查看: 569|回复: 9
[航空航天] abaqus6.12 新性能
发表于 2012-5-16 14:19:28 | 显示全部楼层 |阅读模式 来自 辽宁沈阳
Abaqus 6.12 delivers on SIMULIA's strategic commitment to provide scalable, high-quality realistic simulation solutions with new capabilities and more than 100 customer-requested enhancements. SIMULIA customers in a wide range of industries — including aerospace, automotive, consumer packaged goods, energy and life sciences — are using Abaqus to explore the real-world physical behavior of products and materials, in order to improve performance, reliability and safety, while reducing development time and costs.
Magnetostatic Response: Magnetostatic analysis support to compute the magnetic field due to a known distribution of direct current. This capability can be used to model common electric devices such as magnetic recording devices.
Nonlinear Viscoelasticity: Improved matches with experimental data are now possible using nonlinear viscoelasticity based on the parallel network approach. This enhancement is particularly useful in applications involving polymer materials in the automotive and life science industries.
Smoothed Particle Hydrodynamics (SPH): Abaqus provides a new capability that allows conventional elements to be converted into particles on-the-fly based on user defined criteria, which introduces an entirely new set of workflows to be performed in Abaqus.
Porous Media Flow: Abaqus now supports the modeling of fluid flow through a fibrous type of filter, such as water seeping through soil or a paper filter. Flows through fluid-saturated porous media occur in a wide range of industrial and environmental applications, such as packed-bed heat exchangers, heat pipes, thermal insulation, petroleum reservoirs, nuclear waste repositories, geothermal engineering, thermal management of electronic devices, metal alloy casting, and flow past porous scaffolds in bioreactors.
Non-Newtonian Viscosity: Many fluids of industrial, technological, and biological significance, such as foams, emulsions, dispersions and suspensions, slurries, blood, and polymeric melts, are non-Newtonian in nature. Simulation of flows involving such fluids can now be achieved using the non-Newtonian models developed in Abaqus, thereby increasing the coverage of the product functionality.
Mesh-to-Geometry: Mesh parts can now be converted into geometry. This enhancement is useful for creating geometry from deformed meshes, such as a stent, creating an interior acoustic cavity inside of a vehicle, as well as a number of other industry applications.
Boundary Layer Meshing: Wedge elements can now be generated along selected boundaries of a part or a cell, and the interior is filled with tetrahedral elements. Adding layers of small elements along the walls allows improved analysis of boundary effects in fluid flow and heat transfer analyses.
Hybrid Modeling: Additional modeling flexibility for geometry, native, and orphan meshes to co-exist in the same space.
Node Dragging: Nodes can be repositioned with a new “dragging” feature.
Abaqus/Viewer: Visualization functionality in Abaqus/Viewer has been extended to visualize preprocessing modeling entities, such as interactions, pre-defined fields, loads and more.
AMS-based Substructure Generation: A new substructure generation capability in the AMS eigensolver delivers significant performance improvements and reduces disk space requirements for substructure generation in Abaqus 6.12. In one example, performing a frequency analysis and generating a substructure for a powertrain model with 13 million degrees of freedom (DOF) using the AMS eigensolver in Abaqus 6.12 only takes less than four hours, compared to 17 hours in previous versions.
VCCT Enhancements: Performance and robustness improvements were made to the Virtual Crack Closure Technique (VCCT) in Abaqus/Standard, which allows the delamination of composite structures to be modeled much more quickly.
Contact and Constraints: Abaqus 6.12 offers edge-to-feature enhancements for better handling of contact between edges and surfaces, which is valuable in a broad range of applications, for example, electrical connections.
Adaptive Mesh Refinement for CEL: The adaptive mesh refinement for Coupled Eulerian Lagrangian (CEL) improves performance in models in which large deformation exists, such as airbag deployment, by automatically refining the mesh as needed in Abaqus.
Direct Sparse Solver using Multiple GPGPUs: Support for multiple GPUs in the direct sparse solver provides faster execution on computers with multiple GPU cards.
CATIA V6 Associative Interface: The CATIA V6 AI provides a one-click option to easily transfer part or assembly models to Abaqus/CAE, while retaining the attributes defined in Abaqus/CAE during the re-import of geometry from CATIA V6.
Translator Improvements: The existing fromnastran and fromansys translators were enhanced with new robustness, functionality, and diagnostics to support the growing interest in customers moving from ANSYS and NASTRAN to Abaqus. Also, a new fromdyna translator is available to convert DYNA models into Abaqus. Significant focus was placed on performance and ease-of-use, which will allow users to quickly translate large models with as little manual intervention as possible. In one example, an SUV model with over 6 million nodes was translated in 12 seconds with over 99% of the data translated.
发表于 2012-5-16 14:27:01 | 显示全部楼层 来自 新加坡
期待~~
发表于 2012-5-16 14:37:58 | 显示全部楼层 来自 韩国
期待跟我相关的东东。。不过,估计等不到发布我就毕业了
发表于 2012-5-16 14:39:08 | 显示全部楼层 来自 甘肃兰州
期待。。。。。。。
发表于 2012-5-17 00:24:02 | 显示全部楼层 来自 美国
zsq-w 发表于 2012-5-16 01:27
Mesh-to-Geometry: Mesh parts can now be converted into geometry. This enhancement is useful for crea ...
师兄还记得我问的那个纠结问题么?就是新的版本的non-linear viscoelasticity解决问题,哈哈^^
我们这儿已经拿到正版的啦~!!
点评
恭喜恭喜,最先尝鲜的~  发表于 2012-5-17 11:00
发表于 2012-5-28 21:25:06 | 显示全部楼层 来自 清华大学
期待啊!!
发表于 2012-5-28 21:38:18 | 显示全部楼层 来自 重庆
Magnetostatic Response......?!!!!
我的奶奶!可以算磁场啦!!!!简直不敢我老人家的眼睛啊!!
如果能计算场路耦合的瞬态磁场就太满意啦!
另外,既然有了流体模块,为什么还不能搞双向FSI呢?期待-ing........
发表于 2012-5-28 22:45:27 | 显示全部楼层 来自 陕西西安
无聊,没啥值得期待的的,这研发团队每年就做这点东西,效率咋这么低下
发表于 2012-9-3 01:56:57 | 显示全部楼层 来自 广东广州
赞同你说法
发表于 2012-9-3 10:30:47 | 显示全部楼层 来自 陕西西安
哇塞 让我先学习学习~~
GMT+8, 2024-4-16 23:58 , Processed in 0.044322 second(s), 15 queries , Gzip On, MemCache On.
