- 2011-11-29
我在做管道流固耦合时总是出现下边的错误,刚刚计算就停止了,下面是错误的信息,找了很久还是没找到该怎么解决。请大家帮忙。
Convergence History |
| Writing transient file 0.trn |
| Name : Transient Results 1 |
| Type : Selected Variables |
| Option : Timestep Interval |
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS. |
| Message: |
| The connection between this CFX process and an external process |
| has died unexpectedly. The following error was received: |
| External process : ANSYS |
| Error experienced : Read |
| ** This error is fatal: Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX |
| and external processes to determine the cause of the error. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
*** NOTE *** CP = 2.688 TIME= 09:17:47
ANSYS and CFX are using different unit systems. Unit conversions will
be made for all data transferred between the field solvers.
*** WARNING *** CP = 2.703 TIME= 09:17:47
ANSYS results must be written into the database for Multifield
analysis. The /CONFIG,NOELDB,1 command is ignored.
SERVE GLOBAL COUPLING INFORMATION
ADDITIONAL SYNCHRONIZATION FOR CFX:
SECOND SYNCHRONIZATION POINT OF MASTER CODE:
GET INTERFACE MESHES, INITAIL VALUES, and RESTART LOADS
2nd sync. point: Get interface mesh
SURFACE INTERPOLATION MAPPING
PROFILE PRESERVING INTERPOLATION MAPPING
Sending region name = 1
From sending process = ANSYS
to receiving process = CFX
Transferring variable = DISP
Percentage complete = 25 % ...
Percentage complete = 50 % ...
Percentage complete = 75 % ...
Percentage complete = 100 % ...
Processing complete
CONSERVATIVE INTERPOLATION MAPPING
Sending region name = FSI
From sending process = CFX
to receiving process = ANSYS
Transferring variable = Total Force
Sending Side: Total Area = 4.21001E+06
Non-Matching Area Fraction = 0.0000%
No. of Un-Mapped Nodes = 0
Receiving Side: Total Area = 4.21001E+06
Processing complete
*** ERROR *** CP = 34.688 TIME= 09:18:27
Time increment for solid field analysis, 1 is greater than time
increment, 2.E-03 for multifield analysis.
Error during setup - Skipping the remaining MultiField analysis.
