- 4
- 2005-7-29
nastran计算流固耦合,全部是shell的三角形和四边形单元,共约95000个,其中和液体作用的湿面单元,共约54000个。f06文件没有提示错误代码,但是有如下提示(前面的介绍省略了):
(前面的省略了):
bulk data
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 1
0 N A S T R A N F I L E A N D S Y S T E M P A R A M E T E R E C H O
0
NASTRAN OP2NEW=0 $ MSC.NASTRAN .LCL FILE
NASTRAN BUFFSIZE=65537 $(C:/MSC.SOFTWARE/MSC.NASTRAN/CONF/NAST2005.RCF[2])
NASTRAN SYSTEM(151)=1 $(C:/MSC.SOFTWARE/MSC.NASTRAN/CONF/NAST2005.RCF[5])
NASTRAN SYSTEM(1)=32769 $(C:/MSC.SOFTWARE/MSC.NASTRAN/CONF/NAST2005.RCF[6])
NASTRAN REAL=533200896 $(PROGRAM DEFAULT)
$ NASTRAN INPUT FILE CREATED BY THE MSC MSC.NASTRAN INPUT FILE
$ TRANSLATOR ( MSC.PATRAN 13.0.053 ) ON DECEMBER 26, 2012 AT 18:34:19.
$ DIRECT TEXT INPUT FOR NASTRAN SYSTEM CELL SECTION
NASTRAN DBCFACT=4
$ DIRECT TEXT INPUT FOR FILE MANAGEMENT SECTION
INIT SCRATCH LOGICAL=(SCR1(50GB),SCR2(50GB)),
SCR300=(SCRA(50GB),SCRB(50GB),SCRC(50GB),SCRD(50GB))
$ NORMAL MODES ANALYSIS, DATABASE
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 2
0 N A S T R A N E X E C U T I V E C O N T R O L E C H O
0
SOL 103
$ DIRECT TEXT INPUT FOR EXECUTIVE CONTROL
$$ NASTRAN INPUT DECK GENERATED BY HYPERMESH VERSION : 9.0B121
$$ GENERATED USING HYPERMESH-NASTRAN TEMPLATE VERSION : 9.0B121
$$ TEMPLATE: GENERAL
$$ EXECUTIVE CONTROL CARDS
CEND
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 3
0
0 C A S E C O N T R O L E C H O
COMMAND
COUNT
1 SEALL = ALL
2 SUPER = ALL
3 ECHO = NONE
4 $ DIRECT TEXT INPUT FOR GLOBAL CASE CONTROL DATA
5 $$---------------------------------------------------------------------- --------
6 $$ CASE CONTROL CARDS
7 $$---------------------------------------------------------------------- --------
8 $HMSET 2 2 "OTHER"
9 $HMSETTYPE 2 "REGULAR"
10 $HMSET 3 2 "ELIST"
11 $HMSETTYPE 3 "REGULAR"
12 $$---------------------------------------------------------------------- --------
13 $$ BULK DATA CARDS
14 $$---------------------------------------------------------------------- --------
15 SUBCASE 1
16 $ SUBCASE NAME : DEFAULT
17 SUBTITLE=DEFAULT
18 METHOD = 1
19 VECTOR(SORT1,REAL)=ALL
20 SPCFORCES(SORT1,REAL)=ALL
21 $ DIRECT TEXT INPUT FOR THIS SUBCASE
22 MFLUID=1
23 BEGIN BULK
0 INPUT BULK DATA ENTRY COUNT = 187483
0 TOTAL COUNT= 187434
M O D E L S U M M A R Y
NUMBER OF GRID POINTS = 90393
NUMBER OF CQUAD4 ELEMENTS = 94094
NUMBER OF CTRIA3 ELEMENTS = 1820
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 4
0
0
0
0
*** USER INFORMATION MESSAGE 7555 (GMTSTD)
FINITE ELEMENT GEOMETRY CHECK RESULTS EXCEED TOLERANCE LEVELS FOR THE FOLLOWING ELEMENTS. METRIC VALUES THAT EXCEED
TEST TOLERANCE LIMITS ARE IDENTIFIED BY ONE OF THE FOLLOWING FLAGS PLACED TO THE RIGHT OF THE METRIC VALUE.
"++++" FOR TEST RESULTS EXCEEDING TOLERANCES. INFORMATIONAL ONLY. PROBLEM SOLUTION CONTINUES. (DEFAULT FLAG)
"IGNR" FOR TEST RESULTS EXCEEDING TOLERANCES. INFORMATIONAL ONLY. PROBLEM SOLUTION CONTINUES.
