- 26
- 2003-6-20
发表于 2013-3-29 03:22:36
来自 挪威
FATAL ERROR: E5001: NON-POSITIVE DEFINITE DETECTED AT GRID id COMPONENT n
CAUSE
A negative term has been detected on the stiffness matrix factor diagonal during decomposition.
RESOLUTION
Investigate the degree of freedom at which the Non-Positive Definite condition occurred. Also, check the Solution Processor output in the Model Results Output File for degrees of freedom with large factor diagonal ratios. A large factor diagonal ratio may indicate a mechanism. Also, check your model for isolated large stiffnesses or too few constraints. If using shell elements, either set the model parameter, K6ROT, to a value between 1.0 and 100.0, or set the parameter, SHELLRNODE, to ON. If this does not solve the problem or you are unable to locate the source of the Non-Positive Definite, consider setting the model parameter, SOLUTIONERROR, to ON. Note that solution accuracy may be degraded with this parameter set to ON. Check the EPSILON value in the Model Results Output or Results Summary File. Values greater than 0.001 indicate a possible loss of accuracy.
