查看: 106|回复: 0
[14.错误警告信息] Error in using soil plasticity module
发表于 2013-7-22 21:09:41 | 显示全部楼层 |阅读模式 来自 美国
想用Mohr-Coulomb塑性准则,但是老是出现这个错误,有人能说一下怎么解决这个问题么?
查了一下comso的错误data
错误编号:1150
http://www.comsol.com/support/knowledgebase/1150/
1. Problem Description
Why do I get the error Failed to compute elastoplastic strain variables when using plasticity/concrete/soil plasticity?
2. Solution
This happens because the elastoplastic element cannot evaluate a plastic step if the current stress state is outside of the yield surface. There are two situations where you may encounter this problem:
In the first load step
The elastoplastic element fails to evaluate the consistence conditions (due to either loads, displacements, initial stress/strains), and it fails to compute the first elastic-predictor step. That is, your initial state, e.g. assumed in-situ stresses in a geomechanical problem are outside the yield surface.
During postprocessing
When results are requested at other positions than the Gauss points, the elastoplastic element actually performs a stress computation. If the gradients of the elastoplastic strains are a large within an element this computation may fail. If this happens, use the Gauss point variables such as solid.sGpx instead of general variables like solid.sx.
GMT+8, 2024-4-25 04:09 , Processed in 0.029262 second(s), 15 queries , Gzip On, MemCache On.