"WARN" FOR TEST RESULTS EXCEEDING TOLERANCES. INFORMATIONAL ONLY. PROBLEM SOLUTION CONTINUES.
"FAIL" FOR TEST RESULTS EXCEEDING TOLERANCES. SEVERE ERROR. PROBLEM SOLUTION TERMINATES.
USER ACTION: USE THE GEOMCHECK (EXECUTIVE CONTROL STATEMENT) KEYWORD=VALUE TO CHANGE TOLERANCE VALUES IF DESIRED.
A MAXIMUM OF 100 SKEW ANGLE (SA) TOLERANCE LIMIT VIOLATIONS WILL BE IDENTIFIED BY THE FLAG "++++"
PLACED AFTER THE VALUE METRIC FOR THE TEST.
A MAXIMUM OF 100 MIN INT. ANGLE (IA) TOLERANCE LIMIT VIOLATIONS WILL BE IDENTIFIED BY THE FLAG "++++"
A MAXIMUM OF 100 MAX INT. ANGLE (IA) TOLERANCE LIMIT VIOLATIONS WILL BE IDENTIFIED BY THE FLAG "++++"
A MAXIMUM OF 100 WARPING FACTOR (WF) TOLERANCE LIMIT VIOLATIONS WILL BE IDENTIFIED BY THE FLAG "++++"
A MAXIMUM OF 100 TAPER RATIO (TR) TOLERANCE LIMIT VIOLATIONS WILL BE IDENTIFIED BY THE FLAG "++++"
USER INFORMATION: THE MAXIMUM MESSAGE COUNT FOR ANY ONE ELEMENT ERROR TEST COULD BE EXCEEDED BY THE
CUMULATIVE EFFECT OF ALL THE MESSAGES GENERATED FOR ALL OF THE DIFFERENT TESTS PERFORMED.
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 5
0
TOLERANCE LIMITS ARE: SA = 30.00, IA(MIN) = 30.00, IA(MAX) = 150.00, WF = 0.05, TR = 0.50 (FLAG = LIMIT VIOLATED)
ELEMENT TYPE ID SKEW ANGLE MIN INT. ANGLE MAX INT. ANGLE WARPING FACTOR TAPER RATIO
QUAD4 9015 86.29 55.13 134.11 0.00 0.56 ++++
QUAD4 9094 46.79 37.70 150.82 ++++ 0.00 0.41
QUAD4 9105 42.08 35.42 154.08 ++++ 0.00 0.43
QUAD4 9454 40.78 31.21 155.47 ++++ 0.00 0.44
QUAD4 9829 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 10140 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 10284 60.00 37.41 150.89 ++++ 0.00 0.45
QUAD4 10286 28.06 ++++ 25.83 ++++ 154.17 ++++ 0.00 0.03
QUAD4 10287 23.92 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.03
QUAD4 10288 26.41 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.07
QUAD4 10289 29.79 ++++ 27.64 ++++ 152.36 ++++ 0.00 0.04
QUAD4 10290 34.67 27.64 ++++ 152.36 ++++ 0.00 0.10
QUAD4 10382 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 10619 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 11017 68.94 51.29 135.32 0.00 0.59 ++++
QUAD4 11024 69.02 62.95 143.21 0.00 0.56 ++++
QUAD4 11270 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 11458 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 11689 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 11915 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 12191 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 12379 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 12610 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 12836 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 13764 30.19 29.33 ++++ 150.67 ++++ 0.00 0.01
QUAD4 13765 28.52 ++++ 27.74 ++++ 152.26 ++++ 0.00 0.01
QUAD4 13766 27.01 ++++ 26.30 ++++ 153.70 ++++ 0.00 0.01
QUAD4 13767 25.64 ++++ 25.00 ++++ 155.00 ++++ 0.00 0.01
QUAD4 13768 24.39 ++++ 23.81 ++++ 156.19 ++++ 0.00 0.01
QUAD4 13769 23.25 ++++ 22.72 ++++ 157.28 ++++ 0.00 0.01
QUAD4 13770 22.21 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.01
QUAD4 13771 26.05 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.10
QUAD4 13870 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 13880 58.09 38.77 141.23 0.00 0.67 ++++
QUAD4 14005 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
QUAD4 14006 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 14007 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
QUAD4 14183 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 14333 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 14334 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 14335 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 14666 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 6
0
QUAD4 14667 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 14668 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
