- 2010-12-22
本人在进行瞬态计算的时候,提示了硬盘空间不足的问题“Solver pivot warnings have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully.”?
我从helpfiles中找到了相关的一些问题,想问下具体是什么意思:
The following settings allow you to define when data is calculated and written to the result file for static structural, transient structural, rigid dynamics, steady-state thermal, and transient thermal analyses:
Calculate Results At: Specify this time to be All Time Points (default), Last Time Point, or Equally Spaced Time Points.
Number of Time Points: Displayed only if Calculate Results At is set to Equally Spaced Time Points.
想问下Equally Spaced Time Points到底是什么意思?还有Number of Time Points一般怎样设置才好。上次我再做分析中,把Number of Time Points 设置为2,结果好像是只存储了2个数据。请对这方面明白的版友给予指导,谢谢!
