ANSYS15.0,仅供个人学习!商业用途,请购买正版!
安装方法如下:
Written by 师访.
Step 1 If you have installed an earlier version of ANSYS, please make sure to uninstall it, the ANSYS License Manager in especial (This can be done by deleting the "\ANSYS Inc\Shared Files" folder, if it can not be deleted, then end the related processes in the task manager and try again!).
Step 2 Install only ANSYS products on disk C, do not install ANSYS License Manager. When ask for Hostname 1, just select “Skip this configuration”!
Step 3 After installation, Put ansyslmd.ini and license.dat into the following directory:
C:\Program Files\ANSYS Inc\Shared Files\Licensing\
If you install ANSYS on the other disk, such as disk D, then you just need to modify the second line of the ansyslmd.ini, which in detail is as follows:
LICKEYFIL=D:\Program Files\ANSYS Inc\Shared Files\Licensing\license.dat
Step 4 That's all. If you have any question, just contact me by qq: 1549221758, 师访,中国矿业大学(徐州)
帖子汇总: |
