/lib64/libgtk-x11-2.0.so.0.1400.4
7fb7b9b5b000-7fb7b9b5d000 rw-p 7fb7b9b5b000 00:00 0
7fb7b9b5d000-7fb7b9b78000 r-xp 00000000 08:04 13238331 /lib64/libselinux.so.1
7fb7b9b78000-7fb7b9d77000 ---p 0001b000 08:04 13238331 /lib64/libselinux.so.1
7fb7b9d77000-7fb7b9d78000 r--p 0001a000 08:04 13238331 /lib64/libselinux.so.1
7fb7b9d78000-7fb7b9d79000 rw-p 0001b000 08:04 13238331 /lib64/libselinux.so.1
7fb7b9d79000-7fb7b9d7a000 rw-p 7fb7b9d79000 00:00 0
7fb7b9d7a000-7fb7b9da1000 r-xp 00000000 08:04 13238384 /lib64/libexpat.so.1.5.2
7fb7b9da1000-7fb7b9fa1000 ---p 00027000 08:04 13238384 /lib64/libexpat.so.1.5.2
7fb7b9fa1000-7fb7b9fa3000 r--p 00027000 08:04 13238384 /lib64/libexpat.so.1.5.2
7fb7b9fa3000-7fb7b9fa4000 rw-p 00029000 08:04 13238384 /lib64/libexpat.so.1.5.2
7fb7b9fa4000-7fb7b9fcf000 r-xp 00000000 08:04 23061262 /usr/lib64/libpangoft2-1.0.so.0.2201.0
7fb7b9fcf000-7fb7ba1cf000 ---p 0002b000 08:04 23061262 /usr/lib64/libpangoft2-1.0.so.0.2201.0
7fb7ba1cf000-7fb7ba1d0000 r--p 0002b000 08:04 23061262 /usr/lib64/libpangoft2-1.0.so.0.2201.0
7fb7ba1d0000-7fb7ba1d1000 rw-p 0002c000 08:04 23061262 /usr/lib64/libpangoft2-1.0.so.0.2201.0
7fb7ba1d1000-7fb7ba1d4000 r-xp 00000000 08:04 23060834 /usr/lib64/libgmodule-2.0.so.0.1800.2
7fb7ba1d4000-7fb7ba3d3000 ---p 00003000 08:04 23060834 /usr/lib64/libgmodule-2.0.so.0.1800.2
7fb7ba3d3000-7fb7ba3d4000 r--p 00002000 08:04 23060834 /usr/lib64/libgmodule-2.0.so.0.1800.2
7fb7ba3d4000-7fb7ba3d5000 rw-p 00003000 08:04 23060834 /usr/lib64/libgmodule-2.0.so.0.1800.2
7fb7ba3d5000-7fb7ba447000 r-xp 00000000 08:04 23060902 /usr/lib64/libgio-2.0.so.0.1800.2
7fb7ba447000-7fb7ba647000 ---p 00072000 08:04 23060902 /usr/lib64/libgio-2.0.so.0.1800.2
7fb7ba647000-7fb7ba649000 r--p 00072000 08:04 23060902 /usr/lib64/libgio-2.0.so.0.1800.2
7fb7ba649000-7fb7ba64a000 rw-p 00074000 08:04 23060902 /usr/lib64/libgio-2.0.so.0.1800.2
7fb7ba64a000-7fb7ba64b000 rw-p 7fb7ba64a000 00:00 0
7fb7ba64b000-7fb7ba665000 r-xp 00000000 08:04 23061305 /usr/lib64/libgdk_pixbuf-2.0.so.0.1400.4
7fb7ba665000-7fb7ba864000 ---p 0001a000 08:04 23061305 /usr/lib64/libgdk_pixbuf-2.0.so.0.1400.4
7fb7ba864000-7fb7ba865000 r--p 00019000 08:04 23061305 /usr/lib64/libgdk_pixbuf-2.0.so.0.1400.4
7fb7ba865000-7fb7ba866000 rw-p 0001a000 08:04 23061305 /usr/lib64/libgdk_pixbuf-2.0.so.0.1400.4
7fb7ba866000-7fb7ba868000 r-xp 00000000 08:04 20912442 /usr/lib64/libXau.so.6.0.0
7fb7ba868000-7fb7baa68000 ---p 00002000 08:04 20912442 /usr/lib64/libXau.so.6.0.0
7fb7baa68000-7fb7baa69000 r--p 00002000 08:04 20912442 /usr/lib64/libXau.so.6.0.0
7fb7baa69000-7fb7baa6a000 rw-p 00003000 08:04 20912442 /usr/lib64/libXau.so.6.0.0
7fb7baa6a000-7fb7baa85000 r-xp 00000000 08:04 20912771 /usr/lib64/libxcb.so.1.0.0
7fb7baa85000-7fb7bac84000 ---p 0001b000 08:04 20912771 /usr/lib64/libxcb.so.1.0.0
7fb7bac84000-7fb7bac85000 r--p 0001a000 08:04 20912771 /usr/lib64/libxcb.so.1.0.0
7fb7bac85000-7fb7bac86000 rw-p 0001b000 08:04 20912771 /usr/lib64/libxcb.so.1.0.0
