- 40
- 2003-8-3
发表于 2003-8-21 08:36:01
来自 北京
回复: 【灌水】求教各位高手,反应装甲,k文件怎么不能运行呢?
一个简单的爆炸的例子,我从清华搞到的
水木清华 -- 文章阅读 [讨论区: FEA]
发信人: zguo (子果), 信区: FEA
标 题: Lsdyna例四
发信站: BBS 水木清华站 (Wed May 15 20:08:15 2002)
这是今天刚刚从一个网友处得到的,好像是个爆炸球问题
以前有人问我要,今天终于可以满足一下了。
注意:由于bbs的问题,里面有些错行,请用ultredit修改在用lsdyna求解
*KEYWORD
*TITLE
an exploding sphere
$$$$$$ An explosive material is placed inside of a sphere.
$$$$$$ The explosive is lit, expands, and impacts the sphere.
$$$$$$ The sphere expands, reaches yield, seam lines fail and fragments
$$$$$$ fly apart.
$ - original model obtained from K. Bui (LSTC) - 4/22/97
$ - modified, documented and cleaned up
$ - renumber solid elements (explosive) so file can be read into HyperMesh
$ - scale the solid nodes by 0.9 to make explosive smaller than sphere
$ - merge all sphere coincident nodes
$ - switch to *MAT_PLASTIC_KINEMATIC for sphere
$ - create a new part and move seam line shell elements on the sphere
$ into that part
$ - allow seam line shell elements to fail (with failure strain of 0.2)
$ - time step must be scaled down for stability
$ John D. Reid 1/31/00
$ Units: unknown - possibly gm, cm, micros, 1E7N, Mbar, 1E7N-cm
$$$$ Control Ouput
$...>....1....>....2....>....3....>....4....>....5....>....6....>....7....>.
...8
*CONTROL_TERMINATION
$ endtim endcyc dtmin endeng endmas
50.0
*CONTROL_TIMESTEP
$ dtinit tssfac isdo tslimt dt2ms lctm erode m
s1st
0.30
*CONTROL_ENERGY
$ hgen rwen slnten rylen
2 2 2
*CONTROL_OUTPUT
$ npopt neecho nrefup iaccop opifs ipnint ikedit
1 3
*DATABASE_BINARY_D3PLOT
$ dt
1.0
$*DATABASE_EXTENT_BINARY
$ neiph neips maxint strflg sigflg epsflg rltflg en
gflg
$ cmpflg ieverp beamip
$ 1
*DATABASE_BINARY_D3THDT
$ dt
999999.9
*DATABASE_GLSTAT
$ dt
0.1
*DATABASE_MATSUM
$ dt
0.1
*DATABASE_RCFORC
$ dt
0.1
$$$$ Boundary and Initial Conditions
...8
*INITIAL_DETONATION
$ pid x y z lt
2 0.00 0.00 0.00 0.00
$ pid = 2 Part ID of high explosive material to be lit.
$ x,y,z Coordinate of detonation point.
$ lt = 0 Lighting time.
$$$$ Define Parts and Materials
...8
$$$ Part 1 shell: sphere
$$$ Part 2 solid: high explosive
*PART
$ pid sid mid eosid hgid grav adpopt
sphere
1 1 1
high explosive
2 2 2 2
seams
3 1 3
$$$$ Materials
$ mid ro e pr sigy etan beta
1 7.874 2.07 0.28 0.15 0.136 0
$ src srp fs
40 5
3 7.874 2.07 0.28 0.15 0.136 0
$ src srp fs
40 5 0.2
*MAT_HIGH_EXPLOSIVE_BURN
...8
$ mid ro d pcj beta k g
sigy
2 1.717 0.798 0.290
$ mid = 2 Material ID
$ ro = 1.717 mass density
$ d = 0.798 detonation velocity
$ pcj = 0.290 Chapman-Jouget pressure
$$$$ Sections
*SECTION_SHELL
$ sid elform shrf nip propt qr/irid icomp
$ t1 t2 t3 t4 nloc
0.50 0.50 0.50 0.50
*SECTION_SOLID
$ sid elform
2 1
*EOS_JWL
$ eosid A B r1 r2 omeg Eo
Vo
2 5.2421999 0.07678 4.2000003 1.10 0.340 0.085
1.00
$ Defines the pressure in the solid elements as a function
$ of the relative volume and internal energy.
