小弟最近在redhat5.1中装了个abaqus6.10,最近机器重启后发现abaqus打不开了,现实问题如下:[root@node3 Commands]# sudo /Abaqus/Commands/abaqus cae -mesa
Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: cae
Server name: node3
License path: 27011@node3:
FLEXnet Licensing error:-15,570. System Error: 115 "Operation now in progress"
For further information, refer to the FLEXnet Licensing documentation,
or contact your local Abaqus representative.
Abaqus Error: Abaqus/CAE Kernel exited with an error.
然后我启动了一下 License
出现了一下结果:
[root@node3 ~]# sudo /Abaqus/License/lmgrd -c /Abaqus/abq6101.dat
6:07:49 (lmgrd) -----------------------------------------------
6:07:49 (lmgrd) Please Note:
6:07:49 (lmgrd)
6:07:49 (lmgrd) This log is intended for debug purposes only.
6:07:49 (lmgrd) In order to capture accurate license
6:07:49 (lmgrd) usage data into an organized repository,
6:07:49 (lmgrd) please enable report logging. Use Acresso Software Inc.'s
6:07:49 (lmgrd) software license administration solution,
6:07:49 (lmgrd) FLEXnet Manager, to readily gain visibility
6:07:49 (lmgrd) into license usage data and to create
6:07:49 (lmgrd) insightful reports on critical information like
6:07:49 (lmgrd) license availability and usage. FLEXnet Manager
6:07:49 (lmgrd) can be fully automated to run these reports on
6:07:49 (lmgrd) schedule and can be used to track license
6:07:49 (lmgrd) servers and usage across a heterogeneous
6:07:49 (lmgrd) network of servers including Windows NT, Linux
6:07:49 (lmgrd) and UNIX. Contact Acresso Software Inc. at
6:07:49 (lmgrd) www.acresso.com for more details on how to
6:07:49 (lmgrd) obtain an evaluation copy of FLEXnet Manager
6:07:49 (lmgrd) for your enterprise.
6:07:49 (lmgrd)
6:07:49 (lmgrd)
6:07:49 (lmgrd)
6:07:49 (lmgrd) The license server manager (lmgrd) running as root:
6:07:49 (lmgrd) This is a potential security problem
6:07:49 (lmgrd) and is not recommended.
[root@node3 ~]# 6:08:04 (lmgrd) The TCP port number in the license, 27011, is already in use.
6:08:04 (lmgrd) Possible causes:
6:08:04 (lmgrd) 1) The license server manager (lmgrd) is already running for this license.
6:08:04 (lmgrd) 2) The OS has not "cleared" this port since lmgrd died.
6:08:04 (lmgrd) 3) Another process is using this port number (unlikely).
6:08:04 (lmgrd) Solutions:
6:08:04 (lmgrd) 1) Make sure lmgrd and all vendor daemons for this
6:08:04 (lmgrd) license are not running.
6:08:04 (lmgrd) 2) You may have to wait for the OS to clear this port.
6:08:04 (lmgrd) Retrying for about 5 more minutes
6:08:22 (lmgrd) Still trying...
6:08:40 (lmgrd) Still trying...
6:08:58 (lmgrd) Still trying...
6:09:16 (lmgrd) Still trying...
6:09:34 (lmgrd) Still trying...
6:09:52 (lmgrd) Still trying...
6:10:10 (lmgrd) Still trying...
6:10:28 (lmgrd) Still trying...
6:10:46 (lmgrd) Still trying...
6:11:04 (lmgrd) Still trying...
6:11:22 (lmgrd) Still trying...
6:11:37 (lmgrd) Failed to open the TCP port number in the license.
不知道是何原因了,莫非是因为我设置了license开机启动?不能够吧,实在是不会了,求各位大神帮帮忙吧,十分着急啊啊啊啊,在此先谢过,帮帮忙,帮帮忙。我的abaqus装在了/Abaqus文件夹下。
