- 2011-10-20
发表于 2013-5-8 17:02:30
来自 河南焦作
winnerqin 发表于 2013-5-8 14:51
我看了你的inp,发现两个错误:
一、你的接触属性里面有个错误,没有建立joint和work的接触属性 ,修改如 ...
哦,谢了,我改了下出现以下错误该怎么修正The executable D:\SIMULIA\Abaqus\6.10-1\exec\explicit.exe aborted with system error code 5. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. |