$ Eo = 0.085 initial internal energy
$ Vo = 1.000 initial relative volume
$ A, B, r1, r2, omeg = parameters of equation of state
$$$$ Contact
$ *CONTACT_SLIDING_ONLY - defined at end of model
$$$$ Define Nodes and Elements
...8
*NODE
$ nid x y z tc rc
1 -2.424870000000 -2.424870000000 -2.424870000000
2 -2.659010000000 -1.870640000000 -2.659010000000
3 -2.830330000000 -1.272200000000 -2.830330000000
4 -2.934760000000 -0.643710000000 -2.934760000000
5 -2.969850000000 0.0000000000000 -2.969850000000
6 -2.659010000000 -2.659010000000 -1.870640000000
7 -3.010530000000 -2.070830000000 -2.070830000000
8 -3.273510000000 -1.415450000000 -2.218250000000
9 -3.436020000000 -0.716170000000 -2.306710000000
10 -3.492170000000 0.0000000000000 -2.333400000000
11 -2.830330000000 -2.830330000000 -1.272200000000
12 -3.273510000000 -2.218250000000 -1.415450000000
13 -3.606620000000 -1.521890000000 -1.521890000000
14 -3.811670000000 -0.770820000000 -1.586510000000
15 -3.880290000000 0.0000000000000 -1.607270000000
16 -2.934760000000 -2.934760000000 -0.643710000000
17 -3.436020000000 -2.306710000000 -0.716170000000
18 -3.811670000000 -1.586510000000 -0.770820000000
19 -4.042560000000 -0.805530000000 -0.805530000000
20 -4.119300000000 0.0000000000000 -0.819380000000
21 -2.969850000000 -2.969850000000 0.0000000000000
22 -3.492170000000 -2.333400000000 0.0000000000000
23 -3.880290000000 -1.607270000000 0.0000000000000
24 -4.119300000000 -0.819380000000 0.0000000000000
25 -4.200000000000 0.0000000000000 0.0000000000000
26 -2.934760000000 -2.934760000000 0.6437100000000
27 -3.436020000000 -2.306710000000 0.7161700000000
28 -3.811670000000 -1.586510000000 0.7708200000000
29 -4.042560000000 -0.805530000000 0.8055300000000
30 -4.119300000000 0.0000000000000 0.8193800000000
31 -2.830330000000 -2.830330000000 1.2722000000000
32 -3.273510000000 -2.218250000000 1.4154500000000
33 -3.606620000000 -1.521890000000 1.5218900000000
34 -3.811670000000 -0.770820000000 1.5865100000000
35 -3.880290000000 0.0000000000000 1.6072700000000
36 -2.659010000000 -2.659010000000 1.8706400000000
37 -3.010530000000 -2.070830000000 2.0708300000000
38 -3.273510000000 -1.415450000000 2.2182500000000
39 -3.436020000000 -0.716170000000 2.3067100000000
40 -3.492170000000 0.0000000000000 2.3334000000000
41 -2.424870000000 -2.424870000000 2.4248700000000
42 -2.659010000000 -1.870640000000 2.6590100000000
43 -2.830330000000 -1.272200000000 2.8303300000000
44 -2.934760000000 -0.643710000000 2.9347600000000
45 -2.969850000000 0.0000000000000 2.9698500000000
46 -2.934760000000 0.6437100000000 -2.934760000000
47 -2.830330000000 1.2722000000000 -2.830330000000
48 -2.659010000000 1.8706400000000 -2.659010000000
49 -2.424870000000 2.4248700000000 -2.424870000000
50 -3.436020000000 0.7161700000000 -2.306710000000
51 -3.273510000000 1.4154500000000 -2.218250000000
52 -3.010530000000 2.0708300000000 -2.070830000000
53 -2.659010000000 2.6590100000000 -1.870640000000
54 -3.811670000000 0.7708200000000 -1.586510000000
55 -3.606620000000 1.5218900000000 -1.521890000000
56 -3.273510000000 2.2182500000000 -1.415450000000
57 -2.830330000000 2.8303300000000 -1.272200000000
58 -4.042560000000 0.8055300000000 -0.805530000000
59 -3.811670000000 1.5865100000000 -0.770820000000
60 -3.436020000000 2.3067100000000 -0.716170000000
61 -2.934760000000 2.9347600000000 -0.643710000000
62 -4.119300000000 0.8193800000000 0.0000000000000
63 -3.880290000000 1.6072700000000 0.0000000000000
64 -3.492170000000 2.3334000000000 0.0000000000000
65 -2.969850000000 2.9698500000000 0.0000000000000
66 -4.042560000000 0.8055300000000 0.8055300000000
67 -3.811670000000 1.5865100000000 0.7708200000000
68 -3.436020000000 2.3067100000000 0.7161700000000
69 -2.934760000000 2.9347600000000 0.6437100000000
70 -3.811670000000 0.7708200000000 1.5865100000000
71 -3.606620000000 1.5218900000000 1.5218900000000
72 -3.273510000000 2.2182500000000 1.4154500000000
73 -2.830330000000 2.8303300000000 1.2722000000000
74 -3.436020000000 0.7161700000000 2.3067100000000
75 -3.273510000000 1.4154500000000 2.2182500000000
76 -3.010530000000 2.0708300000000 2.0708300000000
77 -2.659010000000 2.6590100000000 1.8706400000000
78 -2.934760000000 0.6437100000000 2.9347600000000
79 -2.830330000000 1.2722000000000 2.8303300000000
80 -2.659010000000 1.8706400000000 2.6590100000000
81 -2.424870000000 2.4248700000000 2.4248700000000
82 -1.870640000000 -2.659010000000 -2.659010000000
83 -1.272200000000 -2.830330000000 -2.830330000000
84 -0.643710000000 -2.934760000000 -2.934760000000
85 0.0000000000000 -2.969850000000 -2.969850000000
86 -2.070830000000 -3.010530000000 -2.070830000000
87 -1.415450000000 -3.273510000000 -2.218250000000
88 -0.716170000000 -3.436020000000 -2.306710000000
89 0.0000000000000 -3.492170000000 -2.333400000000
90 -2.218250000000 -3.273510000000 -1.415450000000
91 -1.521890000000 -3.606620000000 -1.521890000000