QUAD4 14993 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 14994 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 14995 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 15612 86.29 55.13 134.09 0.00 0.56 ++++
QUAD4 15691 46.78 37.70 150.82 ++++ 0.00 0.41
QUAD4 15702 42.07 35.42 154.10 ++++ 0.00 0.43
QUAD4 16051 40.78 31.21 155.47 ++++ 0.00 0.44
QUAD4 16426 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 16737 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 16881 60.00 37.41 150.89 ++++ 0.00 0.45
QUAD4 16883 28.06 ++++ 25.83 ++++ 154.17 ++++ 0.00 0.03
QUAD4 16884 23.92 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.03
QUAD4 16885 26.41 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.07
QUAD4 16886 29.79 ++++ 27.64 ++++ 152.36 ++++ 0.00 0.04
QUAD4 16887 34.67 27.64 ++++ 152.36 ++++ 0.00 0.10
QUAD4 16979 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 17216 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 17614 68.94 51.29 135.32 0.00 0.59 ++++
QUAD4 17621 69.02 62.95 143.21 0.00 0.56 ++++
QUAD4 17867 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 18055 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 18286 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 18512 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 18788 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 18976 79.45 61.84 117.20 0.00 0.67 ++++
QUAD4 19207 79.45 61.85 117.21 0.00 0.67 ++++
QUAD4 19433 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 20361 30.19 29.33 ++++ 150.67 ++++ 0.00 0.01
QUAD4 20362 28.52 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.01
QUAD4 20363 27.01 ++++ 26.30 ++++ 153.70 ++++ 0.00 0.01
QUAD4 20364 25.64 ++++ 25.00 ++++ 155.00 ++++ 0.00 0.01
QUAD4 20365 24.38 ++++ 23.78 ++++ 156.22 ++++ 0.00 0.01
QUAD4 20366 23.23 ++++ 22.71 ++++ 157.29 ++++ 0.00 0.01
QUAD4 20367 22.21 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.01
QUAD4 20368 26.05 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.10
QUAD4 20467 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 20477 58.09 38.77 141.23 0.00 0.67 ++++
QUAD4 20602 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
QUAD4 20603 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 20604 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 7
0
QUAD4 20780 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 20930 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 20931 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 20932 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 21263 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
QUAD4 21264 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 21265 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
QUAD4 21589 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 21590 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 21591 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 22204 86.29 55.13 134.11 0.00 0.56 ++++
QUAD4 22283 46.79 37.70 150.82 ++++ 0.00 0.41
QUAD4 22294 42.08 35.42 154.08 ++++ 0.00 0.43
QUAD4 22643 40.78 31.21 155.47 ++++ 0.00 0.44
QUAD4 23018 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 23329 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 23473 60.00 37.41 150.89 ++++ 0.00 0.45
QUAD4 23475 28.06 ++++ 25.83 ++++ 154.17 ++++ 0.00 0.03
QUAD4 23476 23.92 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.03
QUAD4 23477 26.41 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.07
QUAD4 23478 29.79 ++++ 27.64 ++++ 152.36 ++++ 0.00 0.04
QUAD4 23479 34.67 27.64 ++++ 152.36 ++++ 0.00 0.10
QUAD4 23571 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 23808 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 24206 68.94 51.29 135.32 0.00 0.59 ++++
QUAD4 24213 69.02 62.95 143.21 0.00 0.56 ++++
