- 2011-9-30
楼主 |
发表于 2012-4-11 14:26:51
来自 广东深圳
Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
THE SLAVE SURFACES ASSEMBLY__PICKEDSURF1154 AND ASSEMBLY__PICKEDSURF1100 INTERSECT EACH OTHER. THEY ARE PAIRED WITH MASTER SURFACES ASSEMBLY__PICKEDSURF1153 AND ASSEMBLY__PICKEDSURF967 THAT ALSO INTERSECT EACH OTHER. IF BOTH PAIRS ARE *CONTACT PAIRs, THESE TWO PAIRS SHOULD NOT BE SIMULTANEOUSLY PRESENT IN A STEP BECAUSE OF POSSIBLE CONVERGENCE PROBLEMS; USE *MODEL CHANGE,TYPE=CONTACT PAIR TO REMOVE ONE OF THEM. IF BOTH ARE *TIE PAIRS, THE REDUNDANT TIES WILL BE REMOVED AUTOMATICALLY. IF ONE PAIR IS *TIE AND ANOTHER IS *CONTACT PAIR, REMOVE ONE OF THEM.
For *tie pair (assembly__pickedsurf1583-assembly__pickedsurf955), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
上述警告信息在不开洞填充墙框架模型也出现过,不影响计算。现在只是开门洞就一直无法计算了。