92 -0.770820000000 -3.811670000000 -1.586510000000
93 0.0000000000000 -3.880290000000 -1.607270000000
94 -2.306710000000 -3.436020000000 -0.716170000000
95 -1.586510000000 -3.811670000000 -0.770820000000
96 -0.805530000000 -4.042560000000 -0.805530000000
97 0.0000000000000 -4.119300000000 -0.819380000000
98 -2.333400000000 -3.492170000000 0.0000000000000
99 -1.607270000000 -3.880290000000 0.0000000000000
100 -0.819380000000 -4.119300000000 0.0000000000000
101 0.0000000000000 -4.200000000000 0.0000000000000
102 -2.306710000000 -3.436020000000 0.7161700000000
103 -1.586510000000 -3.811670000000 0.7708200000000
104 -0.805530000000 -4.042560000000 0.8055300000000
105 0.0000000000000 -4.119300000000 0.8193800000000
106 -2.218250000000 -3.273510000000 1.4154500000000
107 -1.521890000000 -3.606620000000 1.5218900000000
108 -0.770820000000 -3.811670000000 1.5865100000000
109 0.0000000000000 -3.880290000000 1.6072700000000
110 -2.070830000000 -3.010530000000 2.0708300000000
111 -1.415450000000 -3.273510000000 2.2182500000000
112 -0.716170000000 -3.436020000000 2.3067100000000
113 0.0000000000000 -3.492170000000 2.3334000000000
114 -1.870640000000 -2.659010000000 2.6590100000000
115 -1.272200000000 -2.830330000000 2.8303300000000
116 -0.643710000000 -2.934760000000 2.9347600000000
117 0.0000000000000 -2.969850000000 2.9698500000000
118 -2.070830000000 -2.070830000000 -3.010530000000
119 -1.415450000000 -2.218250000000 -3.273510000000
120 -0.716170000000 -2.306710000000 -3.436020000000
121 0.0000000000000 -2.333400000000 -3.492170000000
122 -2.218250000000 -1.415450000000 -3.273510000000
123 -1.521890000000 -1.521890000000 -3.606620000000
124 -0.770820000000 -1.586510000000 -3.811670000000
125 0.0000000000000 -1.607270000000 -3.880290000000
126 -2.306710000000 -0.716170000000 -3.436020000000
127 -1.586510000000 -0.770820000000 -3.811670000000
128 -0.805530000000 -0.805530000000 -4.042560000000
129 0.0000000000000 -0.819380000000 -4.119300000000
130 -2.333400000000 0.0000000000000 -3.492170000000
131 -1.607270000000 0.0000000000000 -3.880290000000
132 -0.819380000000 0.0000000000000 -4.119300000000
133 0.0000000000000 0.0000000000000 -4.200000000000
134 -2.070830000000 -2.070830000000 3.0105300000000
135 -1.415450000000 -2.218250000000 3.2735100000000
136 -0.716170000000 -2.306710000000 3.4360200000000
137 0.0000000000000 -2.333400000000 3.4921700000000
138 -2.218250000000 -1.415450000000 3.2735100000000
139 -1.521890000000 -1.521890000000 3.6066200000000
140 -0.770820000000 -1.586510000000 3.8116700000000
141 0.0000000000000 -1.607270000000 3.8802900000000
142 -2.306710000000 -0.716170000000 3.4360200000000
143 -1.586510000000 -0.770820000000 3.8116700000000
144 -0.805530000000 -0.805530000000 4.0425600000000
145 0.0000000000000 -0.819380000000 4.1193000000000
146 -2.333400000000 0.0000000000000 3.4921700000000
147 -1.607270000000 0.0000000000000 3.8802900000000
148 -0.819380000000 0.0000000000000 4.1193000000000
149 0.0000000000000 0.0000000000000 4.2000000000000
150 -2.306710000000 0.7161700000000 -3.436020000000
151 -1.586510000000 0.7708200000000 -3.811670000000
152 -0.805530000000 0.8055300000000 -4.042560000000
153 0.0000000000000 0.8193800000000 -4.119300000000
154 -2.218250000000 1.4154500000000 -3.273510000000
155 -1.521890000000 1.5218900000000 -3.606620000000 156 -0.770820000000 1.5865100000000 -3.811670000000
157 0.0000000000000 1.6072700000000 -3.880290000000
158 -2.070830000000 2.0708300000000 -3.010530000000
159 -1.415450000000 2.2182500000000 -3.273510000000
160 -0.716170000000 2.3067100000000 -3.436020000000
161 0.0000000000000 2.3334000000000 -3.492170000000
162 -1.870640000000 2.6590100000000 -2.659010000000
163 -1.272200000000 2.8303300000000 -2.830330000000
164 -0.643710000000 2.9347600000000 -2.934760000000
165 0.0000000000000 2.9698500000000 -2.969850000000
166 -2.306710000000 0.7161700000000 3.4360200000000
167 -1.586510000000 0.7708200000000 3.8116700000000
168 -0.805530000000 0.8055300000000 4.0425600000000
169 0.0000000000000 0.8193800000000 4.1193000000000
170 -2.218250000000 1.4154500000000 3.2735100000000
171 -1.521890000000 1.5218900000000 3.6066200000000
172 -0.770820000000 1.5865100000000 3.8116700000000
173 0.0000000000000 1.6072700000000 3.8802900000000
174 -2.070830000000 2.0708300000000 3.0105300000000
175 -1.415450000000 2.2182500000000 3.2735100000000
176 -0.716170000000 2.3067100000000 3.4360200000000
177 0.0000000000000 2.3334000000000 3.4921700000000
178 -1.870640000000 2.6590100000000 2.6590100000000
179 -1.272200000000 2.8303300000000 2.8303300000000
180 -0.643710000000 2.9347600000000 2.9347600000000
181 0.0000000000000 2.9698500000000 2.9698500000000
182 -2.070830000000 3.0105300000000 -2.070830000000
183 -1.415450000000 3.2735100000000 -2.218250000000
184 -0.716170000000 3.4360200000000 -2.306710000000
185 0.0000000000000 3.4921700000000 -2.333400000000
186 -2.218250000000 3.2735100000000 -1.415450000000