QUAD4 24459 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 24647 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 24878 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 25104 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 25380 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 25568 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 25799 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 26025 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 26953 30.19 29.33 ++++ 150.67 ++++ 0.00 0.01
QUAD4 26954 28.52 ++++ 27.74 ++++ 152.26 ++++ 0.00 0.01
QUAD4 26955 27.01 ++++ 26.30 ++++ 153.70 ++++ 0.00 0.01
QUAD4 26956 25.64 ++++ 25.00 ++++ 155.00 ++++ 0.00 0.01
QUAD4 26957 24.39 ++++ 23.81 ++++ 156.19 ++++ 0.00 0.01
QUAD4 26958 23.25 ++++ 22.72 ++++ 157.28 ++++ 0.00 0.01
QUAD4 26959 22.21 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.01
QUAD4 26960 26.05 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.10
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 8
0
QUAD4 27059 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 27069 58.09 38.77 141.23 0.00 0.67 ++++
QUAD4 27194 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
QUAD4 27195 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 27196 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
QUAD4 27372 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 27522 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 27523 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 27524 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 27855 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
QUAD4 27856 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 27857 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
QUAD4 28182 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 28183 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 28184 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 28801 86.29 55.13 134.09 0.00 0.56 ++++
QUAD4 28880 46.78 37.70 150.82 ++++ 0.00 0.41
QUAD4 28891 42.07 35.42 154.10 ++++ 0.00 0.43
QUAD4 29240 40.78 31.21 155.47 ++++ 0.00 0.44
QUAD4 29615 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 29926 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 30070 60.00 37.41 150.89 ++++ 0.00 0.45
QUAD4 30072 28.06 ++++ 25.83 ++++ 154.17 ++++ 0.00 0.03
QUAD4 30073 23.92 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.03
QUAD4 30074 26.41 ++++ 22.25 ++++ 157.75 ++++ 0.00 0.07
QUAD4 30075 29.79 ++++ 27.64 ++++ 152.36 ++++ 0.00 0.04
QUAD4 30076 34.67 27.64 ++++ 152.36 ++++ 0.00 0.10
QUAD4 30168 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 30405 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 30803 68.94 51.29 135.32 0.00 0.59 ++++
QUAD4 30810 69.02 62.95 143.21 0.00 0.56 ++++
QUAD4 31056 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 31244 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 31475 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 31701 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 31977 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 32165 79.45 61.84 117.20 0.00 0.67 ++++
QUAD4 32396 79.45 61.85 117.21 0.00 0.67 ++++
QUAD4 32622 79.48 61.88 117.19 0.00 0.67 ++++
QUAD4 33550 30.19 29.33 ++++ 150.67 ++++ 0.00 0.01
QUAD4 33551 28.52 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.01
QUAD4 33552 27.01 ++++ 26.30 ++++ 153.70 ++++ 0.00 0.01
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 9
0
QUAD4 33553 25.64 ++++ 25.00 ++++ 155.00 ++++ 0.00 0.01
QUAD4 33554 24.38 ++++ 23.78 ++++ 156.22 ++++ 0.00 0.01
QUAD4 33555 23.23 ++++ 22.71 ++++ 157.29 ++++ 0.00 0.01
QUAD4 33556 22.21 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.01
QUAD4 33557 26.05 ++++ 21.72 ++++ 158.28 ++++ 0.00 0.10
