- 2011-11-29
我在做流固耦合的分析时,刚在CFX中计算时,刚run没过一分钟就显示出错了。下面是错误信息,请高手帮忙看看啥原因。
*** WARNING *** CP = 44.219 TIME= 19:36:28
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING *** CP = 3.750 TIME= 19:34:17
ANSYS results must be written into the database for Multifield
analysis. The /CONFIG,NOELDB,1 command is ignored.
SERVE GLOBAL COUPLING INFORMATION
*** FATAL *** CP = 40.500 TIME= 20:50:35
Error during get surface loads: Total Force. Error Message: Read.
ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= ansabort.db
FOR POSSIBLE RESUME FROM THIS POINT
The above error is non-recoverable by ANSYS
ANSYS run terminated by the indicated error
Current data base saved if possible.