187 -1.521890000000 3.6066200000000 -1.521890000000
188 -0.770820000000 3.8116700000000 -1.586510000000
189 0.0000000000000 3.8802900000000 -1.607270000000
190 -2.306710000000 3.4360200000000 -0.716170000000
191 -1.586510000000 3.8116700000000 -0.770820000000
192 -0.805530000000 4.0425600000000 -0.805530000000
193 0.0000000000000 4.1193000000000 -0.819380000000
194 -2.333400000000 3.4921700000000 0.0000000000000
195 -1.607270000000 3.8802900000000 0.0000000000000
196 -0.819380000000 4.1193000000000 0.0000000000000
197 0.0000000000000 4.2000000000000 0.0000000000000
198 -2.306710000000 3.4360200000000 0.7161700000000
199 -1.586510000000 3.8116700000000 0.7708200000000
200 -0.805530000000 4.0425600000000 0.8055300000000
201 0.0000000000000 4.1193000000000 0.8193800000000
202 -2.218250000000 3.2735100000000 1.4154500000000
203 -1.521890000000 3.6066200000000 1.5218900000000
204 -0.770820000000 3.8116700000000 1.5865100000000
205 0.0000000000000 3.8802900000000 1.6072700000000
206 -2.070830000000 3.0105300000000 2.0708300000000
207 -1.415450000000 3.2735100000000 2.2182500000000
208 -0.716170000000 3.4360200000000 2.3067100000000
209 0.0000000000000 3.4921700000000 2.3334000000000
210 0.6437100000000 -2.934760000000 -2.934760000000
211 1.2722000000000 -2.830330000000 -2.830330000000
212 1.8706400000000 -2.659010000000 -2.659010000000
213 2.4248700000000 -2.424870000000 -2.424870000000
214 0.7161700000000 -3.436020000000 -2.306710000000
215 1.4154500000000 -3.273510000000 -2.218250000000
216 2.0708300000000 -3.010530000000 -2.070830000000
217 2.6590100000000 -2.659010000000 -1.870640000000
218 0.7708200000000 -3.811670000000 -1.586510000000
219 1.5218900000000 -3.606620000000 -1.521890000000
220 2.2182500000000 -3.273510000000 -1.415450000000
221 2.8303300000000 -2.830330000000 -1.272200000000
222 0.8055300000000 -4.042560000000 -0.805530000000
223 1.5865100000000 -3.811670000000 -0.770820000000
224 2.3067100000000 -3.436020000000 -0.716170000000
225 2.9347600000000 -2.934760000000 -0.643710000000
226 0.8193800000000 -4.119300000000 0.0000000000000
227 1.6072700000000 -3.880290000000 0.0000000000000
228 2.3334000000000 -3.492170000000 0.0000000000000
229 2.9698500000000 -2.969850000000 0.0000000000000
230 0.8055300000000 -4.042560000000 0.8055300000000
231 1.5865100000000 -3.811670000000 0.7708200000000
232 2.3067100000000 -3.436020000000 0.7161700000000
233 2.9347600000000 -2.934760000000 0.6437100000000
234 0.7708200000000 -3.811670000000 1.5865100000000
235 1.5218900000000 -3.606620000000 1.5218900000000
236 2.2182500000000 -3.273510000000 1.4154500000000
237 2.8303300000000 -2.830330000000 1.2722000000000
238 0.7161700000000 -3.436020000000 2.3067100000000
239 1.4154500000000 -3.273510000000 2.2182500000000
240 2.0708300000000 -3.010530000000 2.0708300000000
241 2.6590100000000 -2.659010000000 1.8706400000000
242 0.6437100000000 -2.934760000000 2.9347600000000
243 1.2722000000000 -2.830330000000 2.8303300000000
244 1.8706400000000 -2.659010000000 2.6590100000000
245 2.4248700000000 -2.424870000000 2.4248700000000
246 0.7161700000000 -2.306710000000 -3.436020000000
247 1.4154500000000 -2.218250000000 -3.273510000000
248 2.0708300000000 -2.070830000000 -3.010530000000
249 2.6590100000000 -1.870640000000 -2.659010000000
250 0.7708200000000 -1.586510000000 -3.811670000000
251 1.5218900000000 -1.521890000000 -3.606620000000
252 2.2182500000000 -1.415450000000 -3.273510000000
253 2.8303300000000 -1.272200000000 -2.830330000000
254 0.8055300000000 -0.805530000000 -4.042560000000
255 1.5865100000000 -0.770820000000 -3.811670000000
256 2.3067100000000 -0.716170000000 -3.436020000000
257 2.9347600000000 -0.643710000000 -2.934760000000
258 0.8193800000000 0.0000000000000 -4.119300000000
259 1.6072700000000 0.0000000000000 -3.880290000000
260 2.3334000000000 0.0000000000000 -3.492170000000
261 2.9698500000000 0.0000000000000 -2.969850000000
262 0.7161700000000 -2.306710000000 3.4360200000000
263 1.4154500000000 -2.218250000000 3.2735100000000
264 2.0708300000000 -2.070830000000 3.0105300000000
265 2.6590100000000 -1.870640000000 2.6590100000000
266 0.7708200000000 -1.586510000000 3.8116700000000
267 1.5218900000000 -1.521890000000 3.6066200000000
268 2.2182500000000 -1.415450000000 3.2735100000000
269 2.8303300000000 -1.272200000000 2.8303300000000
270 0.8055300000000 -0.805530000000 4.0425600000000
271 1.5865100000000 -0.770820000000 3.8116700000000
272 2.3067100000000 -0.716170000000 3.4360200000000
273 2.9347600000000 -0.643710000000 2.9347600000000
274 0.8193800000000 0.0000000000000 4.1193000000000
275 1.6072700000000 0.0000000000000 3.8802900000000
276 2.3334000000000 0.0000000000000 3.4921700000000
277 2.9698500000000 0.0000000000000 2.9698500000000
278 0.8055300000000 0.8055300000000 -4.042560000000
279 1.5865100000000 0.7708200000000 -3.811670000000
280 2.3067100000000 0.7161700000000 -3.436020000000