QUAD4 33656 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 33666 58.09 38.77 141.23 0.00 0.67 ++++
QUAD4 33791 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
QUAD4 33792 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 33793 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
QUAD4 33969 87.65 59.70 142.32 0.00 0.68 ++++
QUAD4 34119 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 34120 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 34121 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 34452 30.51 29.55 ++++ 150.45 ++++ 0.00 0.02
QUAD4 34453 28.63 ++++ 27.76 ++++ 152.24 ++++ 0.00 0.02
QUAD4 34454 35.06 27.76 ++++ 152.24 ++++ 0.00 0.16
QUAD4 34778 30.51 29.54 ++++ 150.46 ++++ 0.00 0.02
QUAD4 34779 28.62 ++++ 27.75 ++++ 152.25 ++++ 0.00 0.02
QUAD4 34780 35.05 27.75 ++++ 152.25 ++++ 0.00 0.16
QUAD4 37657 85.05 59.04 120.88 0.00 0.50 ++++
QUAD4 40386 85.05 59.04 120.88 0.00 0.50 ++++
QUAD4 43115 85.05 59.04 120.88 0.00 0.50 ++++
QUAD4 45844 85.05 59.04 120.88 0.00 0.50 ++++
QUAD4 48039 72.80 54.32 134.31 0.00 0.59 ++++
QUAD4 48634 72.80 54.31 134.31 0.00 0.59 ++++
QUAD4 49229 72.80 54.32 134.31 0.00 0.59 ++++
QUAD4 49824 72.80 54.31 134.31 0.00 0.59 ++++
QUAD4 51468 70.60 62.65 142.30 0.00 0.52 ++++
QUAD4 51469 74.74 51.47 118.37 0.00 0.50 ++++
QUAD4 51719 70.60 62.65 142.31 0.00 0.52 ++++
QUAD4 51720 74.74 51.47 118.37 0.00 0.50 ++++
QUAD4 51970 70.60 62.65 142.30 0.00 0.52 ++++
QUAD4 51971 74.74 51.47 118.37 0.00 0.50 ++++
QUAD4 52221 70.60 62.65 142.31 0.00 0.52 ++++
QUAD4 52222 74.74 51.47 118.37 0.00 0.50 ++++
QUAD4 55090 65.09 45.61 115.78 0.00 0.51 ++++
QUAD4 55094 48.98 40.91 155.08 ++++ 0.00 0.56 ++++
QUAD4 55124 75.92 49.54 137.00 0.00 0.71 ++++
QUAD4 55136 85.63 71.07 135.03 0.00 0.59 ++++
QUAD4 55138 59.03 44.77 113.73 0.00 0.51 ++++
QUAD4 55142 48.98 40.91 155.08 ++++ 0.00 0.56 ++++
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 10
0
QUAD4 55938 84.98 72.71 120.57 0.00 0.55 ++++
QUAD4 55939 84.98 72.71 120.57 0.00 0.55 ++++
QUAD4 55962 65.09 45.61 115.78 0.00 0.51 ++++
QUAD4 56073 65.09 45.61 115.78 0.00 0.51 ++++
QUAD4 56077 48.98 40.91 155.09 ++++ 0.00 0.56 ++++
QUAD4 56107 75.92 49.54 136.99 0.00 0.71 ++++
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 11
0
TOLERANCE LIMITS ARE: SKEW = 10.00, IA(MAX) = 160.00 (++++ = LIMIT VIOLATED)
ELEMENT TYPE ID SKEW ANGLE MAX INT. ANGLE
TRIA3 97884 7.51 ++++ 128.48
TRIA3 97891 7.51 ++++ 128.48
TRIA3 97946 7.51 ++++ 128.45
TRIA3 97953 7.51 ++++ 128.45
TRIA3 98008 7.51 ++++ 128.48
TRIA3 98015 7.51 ++++ 128.48
TRIA3 98070 7.51 ++++ 128.45
TRIA3 98077 7.51 ++++ 128.45
1 DECEMBER 27, 2012 MSC.NASTRAN 9/23/04 PAGE 12
0
E L E M E N T G E O M E T R Y T E S T R E S U L T S S U M M A R Y
TOTAL NUMBER OF TIMES TOLERANCES WERE EXCEEDED
ASPECT/ MINIMUM MAXIMUM SURFACE/FACE EDGE POINT JACOBIAN
ELEMENT TYPE SKEW ANGLE TAPER RATIO INTER. ANGLE INTER. ANGLE WARP FACTOR OFFSET RATIO LENGTH RATIO DETERMINANT
QUAD4 60 324 120 164 0 N/A N/A N/A
TRIA3 8 N/A N/A 0 N/A N/A N/A N/A
N/A IN THE ABOVE TABLE INDICATES TESTS THAT ARE NOT APPLICABLE TO THE ELEMENT TYPE AND WERE NOT PERFORMED.
FOR ALL ELEMENTS WHERE GEOMETRY TEST RESULTS HAVE EXCEEDED TOLERANCES,
QUAD4 ELEMENT ID 20367 PRODUCED SMALLEST SKEW ANGLE OF 22.21 (TOLERANCE = 30.00).
QUAD4 ELEMENT ID 96938 PRODUCED LARGEST TAPER RATIO OF 0.84 (TOLERANCE = 0.50).
QUAD4 ELEMENT ID 13770 PRODUCED SMALLEST INTERIOR ANGLE OF 21.72 (TOLERANCE = 30.00).
QUAD4 ELEMENT ID 33557 PRODUCED LARGEST INTERIOR ANGLE OF 158.28 (TOLERANCE = 150.00).
TRIA3 ELEMENT ID 98077 PRODUCED SMALLEST SKEW ANGLE OF 7.51 (TOLERANCE = 10.00).
MAIN: "Access violation" (C0000005) exception encountered.
MAIN: For reference, A(MAINAL) = 4012FE, A(/SYSTEM/) = 1FD0A00
MAIN: A(/XNSTRN/) = 39C0020
MAIN: Exception occurred at address 0074CB0C.
MAIN: Program attempted to store data at location 11AF4000.
