查看: 221|回复: 10
[14.错误警告信息] 求解模型发现未定义的值,明明是定义了的,怎么回事?...
发表于 2013-7-7 13:16:04 | 显示全部楼层 |阅读模式 来自 北京
Undefined value found in the equation residual vector.
There are 611 degrees of freedom giving NaN/Inf in the vector for the variable mod1.c2
at coordinates: (0.003,0.0198565), (0.003,0.02), (0.003,0.0196868), (0.003,0.0195124), (0.003,0.0193378), ...
There are 611 degrees of freedom giving NaN/Inf in the vector for the variable mod1.c3
There are 643 degrees of freedom giving NaN/Inf in the vector for the variable mod1.c4
at coordinates: (0.00457808,0.02), (0.00523563,0.02), (0.006125,0.02), (0.00484491,0.0196179), (0.00440356,0.019638), ...
There are 643 degrees of freedom giving NaN/Inf in the vector for the variable mod1.c5
There are 643 degrees of freedom giving NaN/Inf in the vector for the variable mod1.cH
There are 4717 degrees of freedom giving NaN/Inf in the vector for the variable mod1.p
at coordinates: (0.00457808,0.02), (0.00490685,0.02), (0.00523563,0.02), (0.00568031,0.02), (0.006125,0.02), ...
There are 1254 degrees of freedom giving NaN/Inf in the vector for the variable mod1.phil
There are 1254 degrees of freedom giving NaN/Inf in the vector for the variable mod1.phis
发表于 2013-7-7 13:53:28 | 显示全部楼层 来自 上海
不合适的初始值,避免用0来初始化
模型上来会更明了,但不能保证能算收敛
 楼主| 发表于 2013-7-7 18:36:25 | 显示全部楼层 来自 北京
mxio 发表于 2013-7-7 13:53
不合适的初始值,避免用0来初始化
模型上来会更明了,但不能保证能算收敛 ...
谢谢,我改下试试
 楼主| 发表于 2013-7-7 18:43:30 | 显示全部楼层 来自 北京
模型在这,求指点,谢谢
 楼主| 发表于 2013-7-7 18:44:15 | 显示全部楼层 来自 北京
不合适的初始值,避免用0来初始化
亲,模型传上来了
点评
嘿嘿,行  发表于 2013-7-8 08:26
也让大神喘口气呀,哈哈哈  发表于 2013-7-7 23:09
发表于 2013-7-8 10:14:43 | 显示全部楼层 来自 上海
现在你的模型 不是你说的这个问题啊。。。
而是这几个变量值 有可能不能为负值 mod1.siec.Eeq_er1 mod1.siec.iloc_er1
而Darcy流动模块的话,推荐和组分传递一样,对求解域分别进行设置,因为它们并不相连,离散求解事实上是会遇上问题的
从整个模型来看,现在的问题主要出在siec上,请注意变量的大小和符号是否填写正确,是否合乎物理
 楼主| 发表于 2013-7-8 15:42:16 | 显示全部楼层 来自 北京
而是这几个变量值 有可能不能为负值 mod1.siec.Eeq_er1 mod1.sie ...
谢谢之前那个未定义的错误,软件自己解决了,我只是多点了几下计算而已。这个负值问题,上一次也出现了,我不知道点了哪个地方,就没有报错。上次计算结果趋势不对,这次只是重复上次工作,出现这些问题不知道如何下手。敢问一下,COMSOl是不是不靠谱啊?
发表于 2013-7-8 16:14:32 | 显示全部楼层 来自 上海
是你自己设置有问题。。。 估计是你参数化扫描的参数值 不合适
虽然它经常算不了,但是报错的提示还是比较靠谱的
 楼主| 发表于 2013-7-9 09:57:08 | 显示全部楼层 来自 北京
虽然它经常算不了,但是报错的提示还是比较 ...
恩,好吧。多多学习。谢谢
发表于 2014-4-11 20:08:22 | 显示全部楼层 来自 北京
同样遇到问题了,新手求指导如何解决
发表于 2014-8-21 16:34:23 | 显示全部楼层 来自 湖北武汉
把study删掉,全部自己手动定义每个步骤。我就是这个问题,不知道你们有没有用。貌似项目初始化的时候不要选择预设study为好
GMT+8, 2024-4-25 19:10 , Processed in 0.041681 second(s), 16 queries , Gzip On, MemCache On.