281 2.9347600000000 0.6437100000000 -2.934760000000
282 0.7708200000000 1.5865100000000 -3.811670000000
283 1.5218900000000 1.5218900000000 -3.606620000000
284 2.2182500000000 1.4154500000000 -3.273510000000
285 2.8303300000000 1.2722000000000 -2.830330000000
286 0.7161700000000 2.3067100000000 -3.436020000000
287 1.4154500000000 2.2182500000000 -3.273510000000
288 2.0708300000000 2.0708300000000 -3.010530000000
289 2.6590100000000 1.8706400000000 -2.659010000000
290 0.6437100000000 2.9347600000000 -2.934760000000
291 1.2722000000000 2.8303300000000 -2.830330000000
292 1.8706400000000 2.6590100000000 -2.659010000000
293 2.4248700000000 2.4248700000000 -2.424870000000
294 0.8055300000000 0.8055300000000 4.0425600000000
295 1.5865100000000 0.7708200000000 3.8116700000000
296 2.3067100000000 0.7161700000000 3.4360200000000
297 2.9347600000000 0.6437100000000 2.9347600000000
298 0.7708200000000 1.5865100000000 3.8116700000000
299 1.5218900000000 1.5218900000000 3.6066200000000
300 2.2182500000000 1.4154500000000 3.2735100000000
301 2.8303300000000 1.2722000000000 2.8303300000000
302 0.7161700000000 2.3067100000000 3.4360200000000
303 1.4154500000000 2.2182500000000 3.2735100000000
304 2.0708300000000 2.0708300000000 3.0105300000000
305 2.6590100000000 1.8706400000000 2.6590100000000
306 0.6437100000000 2.9347600000000 2.9347600000000
307 1.2722000000000 2.8303300000000 2.8303300000000
308 1.8706400000000 2.6590100000000 2.6590100000000
309 2.4248700000000 2.4248700000000 2.4248700000000
310 0.7161700000000 3.4360200000000 -2.306710000000
311 1.4154500000000 3.2735100000000 -2.218250000000
312 2.0708300000000 3.0105300000000 -2.070830000000
313 2.6590100000000 2.6590100000000 -1.870640000000
314 0.7708200000000 3.8116700000000 -1.586510000000
315 1.5218900000000 3.6066200000000 -1.521890000000
316 2.2182500000000 3.2735100000000 -1.415450000000
317 2.8303300000000 2.8303300000000 -1.272200000000
318 0.8055300000000 4.0425600000000 -0.805530000000
319 1.5865100000000 3.8116700000000 -0.770820000000
320 2.3067100000000 3.4360200000000 -0.716170000000
321 2.9347600000000 2.9347600000000 -0.643710000000
322 0.8193800000000 4.1193000000000 0.0000000000000
323 1.6072700000000 3.8802900000000 0.0000000000000
324 2.3334000000000 3.4921700000000 0.0000000000000
325 2.9698500000000 2.9698500000000 0.0000000000000
326 0.8055300000000 4.0425600000000 0.8055300000000
327 1.5865100000000 3.8116700000000 0.7708200000000
328 2.3067100000000 3.4360200000000 0.7161700000000
329 2.9347600000000 2.9347600000000 0.6437100000000
330 0.7708200000000 3.8116700000000 1.5865100000000
331 1.5218900000000 3.6066200000000 1.5218900000000
332 2.2182500000000 3.2735100000000 1.4154500000000
333 2.8303300000000 2.8303300000000 1.2722000000000
334 0.7161700000000 3.4360200000000 2.3067100000000
335 1.4154500000000 3.2735100000000 2.2182500000000
336 2.0708300000000 3.0105300000000 2.0708300000000
337 2.6590100000000 2.6590100000000 1.8706400000000
338 3.0105300000000 -2.070830000000 -2.070830000000
339 3.2735100000000 -1.415450000000 -2.218250000000
340 3.4360200000000 -0.716170000000 -2.306710000000
341 3.4921700000000 0.0000000000000 -2.333400000000
342 3.2735100000000 -2.218250000000 -1.415450000000
343 3.6066200000000 -1.521890000000 -1.521890000000
344 3.8116700000000 -0.770820000000 -1.586510000000
345 3.8802900000000 0.0000000000000 -1.607270000000
346 3.4360200000000 -2.306710000000 -0.716170000000
347 3.8116700000000 -1.586510000000 -0.770820000000
348 4.0425600000000 -0.805530000000 -0.805530000000
349 4.1193000000000 0.0000000000000 -0.819380000000
350 3.4921700000000 -2.333400000000 0.0000000000000
351 3.8802900000000 -1.607270000000 0.0000000000000
352 4.1193000000000 -0.819380000000 0.0000000000000
353 4.2000000000000 0.0000000000000 0.0000000000000
354 3.4360200000000 -2.306710000000 0.7161700000000
355 3.8116700000000 -1.586510000000 0.7708200000000
356 4.0425600000000 -0.805530000000 0.8055300000000
357 4.1193000000000 0.0000000000000 0.8193800000000
358 3.2735100000000 -2.218250000000 1.4154500000000
359 3.6066200000000 -1.521890000000 1.5218900000000
360 3.8116700000000 -0.770820000000 1.5865100000000
361 3.8802900000000 0.0000000000000 1.6072700000000
362 3.0105300000000 -2.070830000000 2.0708300000000
363 3.2735100000000 -1.415450000000 2.2182500000000
364 3.4360200000000 -0.716170000000 2.3067100000000
365 3.4921700000000 0.0000000000000 2.3334000000000
366 3.4360200000000 0.7161700000000 -2.306710000000
367 3.2735100000000 1.4154500000000 -2.218250000000
368 3.0105300000000 2.0708300000000 -2.070830000000
369 3.8116700000000 0.7708200000000 -1.586510000000
370 3.6066200000000 1.5218900000000 -1.521890000000
371 3.2735100000000 2.2182500000000 -1.415450000000
372 4.0425600000000 0.8055300000000 -0.805530000000
373 3.8116700000000 1.5865100000000 -0.770820000000
374 3.4360200000000 2.3067100000000 -0.716170000000
