- 3
- 2012-10-23
发表于 2013-5-1 17:48:47
来自 北京
478107371 发表于 2013-5-1 15:59
传了附件
from abaqus import *
upgradeMdb(
'D:/abaqus\xb9\xa4\xd7\xf7\xc4\xbf\xc2\xbc/liu san-xing/circle-6.12-1.cae',
'D:/abaqus\xb9\xa4\xd7\xf7\xc4\xbf\xc2\xbc/liu san-xing/circle.cae')
# Save by Administrator on Tue Apr 02 13:42:10 2013
from part import *
from material import *
from section import *
from assembly import *
from step import *
from interaction import *
from load import *
from mesh import *
from optimization import *
from job import *
from sketch import *
from visualization import *
from connectorBehavior import *
mdb.jobs['Couple_load'].submit(consistencyChecking=OFF, datacheckJob=True)
mdb.jobs['Couple_load']._Message(STARTED, {'phase': BATCHPRE_PHASE,
'clientHost': 'Hanjun', 'handle': 0, 'jobName': 'Couple_load'})
mdb.jobs['Couple_load']._Message(ERROR, {
'message': 'The executable pre.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.',
mdb.jobs['Couple_load']._Message(JOB_ABORTED, {
# Save by Administrator on 2013_04_05-19.47.17; build 6.12-1 2012_03_13-20.44.39 119612
最初建模的信息丢失掉了,我是没办法了。。等待有6.12 的人来解惑吧,其实我发现往往是这样,当别人的解答到了的时候,你自己也琢磨透了。自助者天助吧,楼主好运。 |
