- 25
- 2011-11-16
楼主 |
发表于 2012-12-25 09:00:24
来自 江苏南京
tjtianj 发表于 2012-12-24 19:11
学习了。还是有一些疑问:
1. LOAD CASE=1如何理解。(加载在工况1上,也就是前文的PSD分析布。)帮助文件 ...
- (1)LOAD CASE1对应特定分析布,我的理解是对应RANDOM RESPOSE分析布。用户手册的提示全部内容是一下,你不能断章取义,搞得好像我骗你似的。
- The loads can be defined as concentrated point loads, as distributed loads, as connector element loads, or as base motion excitations, as described below in “Boundary conditions,” and “Loads.” Multiple, uncorrelated load cases can be defined for concentrated point loads, connector loads, and base motions. Load case 1 is reserved for all distributed loads defined in a particular step. In these steps load case 1 cannot be used for any concentrated point load, connector load, or base motion. Thus, there cannot be any correlation between distributed loads and any other load. Moreover, base motion excitations are assumed to be statistically independent (no correlation) with any other load type even when the same load case number is used. The concentrated point and connector element loads are assumed to be correlated if the same load case number is used.
- 大致意思:载荷施加类型可以是集中载荷,分布载荷,单元连接载荷,或者基础运动BASE MOTION来激发。如果具有多个工况,不具有相关性的工况可以采用上述四种载荷类型,而工况1只能用于分布载荷,不能用于其他三类载荷类型,而且不能和其他自相关的工况同时应用。
- 我试了一下,吧刚性单元拿掉,对节点施加全约束,结果一样,那说明显然是对的。见下图。
- (2)显然你没有好好看我的模型,约束点是采用的全约束,你想输出加速度、速度,结果,你是在考验我们的智商吗?输出的RA等结果是相对基础点的——相对位移、速度、加速度。是一个相对量。
- (3)材料总有一个拉伸强度极限,剪切强度极限等等,超过了就会破坏。均方根RMS对应的是方差,体现偏离平衡位置的值。引用版内一位朋友的说法“结果察看,最大主应力乘以3(3sigma principal stress)作为考核结果,认为最大结果小于材料极限的话,失效的几率小于99.7%”
复制代码
刚性单元约束改为节点约束