375 4.1193000000000 0.8193800000000 0.000000000000 376 3.8802900000000 1.6072700000000 0.0000000000000
377 3.4921700000000 2.3334000000000 0.0000000000000
378 4.0425600000000 0.8055300000000 0.8055300000000
379 3.8116700000000 1.5865100000000 0.7708200000000
380 3.4360200000000 2.3067100000000 0.7161700000000
381 3.8116700000000 0.7708200000000 1.5865100000000
382 3.6066200000000 1.5218900000000 1.5218900000000
383 3.2735100000000 2.2182500000000 1.4154500000000
384 3.4360200000000 0.7161700000000 2.3067100000000
385 3.2735100000000 1.4154500000000 2.2182500000000
386 3.0105300000000 2.0708300000000 2.0708300000000
387 -2.182383000000 -2.182383000000 -2.182383000000
388 -1.818657000000 -1.818657000000 -1.818657000000
389 -1.454922000000 -1.454922000000 -1.454922000000
390 -2.393109000000 -1.683576000000 -2.393109000000
391 -1.964889000000 -1.387386000000 -1.964889000000
392 -1.536669000000 -1.091196000000 -1.536669000000
393 -2.547297000000 -1.144980000000 -2.547297000000
394 -2.082852000000 -0.936225000000 -2.082852000000
395 -1.618416000000 -0.727461000000 -1.618416000000
396 -2.641284000000 -0.579339000000 -2.641284000000
397 -2.170728000000 -0.471537000000 -2.170728000000
398 -1.700163000000 -0.363735000000 -1.700163000000
399 -2.672865000000 0.0000000000000 -2.672865000000
400 -2.227383000000 0.0000000000000 -2.227383000000
401 -1.781910000000 0.0000000000000 -1.781910000000
402 -2.393109000000 -2.393109000000 -1.683576000000
403 -1.964889000000 -1.964889000000 -1.387386000000
404 -1.536669000000 -1.536669000000 -1.091196000000
405 -2.709477000000 -1.863747000000 -1.863747000000
406 -2.176794000000 -1.508130000000 -1.508130000000
407 -1.644111000000 -1.152504000000 -1.152504000000
408 -2.946159000000 -1.273905000000 -1.996425000000
409 -2.348856000000 -1.021122000000 -1.605114000000
410 -1.751553000000 -0.768339000000 -1.213812000000
411 -3.092418000000 -0.644553000000 -2.076039000000
412 -2.475702000000 -0.514359000000 -1.675575000000
413 -1.858995000000 -0.384165000000 -1.275120000000
414 -3.142953000000 0.0000000000000 -2.100060000000
415 -2.554695000000 0.0000000000000 -1.718244000000
416 -1.966428000000 0.0000000000000 -1.336428000000
417 -2.547297000000 -2.547297000000 -1.144980000000
418 -2.082852000000 -2.082852000000 -0.936225000000
419 -1.618416000000 -1.618416000000 -0.727461000000
420 -2.946159000000 -1.996425000000 -1.273905000000
421 -2.348856000000 -1.605114000000 -1.021122000000
422 -1.751553000000 -1.213812000000 -0.768339000000
423 -3.245958000000 -1.369701000000 -1.369701000000
424 -2.565324000000 -1.089459000000 -1.089459000000
425 -1.884681000000 -0.809208000000 -0.809208000000
426 -3.430503000000 -0.693738000000 -1.427859000000
427 -2.724156000000 -0.549171000000 -1.138968000000
428 -2.017818000000 -0.404604000000 -0.850077000000
429 -3.492261000000 0.0000000000000 -1.446543000000
430 -2.821608000000 0.0000000000000 -1.168749000000
431 -2.150955000000 0.0000000000000 -0.890955000000
432 -2.641284000000 -2.641284000000 -0.579339000000
433 -2.170728000000 -2.170728000000 -0.471537000000
434 -1.700163000000 -1.700163000000 -0.363735000000
435 -3.092418000000 -2.076039000000 -0.644553000000
436 -2.475702000000 -1.675575000000 -0.514359000000
437 -1.858995000000 -1.275120000000 -0.384165000000
438 -3.430503000000 -1.427859000000 -0.693738000000
439 -2.724156000000 -1.138968000000 -0.549171000000
440 -2.017818000000 -0.850077000000 -0.404604000000
441 -3.638304000000 -0.724977000000 -0.724977000000
442 -2.907477000000 -0.575010000000 -0.575010000000
443 -2.176650000000 -0.425043000000 -0.425043000000
444 -3.707370000000 0.0000000000000 -0.737442000000
445 -3.021426000000 0.0000000000000 -0.591462000000
446 -2.335473000000 0.0000000000000 -0.445473000000
447 -2.672865000000 -2.672865000000 0.0000000000000
448 -2.227383000000 -2.227383000000 0.0000000000000
449 -1.781910000000 -1.781910000000 0.0000000000000
450 -3.142953000000 -2.100060000000 0.0000000000000
451 -2.554695000000 -1.718244000000 0.0000000000000
452 -1.966428000000 -1.336428000000 0.0000000000000
453 -3.492261000000 -1.446543000000 0.0000000000000
454 -2.821608000000 -1.168749000000 0.0000000000000
455 -2.150955000000 -0.890955000000 0.0000000000000
456 -3.707370000000 -0.737442000000 0.0000000000000
457 -3.021426000000 -0.591462000000 0.0000000000000
458 -2.335473000000 -0.445473000000 0.0000000000000
459 -3.780000000000 0.0000000000000 0.0000000000000
460 -3.150000000000 0.0000000000000 0.0000000000000
461 -2.520000000000 0.0000000000000 0.0000000000000
462 -2.641284000000 -2.641284000000 0.5793390000000
463 -2.170728000000 -2.170728000000 0.4715370000000
464 -1.700163000000 -1.700163000000 0.3637350000000
465 -3.092418000000 -2.076039000000 0.6445530000000
466 -2.475702000000 -1.675575000000 0.5143590000000
467 -1.858995000000 -1.275120000000 0.3841650000000
468 -3.430503000000 -1.427859000000 0.6937380000000
469 -2.724156000000 -1.138968000000 0.5491710000000