MAIN: Context Flags 0001003F
MAIN: EAX 00000020 EBX 03A26C94 ECX 000021E9 EDX 03AF39F0 ESI 10772AF8 EDI 11AF3FF8
MAIN: EBP 03AAFCD0 ESP 0012F070 EIP 0074CB0C EFLAGS 00010202
MAIN: The 32 bytes around exception location 0074CB0C are --
MAIN: 0074CAFC 03 8D 49 00 DD 45 00 D8 C9 DD 1F DD 45 08 D8 C9
MAIN: 0074CB0C DD 5F 08 DD 45 10 D8 C9 DD 5F 10 DD 45 18 D8 C9
MAIN: FPU Control Word 0273 StatusWord 0332 TagWord FFF0
MAIN: FPU EIP 0074CB0A OpCode 0201 DataOffset 03AAFCD8
MAIN: Data at 03AAFCD8 is 00EADED6 47132FBE
MAIN: FPU Reg 0 (Tag 0) BFD1903B5EFBF25B1000 -1.601295963531041e-014
MAIN: FPU Reg 1 (Tag 0) 3FED9486128661453800 4.426351790662797e-006
MAIN: FPU Reg 2 (Tag 3) 3FED960540905C4F4000 EMPTY
MAIN: FPU Reg 3 (Tag 3) 3FED942F734DBA962000 EMPTY
MAIN: FPU Reg 4 (Tag 3) 3FED94B7B017A906D000 EMPTY
MAIN: FPU Reg 5 (Tag 3) 3FED95AFB5008A540800 EMPTY
MAIN: FPU Reg 6 (Tag 3) 3FED96363F85AF505800 EMPTY
MAIN: FPU Reg 7 (Tag 3) 3FED9161350677FEF800 EMPTY
MAIN: The 256 words on the stack, starting at 0012F070, are --
MAIN: 0012F070 0000CC1D 03AA3728 03AF39E8 03AF39F0 039C07D8 FFFF5FA7 0000000C 00000002 *....(7...9...9......._..........*
MAIN: 0012F090 039C0030 039C0030 0252F4E1 03A8D168 00DA26E2 039C0030 03A8D168 03A268C0 *0...0.....R.h....&..0...h....h..*
MAIN: 0012F0B0 03AF39F0 10772AF8 0CE7D3B0 02D5C45C 02D5C488 02383228 0238321C 023831D8 *.9...*w.....\.......(28..28..18.*
MAIN: 0012F0D0 02383220 3EF26489 00000273 00000018 00000E73 0012F210 00000000 0201A6E1 * 28..d.>s.......s...............*
MAIN: 0012F0F0 00000000 000002B0 0336CB2E 0000CD12 00000000 00000000 0000CD11 000001DD *..........6.....................*
MAIN: 0012F110 0000CD11 02383048 0000CD11 0252F4E1 00000000 0000A059 0001E110 00000001 *....H08.......R.....Y...........*
MAIN: 0012F130 358637BD 3E001AF3 00000000 3D619AA9 00000000 00002CB9 00000001 00000001 *.7.5...>......a=.....,..........*
MAIN: 0012F150 3DEE44DB 3EF26489 0000CD11 00006688 00000000 0000000C 01FD0C5C 00000259 *.D.=.d.>.....f..........\...Y...*
MAIN: 0012F170 0047CA73 00000036 00000006 44626170 00000002 00000001 02187380 4442FD80 *s.G.6.......pabD.........s....BD*
MAIN: 0012F190 FFFFFFFE 00000001 0218737C 463202F0 00000000 45852260 01CDE433 00000001 *........|s....2F....`".E3.......*
MAIN: 0012F1B0 02080C60 00000001 00000005 00000004 0000000E 5223512B 00449024 52228419 *`...................+Q#R$.D..."R*
MAIN: 0012F1D0 0012F23C 0012F234 0012F200 0012F1F8 00449024 00000001 021EA4D0 00000001 *<...4...........$.D.............*
MAIN: 0012F1F0 00000008 00000000 00000000 0000000E 02DFC660 0012F258 00000000 00000000 *................`...X...........*
MAIN: 0012F210 00000000 00000000 00000001 00000001 20202035 00000000 00000014 00489ABE *................5 ..........H.*
MAIN: 0012F230 00000000 02202190 00000000 02202190 02036160 039C0030 00932FE0 022B0500 *.....! ......! .`a..0..../....+.*
MAIN: 0012F250 02036160 0203614C 022B0490 02080C74 039C0030 039C0030 039C0030 022021C0 *`a..La....+.t...0...0...0....! .*
