- 2009-5-26
计算过程中一直报错:
in keyword *DISTRIBUTIONTABLE, file "textilemodel-2012-10-19.inp", line 9: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
仔细核对没有发现错误,请大侠明示
问题1:The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
不明白它的意思
问题2: 提示中line 9是具体是指哪一行(见inp文件),定义为一个line得标准是什么?
是指*distribution table, name=orientationangle
ANGLE
这一行嘛?
具体的inp 文件如下:
inp文件:
** PART INSTANCE: unitCellInstance
COORD3D,COORD3D
*distribution, location=element, table=orientation, name=ordist, input=simpleplain_0-5.ori
ANGLE
*distribution, location=element, table=orientationangle, name=angledist
,0.0
*orientation, name=dist, definition=coordinates
ordist
3, angledist
*distribution table, name=yarnProps
MODULUS,MODULUS,MODULUS,RATIO,RATIO,RATIO,MODULUS
MODULUS,MODULUS
*distribution, location=element, table=yarnProps, name=yarnDist, input=simpleplain_0-5.matprops
*Material, name=yarn
*Elastic, type=ENGINEERING CONSTANTS
yarnDist
*Depvar
*Solid section, elset=unitCellInstance_yarnCellSet, material=yarn, orientation=dist
1.,
*Initial conditions, type=solution, input=simpleplain_0-5.vf
*Node
1, 0., 0., 0.280002326
2, 1.75, 0., 0.400000006
3, 0., 0., 0.519999981
4, 1.75, 2., 0.275000006
5, 0., 2., 0.395524532
