查看: 91|回复: 4
[其他] 缩减空间不够,如何修改
发表于 2013-4-15 11:40:26 | 显示全部楼层 |阅读模式 来自 重庆
大家好,我缩减模型的时候,出现了磁盘空间的不足的错误,除了减小模型外,有没有其他办法?
*** USER FATAL MESSAGE 1250 (BIOWRT)
     STATUS =          112, FILX =    5, LOGNAME = SCR300  , NSBUF3 =    32768
     FILE = c:/scratch/block_smot_cond_v2005_cms.T2776_8.SCR300
     BLKNBR =      47327
     ERROR MESSAGE IS --
     磁盘空间不足。
     BIOMSG: ERROR    923 HAS OCCURRED IN ROUTINE IONAST  , FILE INDEX =            5.
     LOGICAL NAME IS SCR300
     FILENAME IS c:/scratch/block_smot_cond_v2005_cms.T2776_8.SCR300
     STATUS =        112
********* NASTRAN FILE TABLE *********
INDEX  LOGNAME         STREAM_ID     NAME
     1  SCRATCH         00000001      c:/scratch/block_smot_cond_v2005_cms.T2776_8.SCRATCH
     2  OBJSCR          00000002      c:/scratch/block_smot_cond_v2005_cms.T2776_8.OBJSCR
     3  MASTER          00000003      c:/scratch/block_smot_cond_v2005_cms.T2776_8.MASTER
     4  DBALL           00000004      c:/scratch/block_smot_cond_v2005_cms.T2776_8.DBALL
     5  SCR300          00000005      c:/scratch/block_smot_cond_v2005_cms.T2776_8.SCR300
     6  MASTERA         FFFFFFFA      c:/msc.software/md_nastran/md2008/i386/SSS.MASTERA
     7  MSCOBJ          FFFFFFF9      c:/msc.software/md_nastran/md2008/i386/SSS.MSCOBJ
     8  MSCSOU          FFFFFFF8      c:/msc.software/md_nastran/md2008/i386/SSS.MSCSOU
*** SYSTEM FATAL MESSAGE 4276 (IONAST)
     ERROR CODE      923 PID=   0
     USER INFORMATION: THIS ERROR MAY BE CAUSED BY EXCEEDING THE CAPACITY OF A SYSTEM RESOURCE.
     (E.G., ALLOCATED DISK IS FULL, OR MAXIMUM FILE SIZE HAS BEEN REACHED)
*** USER INFORMATION MESSAGE 4276 (IONAST)
     THE DIAG 44 RELATED A NASTRAN DUMP IS SENT TO LOG FILE.
     USER ACTION: THIS INFORMATION MAY BE USEFUL TO MSC FOR DEBUGGING YOUR PROBLEM.
                  PLEASE CONTACT MSC CLIENT SUPPORT.
我的缩减模板如下:NASTRAN BUFFSIZE=65537
NASTRAN SYSTEM(213)=1
NASTRAN SYSTEM(1)=32769
NASTRAN SYSTEM(146)=1   $ SPACE SAVING METHOD FOR LANCZOS
NASTRAN SYSTEM(151)=1   $ SPILL OF THE SRC300 PARTITION
NASTRAN SYSTEM(166)=0   $ NO ACTION AFTER SPARSE DECOMP. CONTROL
INIT MASTER(S)          $ DELETE DB AT THE END OF THE RUN
$ ------------ FILE MANAGEMENT SECTION ----------------------------------------
$INIT DBALL LOGICAL=(DB1(30gb),DB2(30gb))
$INIT SCRATCH(MEM=1000) LOGICAL=(A(100)),SCR300=(SC300(50gb))
$ASSIGN DB1='Primer_Block_SMOT_01.DBALL'
$ASSIGN DB2='Primer_Block_SMOT_02.DBALL'
$ASSIGN A='Primer_Block_cond_SMOT_0.scr'
$ASSIGN B='Primer_Block_cond_SMOT_01.scr_50gb'
模板如何修改,可以给缩减分配更多的空间?
发表于 2013-4-18 09:23:00 | 显示全部楼层 来自 辽宁沈阳
LZ你好。。小弟最近在做缩减。。请问您有没有缩减的例子?我急需啊。。能不能麻烦楼主给小弟发几个例子?邮箱629828472@qq.com
 楼主| 发表于 2013-4-18 15:17:32 | 显示全部楼层 来自 重庆
snowcube 发表于 2013-4-18 09:23
LZ你好。。小弟最近在做缩减。。请问您有没有缩减的例子?我急需啊。。能不能麻烦楼主给小弟发几个例子?邮 ...
我之前也是参照excite自带的例子做的,手上目前做的是项目,就不方面给你了。。。
发表于 2013-4-28 22:04:17 来自手机 | 显示全部楼层 来自 天津
建议你留一块足够大的硬盘200G,然后就不要再设定指定硬盘空间,即刪除命会中FILE MANAGEMENT 部分
 楼主| 发表于 2013-5-2 14:42:30 | 显示全部楼层 来自 重庆
DrLan 发表于 2013-4-28 22:04
建议你留一块足够大的硬盘200G,然后就不要再设定指定硬盘空间,即刪除命会中FILE MANAGEMENT 部分 ...
谢谢,蓝博士!
GMT+8, 2024-6-6 23:45 , Processed in 0.028777 second(s), 11 queries , Gzip On, MemCache On.