470 -2.017818000000 -0.850077000000 0.4046040000000
471 -3.638304000000 -0.724977000000 0.7249770000000
472 -2.907477000000 -0.575010000000 0.5750100000000
473 -2.176650000000 -0.425043000000 0.4250430000000
474 -3.707370000000 0.0000000000000 0.7374420000000
475 -3.021426000000 0.0000000000000 0.5914620000000
476 -2.335473000000 0.0000000000000 0.4454730000000
477 -2.547297000000 -2.547297000000 1.1449800000000
478 -2.082852000000 -2.082852000000 0.9362250000000
479 -1.618416000000 -1.618416000000 0.7274610000000
480 -2.946159000000 -1.996425000000 1.2739050000000
481 -2.348856000000 -1.605114000000 1.0211220000000
482 -1.751553000000 -1.213812000000 0.7683390000000
483 -3.245958000000 -1.369701000000 1.3697010000000
484 -2.565324000000 -1.089459000000 1.0894590000000
485 -1.884681000000 -0.809208000000 0.8092080000000
486 -3.430503000000 -0.693738000000 1.4278590000000
487 -2.724156000000 -0.549171000000 1.1389680000000
488 -2.017818000000 -0.404604000000 0.8500770000000
489 -3.492261000000 0.0000000000000 1.4465430000000
490 -2.821608000000 0.0000000000000 1.1687490000000
491 -2.150955000000 0.0000000000000 0.8909550000000
492 -2.393109000000 -2.393109000000 1.6835760000000
493 -1.964889000000 -1.964889000000 1.3873860000000
494 -1.536669000000 -1.536669000000 1.0911960000000
495 -2.709477000000 -1.863747000000 1.8637470000000
496 -2.176794000000 -1.508130000000 1.5081300000000
497 -1.644111000000 -1.152504000000 1.1525040000000
498 -2.946159000000 -1.273905000000 1.9964250000000
499 -2.348856000000 -1.021122000000 1.6051140000000
500 -1.751553000000 -0.768339000000 1.2138120000000
501 -3.092418000000 -0.644553000000 2.0760390000000
502 -2.475702000000 -0.514359000000 1.6755750000000
503 -1.858995000000 -0.384165000000 1.2751200000000
504 -3.142953000000 0.0000000000000 2.1000600000000
505 -2.554695000000 0.0000000000000 1.7182440000000
506 -1.966428000000 0.0000000000000 1.3364280000000
507 -2.182383000000 -2.182383000000 2.1823830000000
508 -1.818657000000 -1.818657000000 1.8186570000000
509 -1.454922000000 -1.454922000000 1.4549220000000
510 -2.393109000000 -1.683576000000 2.3931090000000
511 -1.964889000000 -1.387386000000 1.9648890000000
512 -1.536669000000 -1.091196000000 1.5366690000000
513 -2.547297000000 -1.144980000000 2.5472970000000
514 -2.082852000000 -0.936225000000 2.0828520000000
515 -1.618416000000 -0.727461000000 1.6184160000000
516 -2.641284000000 -0.579339000000 2.6412840000000
517 -2.170728000000 -0.471537000000 2.1707280000000
518 -1.700163000000 -0.363735000000 1.7001630000000
519 -2.672865000000 0.0000000000000 2.6728650000000
520 -2.227383000000 0.0000000000000 2.2273830000000
521 -1.781910000000 0.0000000000000 1.7819100000000
522 -2.641284000000 0.5793390000000 -2.641284000000
523 -2.170728000000 0.4715370000000 -2.170728000000
524 -1.700163000000 0.3637350000000 -1.700163000000
525 -2.547297000000 1.1449800000000 -2.547297000000
526 -2.082852000000 0.9362250000000 -2.082852000000
527 -1.618416000000 0.7274610000000 -1.618416000000
528 -2.393109000000 1.6835760000000 -2.393109000000
529 -1.964889000000 1.3873860000000 -1.964889000000
530 -1.536669000000 1.0911960000000 -1.536669000000
531 -2.182383000000 2.1823830000000 -2.182383000000
532 -1.818657000000 1.8186570000000 -1.818657000000
533 -1.454922000000 1.4549220000000 -1.454922000000
534 -3.092418000000 0.6445530000000 -2.076039000000
535 -2.475702000000 0.5143590000000 -1.675575000000
536 -1.858995000000 0.3841650000000 -1.275120000000
537 -2.946159000000 1.2739050000000 -1.996425000000
538 -2.348856000000 1.0211220000000 -1.605114000000
539 -1.751553000000 0.7683390000000 -1.213812000000
540 -2.709477000000 1.8637470000000 -1.863747000000
541 -2.176794000000 1.5081300000000 -1.508130000000
542 -1.644111000000 1.1525040000000 -1.152504000000
543 -2.393109000000 2.3931090000000 -1.683576000000
544 -1.964889000000 1.9648890000000 -1.387386000000
545 -1.536669000000 1.5366690000000 -1.091196000000
546 -3.430503000000 0.6937380000000 -1.427859000000
547 -2.724156000000 0.5491710000000 -1.138968000000
548 -2.017818000000 0.4046040000000 -0.850077000000
549 -3.245958000000 1.3697010000000 -1.369701000000
550 -2.565324000000 1.0894590000000 -1.089459000000
551 -1.884681000000 0.8092080000000 -0.809208000000
552 -2.946159000000 1.9964250000000 -1.273905000000
553 -2.348856000000 1.6051140000000 -1.021122000000
554 -1.751553000000 1.2138120000000 -0.768339000000
555 -2.547297000000 2.5472970000000 -1.144980000000
556 -2.082852000000 2.0828520000000 -0.936225000000
557 -1.618416000000 1.6184160000000 -0.727461000000
558 -3.638304000000 0.7249770000000 -0.724977000000
559 -2.907477000000 0.5750100000000 -0.575010000000
560 -2.176650000000 0.4250430000000 -0.425043000000
561 -3.430503000000 1.4278590000000 -0.693738000000
562 -2.724156000000 1.1389680000000 -0.549171000000
563 -2.017818000000 0.8500770000000 -0.404604000000
