- 2011-5-29
楼主 |
发表于 2012-7-15 21:59:05
来自 重庆
wbrto 发表于 2012-7-15 21:52
C:\MSC2010\NASTRAN2010\bin\mdnastranw.exe static.bdf
SCR=no 试试~~~
试了 也是不可以 这是f06文件的部分:(并没有显示错误)
SOL 101
CEND
1 JULY 15, 2012 MD NASTRAN 12/15/10 PAGE 3
0
0 C A S E C O N T R O L E C H O
COMMAND
COUNT
1 $
2 ECHO = NONE
3 SPC = 2
4 LOAD = 1
5 $
6 $ OUTPUT OF DISPLACEMENT OF GRID 2
7 SET 1 = 2
8 DISPLACEMENT(PUNCH)= 1
9 $
10 $
11 BEGIN BULK
0 INPUT BULK DATA ENTRY COUNT = 63844
0 TOTAL COUNT= 63764
^^^ >>> IFP OPERATIONS COMPLETE <<<
M O D E L S U M M A R Y
NUMBER OF GRID POINTS = 30598
NUMBER OF CHEXA ELEMENTS = 315
NUMBER OF CQUAD4 ELEMENTS = 27261
NUMBER OF CTRIA3 ELEMENTS = 180
NUMBER OF RBE3 ELEMENTS = 2108
1 JULY 15, 2012 MD NASTRAN 12/15/10 PAGE 4
0
O U T P U T F R O M G R I D P O I N T W E I G H T G E N E R A T O R
0 REFERENCE POINT = 0
M O
* 2.679236E-02 0.000000E+00 0.000000E+00 0.000000E+00 -8.388488E-01 1.290934E+01 *
* 0.000000E+00 2.679236E-02 0.000000E+00 8.388488E-01 0.000000E+00 1.845864E+01 *
* 0.000000E+00 0.000000E+00 2.679236E-02 -1.290934E+01 -1.845864E+01 0.000000E+00 *
* 0.000000E+00 8.388488E-01 -1.290934E+01 9.269078E+03 9.042544E+03 4.515330E+02 *
* -8.388488E-01 0.000000E+00 -1.845864E+01 9.042544E+03 1.730909E+04 -1.817521E+02 *
* 1.290934E+01 1.845864E+01 0.000000E+00 4.515330E+02 -1.817521E+02 2.586922E+04 *
S
* 1.000000E+00 0.000000E+00 0.000000E+00 *
* 0.000000E+00 1.000000E+00 0.000000E+00 *
* 0.000000E+00 0.000000E+00 1.000000E+00 *
DIRECTION
MASS AXIS SYSTEM (S) MASS X-C.G. Y-C.G. Z-C.G.
X 2.679236E-02 0.000000E+00 -4.818290E+02 -3.130925E+01
Y 2.679236E-02 6.889516E+02 0.000000E+00 -3.130925E+01
Z 2.679236E-02 6.889516E+02 -4.818290E+02 0.000000E+00
I(S)
* 3.022721E+03 -1.486349E+02 1.263933E+02 *
* -1.486349E+02 4.565716E+03 -2.224297E+02 *
* 1.263933E+02 -2.224297E+02 6.932021E+03 *
I(Q)
* 3.002998E+03 *
* 6.955949E+03 *
* 4.561511E+03 *
Q
* -9.942825E-01 2.855554E-02 -1.028930E-01 *
* 9.992702E-02 -9.085909E-02 -9.908376E-01 *
* -3.764267E-02 -9.954543E-01 8.748613E-02 *
1 JULY 15, 2012 MD NASTRAN 12/15/10 PAGE 5
0
1 JULY 15, 2012 MD NASTRAN 12/15/10 PAGE 6
0
0 RESULTANTS ABOUT ORIGIN OF SUPERELEMENT BASIC COORDINATE SYSTEM IN SUPERELEMENT BASIC SYSTEM COORDINATES.
0 OLOAD RESULTANT
SUBCASE/ LOAD
DAREA ID TYPE T1 T2 T3 R1 R2 R3
0 1 FX 0.000000E+00 ---- ---- ---- 0.000000E+00 0.000000E+00
FY ---- 0.000000E+00 ---- 0.000000E+00 ---- 0.000000E+00
FZ ---- ---- -5.000015E+02 2.612685E+05 1.077425E+05 ----
MX ---- ---- ---- 0.000000E+00 ---- ----
MY ---- ---- ---- ---- 0.000000E+00 ----
MZ ---- ---- ---- ---- ---- 0.000000E+00
TOTALS 0.000000E+00 0.000000E+00 -5.000015E+02 2.612685E+05 1.077425E+05 0.000000E+00
*** SYSTEM INFORMATION MESSAGE 4159 (DFMSA)
THE DECOMPOSITION OF KLL YIELDS A MAXIMUM MATRIX-TO-FACTOR-DIAGONAL RATIO OF 1.805090E+03
1 JULY 15, 2012 MD NASTRAN 12/15/10 PAGE 7
0
*** USER INFORMATION MESSAGE 5293 (SSG3A)
FOR DATA BLOCK KLL
LOAD SEQ. NO. EPSILON EXTERNAL WORK EPSILONS LARGER THAN 0.001 ARE FLAGGED WITH ASTERISKS
1 1.0037898E-11 5.7756611E+03
1 JULY 15, 2012 MD NASTRAN 12/15/10 PAGE 8
0
* * * * D B D I C T P R I N T * * * * SUBDMAP = PRTSUM , DMAP STATEMENT NO. 40
0 * * * * A N A L Y S I S S U M M A R Y T A B L E * * * *
0 SEID PEID PROJ VERS APRCH SEMG SEMR SEKR SELG SELR MODES DYNRED SOLLIN PVALID SOLNL LOOPID DESIGN CYCLE SENSITIVITY
0 0 1 1 ' ' T T T T T F F T 0 F -1 0 F
0SEID = SUPERELEMENT ID.
PEID = PRIMARY SUPERELEMENT ID OF IMAGE SUPERELEMENT.
PROJ = PROJECT ID NUMBER.
VERS = VERSION ID.
APRCH = BLANK FOR STRUCTURAL ANALYSIS. HEAT FOR HEAT TRANSFER ANALYSIS.
SEMG = STIFFNESS AND MASS MATRIX GENERATION STEP.
SEMR = MASS MATRIX REDUCTION STEP (INCLUDES EIGENVALUE SOLUTION FOR MODES).
SEKR = STIFFNESS MATRIX REDUCTION STEP.
SELG = LOAD MATRIX GENERATION STEP.
SELR = LOAD MATRIX REDUCTION STEP.
MODES = T (TRUE) IF NORMAL MODES OR BUCKLING MODES CALCULATED.
DYNRED = T (TRUE) MEANS GENERALIZED DYNAMIC AND/OR COMPONENT MODE REDUCTION PERFORMED.
SOLLIN = T (TRUE) IF LINEAR SOLUTION EXISTS IN DATABASE.
PVALID = P-DISTRIBUTION ID OF P-VALUE FOR P-ELEMENTS
LOOPID = THE LAST LOOPID VALUE USED IN THE NONLINEAR ANALYSIS. USEFUL FOR RESTARTS.
SOLNL = T (TRUE) IF NONLINEAR SOLUTION EXISTS IN DATABASE.
DESIGN CYCLE = THE LAST DESIGN CYCLE (ONLY VALID IN OPTIMIZATION).
SENSITIVITY = SENSITIVITY MATRIX GENERATION FLAG.
No PARAM values were set in the Control File.
1 * * * END OF JOB * * *
No Symbolic Replacement variables or values were specified.