MAIN: 0012F270 02D97F00 039C0030 005100CC 02029B24 021D5DD4 10852E3C 10852E38 033A4B81 *....0.....Q.$....]..<...8....K:.*
MAIN: 0012F290 0000FFFF 039C0020 00000007 00000014 00000007 FFFFFFFF 00084696 004353D0 *.... ....................F...SC.*
MAIN: 0012F2B0 022932C0 454D554E 20434952 00000001 FFFFFFFF 022049B0 00000006 00000001 *.2).NUMERIC .........I .........*
MAIN: 0012F2D0 0012F384 FFFFFFF6 0012F384 FFFFFFF6 00000000 02202088 005AEB1D 02036164 *..................... ...Z.da..*
MAIN: 0012F2F0 02036160 0203614C 02202190 039C0030 022021D4 02202080 02DFC678 022020E0 *`a..La...! .0....! .. .x.... .*
MAIN: 0012F310 022021B0 039C0030 FFFFFFFC 00000072 033A4735 00000001 00000000 FFFFFFFF *.! .0.......r...5G:.............*
MAIN: 0012F330 00000001 0005AA0A 00000001 1170CDD4 0004F483 00000001 007954FC 00000000 *..............p..........Ty.....*
MAIN: 0012F350 00000018 00000000 00000000 00000006 005D3CE2 022049B0 02204990 022049B0 *.................<]..I ..I ..I .*
MAIN: 0012F370 00000006 00000000 00000018 00000000 0047EFBF 00000006 0047F08E 00429C2E *..................G.......G...B.*
MAIN: 0012F390 00000A28 7FFDB000 0040F92E 004018C8 00000000 00000A28 7FFDB000 0012F3D4 *(.........@...@.....(...........*
MAIN: 0012F3B0 000003A8 00000804 00000000 77C00626 00000002 FE81003F 00000000 00000000 *............&..w....?...........*
MAIN: 0012F3D0 00680000 02200248 02200220 02200220 02200220 02680220 02280228 02280228 *..h.H. . . . . . . . .h.(.(.(.(.*
MAIN: 0012F3F0 02200220 02200220 02200220 02200220 02200220 02200220 02200220 02200220 * . . . . . . . . . . . . . . . .*
MAIN: 0012F410 02200220 02100248 02100210 02100210 02100210 0012FE9C 0040AF62 00000000 * . .H...................b.@.....*
MAIN: 0012F430 00000000 00000001 0012F070 00000000 003DDF28 00000000 00000000 00000000 *........p.......(.=.............*
MAIN: 0012F450 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 *................................*
MAIN: The 256 words on the stack, starting at 03AAFCD0, are --
MAIN: 03AAFCD0 EB40EA00 BE303471 D6DEEA00 BE2F1347 A8742C00 BE2D2D55 3DF68A00 BE2C155D *..@.q40.....G./..,t.U--....=].,.*
MAIN: 03AAFCF0 16C89E00 BE24E0EE 8C6BE200 BE25A898 9D7EF800 BE25299D ED48E800 BE25F310 *......$...k...%...~..)%...H...%.*
MAIN: 03AAFD10 5F53A200 BE2421B1 23A33400 BE2468A0 F2BE5600 BE255A6B 83003800 BE2494B6 *..S_.!$..4.#.h$..V..kZ%..8....$.*
MAIN: 03AAFD30 76550200 BE23D764 42AFB000 BE27A115 9027F600 BE26C567 1453FA00 BE2752F4 *..Uvd.#....B..'...'.g.&...S..R'.*
MAIN: 03AAFD50 84F15800 BE26791E 01345600 BE2700BF AFBFFC00 BE2628F2 8ABB0C00 BE25AF9A *.X...y&..V4...'......(&.......%.*
MAIN: 03AAFD70 64D87000 BE267C15 CE492200 BE25ED38 53346200 BE26BAF6 CE63B600 BE24EB9E *.p.d.|&.."I.8.%..b4S..&...c...$.*
MAIN: 03AAFD90 D1EE0200 BE2527FB 58480600 BE263969 C578A400 BE256E5C BFF85000 BE24ABCB *.....'%...HXi9&...x.\n%..P....$.*
MAIN: 03AAFDB0 7BC51200 BE2871A8 40F7FC00 BE2791A0 AF52B000 BE283040 E5928800 BE27517B *...{.q(....@..'...R.@0(.....{Q'.*
