查看: 95|回复: 0
[液压伺服系统] -基于AMESim的船用甲板起重机变幅液压系统仿真研究
发表于 2013-5-5 18:10:14 | 显示全部楼层 |阅读模式 来自 吉林长春
基于AMESim 的船用甲板起重机变幅液压系统仿真研究
张成凤龚苏生徐长生
武汉理工大学武汉430063
摘要: 分析了100 t 船用甲板起重机变幅机构液压系统原理,运用AMESim 软件对变幅机构进行了机电液
一体化仿真建模,通过与理论计算对比,验证了仿真模型的正确性。在此基础上,分析了变幅液压缸的推力变化
和其速度的平顺性,得出了考虑液压系统动态效应后的液压缸最大推力,为验证液压元件选用是否合理提供科
学依据。
关键词: 船用甲板起重机; AMESim; 机电液一体化; 平顺性
中图分类号: U664. 4 文献标识码: A 文章编号: 1001 - 0785 ( 2012) 07 - 0064 - 04
Abstract: This paper analyzes the principle of luffing mechanism hydraulic system for the 100 t marine deck
crane. The AMESim software is adopted for mechanical-electrical-hydraulic integration simulation modeling of luffing mechanism,
in order to verify the correctness of simulation model by comparing with theoretical calculation. Based on this,thrust
fluctuation and speed smoothness of the luffing hydraulic cylinder are analyzed and the maximum thrust of hydraulic cylinder,
with hydraulic system dynamic effect into consideration,is figured out,to provide scientific basis for checking for the
rationality of selected hydraulic components.
Keywords: marine deck crane; AMESim; mechanical-electrical-hydraulic integration; smoothness
GMT+8, 2024-4-17 06:31 , Processed in 0.029445 second(s), 12 queries , Gzip On, MemCache On.
