- 2012-8-20
发表于 2013-4-15 19:58:06
来自 陕西西安
liuyang5299 发表于 2013-4-10 16:13
经过检查模型发现出现error5(拒绝访问)的原因是tie的设置方式有误。
我的也出现同样的问题了。Abaqus Error: The executable C:\SIMULIA\Abaqus\6.11-1\exec\package.exe
aborted with system error code 144.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
我检查的模型本身没问题,在别人的机子上都可以算,但在我的机子上就出现这样的错误。不知道啥原因 |