MAIN: 03AAFDD0 9E04D000 BE27EAAF 8B166800 BE270D5E F96B2200 BE21713C E5B3B600 BE22129A *......'..h..^.'.."k.<q!.......".*
MAIN: 03AAFDF0 683EDA00 BE21B17D F17EA400 BE225479 3A7F4E00 BE20D67A D1F3DA00 BE211524 *..>h}.!...~.yT"..N.:z. .....$.!.*
MAIN: 03AAFE10 118E9400 BE21CDCF CB8D2200 BE212E31 388D9200 BE209525 E3366A00 BE23AFB0 *......!.."..1.!....8%. ..j6...#.*
MAIN: 03AAFE30 C7B12800 BE22FE6D 9028A200 BE236A7A 67FBE400 BE22BAE7 DD82FA00 BE23220D *.(..m."...(.zj#....g.."......"#.*
MAIN: 03AAFE50 68A80C00 BE227450 895F3400 BE2228EE 2387B000 BE22CEBD 5A3CEE00 BE22605F *...hPt"..4_..("....#.."...<Z_`".*
MAIN: 03AAFE70 61B2FE00 BE230764 2F73B400 BE2189D0 448F5600 BE21C00E 7714C400 BE229310 *...ad.#...s/..!..V.D..!....w..".*
MAIN: 03AAFE90 3CDEEC00 BE21EE9A ED945400 BE2150CE 28C54800 BE246AD9 F4EB2000 BE23B56F *...<..!..T...P!..H.(.j$.. ..o.#.*
MAIN: 03AAFEB0 65890200 BE242FBB EF259800 BE237B8E 05947400 BE23F14F CD8E7C00 BE233E84 *...e./$...%..{#..t..O.#..|...>#.*
MAIN: 03AAFED0 D9F7CD00 BE33D8D3 C26A1100 BE338B61 803E4100 BE33387E 4C050900 BE32E023 *......3...j.a.3..A>.~83....L#.2.*
MAIN: 03AAFEF0 57FFDB00 BE32824C EF5CC200 BE321EF8 E7322D00 BE25BE70 70337900 BE20504B *...WL.2...\...2..-2.p.%..y3pKP .*
MAIN: 03AAFF10 A01BB600 BE2AF7D8 E5D88C80 BE2533E6 2CADB800 BE2923A4 C3095E80 BE259640 *......*......3%....,.#)..^..@.%.*
MAIN: 03AAFF30 CF74E000 BE25CAFC C9FC4700 BE266B12 2157A200 BE25E703 C7517F00 BE276672 *..t...%..G...k&...W!..%...Q.rf'.*
MAIN: 03AAFF50 B1409E00 BE26AD40 B8F9A100 BE288E3F BE8C5E00 BE279C40 33779C00 BE2A7A0A *..@.@.&.....?.(..^..@.'...w3.z*.*
MAIN: 03AAFF70 1E1BDC00 BE28AAFD B6BCF880 BE3069B0 1428A000 BE2A1F40 8DA19380 BE314E7E *......(......i0...(.@.*.....~N1.*
MAIN: 03AAFF90 323F1300 BE2CFDC1 9B31B000 BE171F2A 6D37C580 BDE78592 CEB1CD00 BE169BBB *..?2..,...1.*.....7m............*
MAIN: 03AAFFB0 034A0D00 BDE74008 4B0EA380 BE0CC48C D1389500 BE1EB40D CA9C8000 BE0C3071 *..J..@.....K......8.........q0..*
MAIN: 03AAFFD0 0E9B5C00 BE1DFF88 CF9B2880 BDE813CD ADE93E80 BE179BA2 347EBC80 BE1F5C8D *.\.......(.......>........~4.\..*
MAIN: 03AAFFF0 3E91AE80 BE0D56CE DDC6DA80 BE187EC2 478FCC00 BDE8F752 99C41180 BE1810DD *...>.V.......~.....GR...........*
MAIN: 03AB0010 DB26F780 BDE88F57 037D8C00 BE0E6A35 092BA400 BE203F38 04C88600 BE273629 *..&.W.....}.5j....+.8? .....)6'.*
MAIN: 03AB0030 618D5C00 BE1434B9 FB532700 BE283CAA 57ED6B00 BE152D7F 1AA21200 BDF5B5D7 *.\.a.4...'S..<(..k.W.-..........*
MAIN: 03AB0050 A38F7C00 BE22CD3F 947A9800 BDF6E271 1704AF00 BE23A11E 39404000 BE134C72 *.|..?."...z.q.........#..@@9rL..*
MAIN: 03AB0070 86815E00 BE263A28 8E022300 BE22037C D219E700 BDF4DBF2 F1734900 BE245D1F *.^..(:&..#..|."..........Is..]$.*
MAIN: 03AB0090 185BD600 BE11A71B 93EF4100 BE25453E 001B8600 BE127449 2D22B500 BDF33A24 *..[......A..>E%.....It...."-$:..*
MAIN: 03AB00B0 F25B4D00 BE208AF2 E9AE9D00 BDF40560 0FAF9400 BE214215 F9DD4300 BE22B6DE *.M[... .....`........B!..C....".*
论坛里看到有朋友也遇到过问题,但是不多,请各位高手帮忙一下,很着急,跪谢!!