7fb7bac86000-7fb7bac87000 r-xp 00000000 08:04 20912761 /usr/lib64/libxcb-xlib.so.0.0.0
7fb7bac87000-7fb7bae86000 ---p 00001000 08:04 20912761 /usr/lib64/libxcb-xlib.so.0.0.0
7fb7bae86000-7fb7bae87000 r--p 00000000 08:04 20912761 /usr/lib64/libxcb-xlib.so.0.0.0
7fb7bae87000-7fb7bae88000 rw-p 00001000 08:04 20912761 /usr/lib64/libxcb-xlib.so.0.0.0
7fb7bae88000-7fb7bafbf000 r-xp 00000000 08:04 23060702 /usr/lib64/libX11.so.6.2.0
7fb7bafbf000-7fb7bb1bf000 ---p 00137000 08:04 23060702 /usr/lib64/libX11.so.6.2.0
7fb7bb1bf000-7fb7bb1c0000 r--p 00137000 08:04 23060702 /usr/lib64/libX11.so.6.2.0
7fb7bb1c0000-7fb7bb1c5000 rw-p 00138000 08:04 23060702 /usr/lib64/libX11.so.6.2.0
7fb7bb1c5000-7fb7bb1ca000 r-xp 00000000 08:04 23060777 /usr/lib64/libXfixes.so.3.1.0
7fb7bb1ca000-7fb7bb3c9000 ---p 00005000 08:04 23060777 /usr/lib64/libXfixes.so.3.1.0
7fb7bb3c9000-7fb7bb3ca000 r--p 00004000 08:04 23060777 /usr/lib64/libXfixes.so.3.1.0
7fb7bb3ca000-7fb7bb3cb000 rw-p 00005000 08:04 23060777 /usr/lib64/libXfixes.so.3.1.0
7fb7bb3cb000-7fb7bb3cd000 r-xp 00000000 08:04 23060991 /usr/lib64/libXdamage.so.1.1.0
7fb7bb3cd000-7fb7bb5cc000 ---p 00002000 08:04 23060991 /usr/lib64/libXdamage.so.1.1.0
7fb7bb5cc000-7fb7bb5cd000 r--p 00001000 08:04 23060991 /usr/lib64/libXdamage.so.1.1.0
7fb7bb5cd000-7fb7bb5ce000 rw-p 00002000 08:04 23060991 /usr/lib64/libXdamage.so.1.1.0
7fb7bb5ce000-7fb7bb5df000 r-xp 00000000 08:04 23060779 /usr/lib64/libXext.so.6.4.0
7fb7bb5df000-7fb7bb7de000 ---p 00011000 08:04 23060779 /usr/lib64/libXext.so.6.4.0
7fb7bb7de000-7fb7bb7df000 r--p 00010000 08:04 23060779 /usr/lib64/libXext.so.6.4.0
7fb7bb7df000-7fb7bb7e0000 rw-p 00011000 08:04 23060779 /usr/lib64/libXext.so.6.4.0
7fb7bb7e0000-7fb7bb7e2000 r-xp 00000000 08:04 23060987 /usr/lib64/libXcomposite.so.1.0.0
7fb7bb7e2000-7fb7bb9e1000 ---p 00002000 08:04 23060987 /usr/lib64/libXcomposite.so.1.0.0
7fb7bb9e1000-7fb7bb9e2000 r--p 00001000 08:04 23060987 /usr/lib64/libXcomposite.so.1.0.0
7fb7bb9e2000-7fb7bb9e3000 rw-p 00002000 08:04 23060987 /usr/lib64/libXcomposite.so.1.0.0
7fb7bb9e3000-7fb7bb9ec000 r-xp 00000000 08:04 23060775 /usr/lib64/libXrender.so.1.3.0
7fb7bb9ec000-7fb7bbbeb000 ---p 00009000 08:04 23060775 /usr/lib64/libXrender.so.1.3.0
7fb7bbbeb000-7fb7bbbec000 r--p 00008000 08:04 23060775 /usr/lib64/libXrender.so.1.3.0
7fb7bbbec000-7fb7bbbed000 rw-p 00009000 08:04 23060775 /usr/lib64/libXrender.so.1.3.0
7fb7bbbed000-7fb7bbbf7000 r-xp 00000000 08:04 23060989 /usr/lib64/libXcursor.so.1.0.2
7fb7bbbf7000-7fb7bbdf6000 ---p 0000a000 08:04 23060989 /usr/lib64/libXcursor.so.1.0.2
7fb7bbdf6000-7fb7bbdf7000 r--p 00009000 08:04 23060989 /usr/lib64/libXcursor.so.1.0.2
7fb7bbdf7000-7fb7bbdf8000 rw-p 0000a000 08:04 23060989 /usr/lib64/libXcursor.so.1.0.2
7fb7bbdf8000-7fb7bbdff000 r-xp 00000000 08:04 23061009 /usr/lib64/libXrandr.so.2.1.0
7fb7bbdff000-7fb7bbffe000 ---p 00007000 08:04 23061009 /usr/lib64/libXrandr.so.2.1.0
7fb7 |
