- 2012-3-11
对于CAE工程师来说,遇到规模大的项目就会比较头疼。因为前处理阶段的工作实在是在繁琐了。为了能减轻工程师繁重的工作,同时提高建模效率和准确度。我编写了一个macro,可以根据需要自动导入材料参数,自动建模属性(properties),并自动与component连接。通过使用这个macro,这阶段的工作可以节省百分之八十的时间。
演示视频
# HWVERSION_10.0build
# Purpose : The script aimed to auto_biuld a model,including automodify comps name,auto_import material,auto_create assign property.
# Help Document
# tips :1.The external file formate(txt formate):
# comp_name1 mat1 thickness(omit)
# comp_name2 mat2 thickness
# 2.The material name in the txt file,the material name in the material name,the material name in the .inp file, all of them should be same.
# 3.Just S3R/S4R/SC6R/SC8R/M3D3/M3D4/R3D3/R3D4/SOLID SECTION has been supported.
# 4.Before you apply the script,please make sure you have assigned right elements type.
# 5.Apply it with Component Brower is suggested.
Any question or suggestion please contact me!
附件: |