564 -3.092418000000 2.0760390000000 -0.644553000000
565 -2.475702000000 1.6755750000000 -0.514359000000
566 -1.858995000000 1.2751200000000 -0.384165000000
567 -2.641284000000 2.6412840000000 -0.579339000000
568 -2.170728000000 2.1707280000000 -0.471537000000
569 -1.700163000000 1.7001630000000 -0.363735000000
570 -3.707370000000 0.7374420000000 0.0000000000000
571 -3.021426000000 0.5914620000000 0.0000000000000
572 -2.335473000000 0.4454730000000 0.0000000000000
573 -3.492261000000 1.4465430000000 0.0000000000000
574 -2.821608000000 1.1687490000000 0.0000000000000
575 -2.150955000000 0.8909550000000 0.0000000000000
576 -3.142953000000 2.1000600000000 0.0000000000000
577 -2.554695000000 1.7182440000000 0.0000000000000
578 -1.966428000000 1.3364280000000 0.0000000000000
579 -2.672865000000 2.6728650000000 0.0000000000000
580 -2.227383000000 2.2273830000000 0.0000000000000
581 -1.781910000000 1.7819100000000 0.0000000000000
582 -3.638304000000 0.7249770000000 0.7249770000000
583 -2.907477000000 0.5750100000000 0.5750100000000
584 -2.176650000000 0.4250430000000 0.4250430000000
585 -3.430503000000 1.4278590000000 0.6937380000000
586 -2.724156000000 1.1389680000000 0.5491710000000
587 -2.017818000000 0.8500770000000 0.4046040000000
588 -3.092418000000 2.0760390000000 0.6445530000000
589 -2.475702000000 1.6755750000000 0.5143590000000
590 -1.858995000000 1.2751200000000 0.3841650000000
591 -2.641284000000 2.6412840000000 0.5793390000000
592 -2.170728000000 2.1707280000000 0.4715370000000
593 -1.700163000000 1.7001630000000 0.3637350000000
594 -3.430503000000 0.6937380000000 1.4278590000000
595 -2.724156000000 0.5491710000000 1.1389680000000
596 -2.017818000000 0.4046040000000 0.8500770000000
597 -3.245958000000 1.3697010000000 1.3697010000000
598 -2.565324000000 1.0894590000000 1.0894590000000
599 -1.884681000000 0.8092080000000 0.8092080000000
600 -2.946159000000 1.9964250000000 1.2739050000000
601 -2.348856000000 1.6051140000000 1.0211220000000
602 -1.751553000000 1.2138120000000 0.7683390000000
603 -2.547297000000 2.5472970000000 1.1449800000000
604 -2.082852000000 2.0828520000000 0.9362250000000
605 -1.618416000000 1.6184160000000 0.7274610000000
606 -3.092418000000 0.6445530000000 2.0760390000000
607 -2.475702000000 0.5143590000000 1.6755750000000
608 -1.858995000000 0.3841650000000 1.2751200000000
609 -2.946159000000 1.2739050000000 1.9964250000000
610 -2.348856000000 1.0211220000000 1.6051140000000
611 -1.751553000000 0.7683390000000 1.2138120000000
612 -2.709477000000 1.8637470000000 1.8637470000000
613 -2.176794000000 1.5081300000000 1.5081300000000
614 -1.644111000000 1.1525040000000 1.1525040000000
615 -2.393109000000 2.3931090000000 1.6835760000000
616 -1.964889000000 1.9648890000000 1.3873860000000
617 -1.536669000000 1.5366690000000 1.0911960000000
618 -2.641284000000 0.5793390000000 2.6412840000000
619 -2.170728000000 0.4715370000000 2.1707280000000
620 -1.700163000000 0.3637350000000 1.7001630000000
621 -2.547297000000 1.1449800000000 2.5472970000000
622 -2.082852000000 0.9362250000000 2.0828520000000
623 -1.618416000000 0.7274610000000 1.6184160000000
624 -2.393109000000 1.6835760000000 2.3931090000000
625 -1.964889000000 1.3873860000000 1.9648890000000
626 -1.536669000000 1.0911960000000 1.5366690000000
627 -2.182383000000 2.1823830000000 2.1823830000000
628 -1.818657000000 1.8186570000000 1.8186570000000
629 -1.454922000000 1.4549220000000 1.4549220000000
630 -1.683576000000 -2.393109000000 -2.393109000000
631 -1.144980000000 -2.547297000000 -2.547297000000
632 -0.579339000000 -2.641284000000 -2.641284000000
633 0.0000000000000 -2.672865000000 -2.672865000000
634 -1.387386000000 -1.964889000000 -1.964889000000
635 -0.936225000000 -2.082852000000 -2.082852000000
636 -0.471537000000 -2.170728000000 -2.170728000000
637 0.0000000000000 -2.227383000000 -2.227383000000
638 -1.091196000000 -1.536669000000 -1.536669000000
639 -0.727461000000 -1.618416000000 -1.618416000000
640 -0.363735000000 -1.700163000000 -1.700163000000
641 0.0000000000000 -1.781910000000 -1.781910000000
642 -1.863747000000 -2.709477000000 -1.863747000000
643 -1.273905000000 -2.946159000000 -1.996425000000
644 -0.644553000000 -3.092418000000 -2.076039000000
645 0.0000000000000 -3.142953000000 -2.100060000000
646 -1.508130000000 -2.176794000000 -1.508130000000
647 -1.021122000000 -2.348856000000 -1.605114000000
648 -0.514359000000 -2.475702000000 -1.675575000000
649 0.0000000000000 -2.554695000000 -1.718244000000
650 -1.152504000000 -1.644111000000 -1.152504000000
651 -0.768339000000 -1.751553000000 -1.213812000000
652 -0.384165000000 -1.858995000000 -1.275120000000
653 0.0000000000000 -1.966428000000 -1.336428000000
654 -1.996425000000 -2.946159000000 -1.273905000000
655 -1.369701000000 -3.245958000000 -1.369701000000
656 -0.693738000000 -3.430503000000 -1.427859000000
657 0.0000000000000 -3.492261000000 -1.446543000000
658 -1.605114000000 -2.348856000000 |
