- 2012-3-25
abaqus 版本为6.11 我是用visual studio2008+Fortran 10.1的组合安装的~一开始是用vs2008的汉化版,就出现这种错误,后全部卸载后下载了一个vs2008express英文版本,只安装其中的c++模块,还是提示不能确定C++版本,安装过程完全参照帖子~求帮我看一下问题出在哪了
Abaqus Product Install Verification...
Thu Feb 28 15:54:56 2013
Running system requirement checks.
Requirement: Windows Server 2003, Windows XP, Windows Vista, or Windows 7
Product: All Abaqus Products
Status: Pass - Found Microsoft Windows XP Professional Service Pack
3 (Build 2600) (x86).
Requirement: Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product: Abaqus make utility with C++
Status: Fail - Unable to locate or determine the version of a C++
compiler on this system. If Microsoft Visual C++ 8.0 (.NET
2005) is installed on this system, please load the
vcvars32.bat file before running Abaqus.
Requirement: Intel Fortran Compiler 10.1 or 11.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Fortran compiler on this system. If Intel Fortran is
installed on this machine, please load ifortvars.bat before
running Abaqus.
Requirement: HP-MPI 01.01.00.00
Product: Abaqus analyses using MPI-based parallelization and
Abaqus/CFD
Status: Pass - Found HP-MPI 01.01.00.00.
Requirement: Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
3.5, or greater
Product: Abaqus Documentation
Status: Fail - Found 搜狗高速浏览器 4.0.2.6677.
Making D:\Temp\verify. All verification files will reside in this directory.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...INFORMATION
System requirements were not met. Verification
procedure will be skipped. However, user subroutines
can be run using a precompiled library set by the
variable usub_lib_dir. For more information please
see the section 3.2.2 of Abaqus Analysis User's
Manual.
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...INFORMATION
Manual.
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...PASS
Continuing...
Geometry Translator for CATIA V5
...PASS
Continuing...
Direct Geometry Import for CATIA V5
...PASS
Continuing...
Geometry Translator for I-DEAS
...PASS
Continuing...
Geometry Translator for Parasolid
...PASS
Continuing...
Geometry Translator for Pro/ENGINEER
...PASS
Continuing...
SolidWorks Associative Interface
...PASS
Continuing...
Abaqus/AMS
...PASS
Continuing...
Abaqus Interface for MSC.ADAMS
...PASS
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...PASS
Continuing...
Abaqus Interface for Moldflow
...PASS
Continuing...
...INFORMATION
Continuing...
...INFORMATION
Continuing...
Abaqus make utility with object code
...INFORMATION
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
Running thread-based parallel with 2 cpu(s)
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Abaqus/CFD
...PASS
Continuing...
Abaqus/CAE Topology Optimization Module
...INFORMATION
Product is not licensed. Verification procedure will
be skipped.
Continuing...
Clean-up...
Verification directory D:\Temp\verify has been deleted.
