楼主刚搜索到一个激光多道焊接的例子,但是还是有点小问题,大家拿回去运行,调试一下,看看如何改善!记得做人要厚道哦
/UNITS,SI
/CONFIG,NRES,10000
/PREP7
ET,1,SOLID70 !单元类型,1表示此单元编号为1
MP,DENS,1,7930 !定义材料密度
MP,C,1,502 !定义材料比热
mptemp,1,20,100,500
mpdata,kxx,1,1,12.1,16.3,21.4 !kxx热导系数
/VIEW,1,1,1,1
!*************定义基板尺寸***********
lx=0.1
lz=0.1
ly=0.006 !基板大小
!*************定义焊接参数***********
layer=2 !总的焊接道数
lap=1/3 !两道之间搭接量
weld=0.01 !每道焊道宽度
wweld=layer*weld-(layer-1)*lap*weld !焊道的总宽度
wheight=0.004 !焊道的高度
remain=0.03
LSIZE=0.002
V=0.008 !速度
pi=3.1415926
U=25
I=180
Q=U*I !电源有效功率(在此,可以对Q通过UI来调整)
R=0.006 !电源有效热半径
effect=0.8
Qmax=effect*Q/(pi*R*R) !中心处最大热流
tm=(lx-2*remain)/V !一道的总时间
tinc=LSIZE/V !每小段的时间间隔
!*****************建立模型,生成网格**************
block,0,lx,0,ly,0,lz !创建一个块体积,可以根据基板尺寸调整坐标
wpoff,remain,ly,(lz-wweld)/2 !随着坐标系轴的变化平移工作平面
block,0,lx-2*remain,0,wheight,0,wweld
vsbw,all,,delete !对block布尔运算
wpoff,,,wweld
vsbw,all,,delete
wprota,90,90 !转动工作面
vsbw,all,,delete
wpoff,,,lx-2*remain
vsbw,all,,delete
save
vglue,all !粘合所有的几何体
lsel,s,,,9,12,1
lsel,a,,,25,26,1
lsel,a,,,30
lsel,a,,,32
lsel,a,,,38
lsel,a,,,45
lsel,a,,,59
lsel,a,,,73
lesize,all,0.005,,,0.2,,,,1
allsel,all
lsel,s,,,13,16,1
lsel,a,,,19,21,1
lsel,a,,,23,24,1
lsel,a,,,34
lsel,a,,,41,44,1
lsel,a,,,63,64,1
lsel,a,,,77,78,1
lsel,a,,,81,82,1
lesize,all,0.001,,,1,,,,1
allsel,all
lsel,s,,,1
lsel,a,,,3,6,1
lsel,a,,,8
lsel,a,,,27
lsel,a,,,29
lsel,a,,,31
lsel,a,,,33
lsel,a,,,35
lsel,a,,,37
lsel,a,,,40
lsel,a,,,50
lsel,a,,,53
lsel,a,,,55
lsel,a,,,62
lsel,a,,,67
lsel,a,,,69
lsel,a,,,85
lesize,all,0.002,,,1,,,,1
allsel,all
lsel,s,,,46
lsel,a,,,86
lsel,a,,,88
lesize,all,0.001,,,5,,,,1
allsel,all
vsweep,all
/PNUM,DEFA
EPLOT
fini
!*******************进入后处理器*********************
/solu
antype,trans,new
!nlgeom,on
timint,0,struct
timint,1,therm
timint,0,mag
timint,0,elect
tref,25
nropt,auto
autos,on
kbc,0
pred,on
lnsrch,on
!************杀死焊缝去单元***********
nsel,s,loc,y,ly,ly+wheight
esln,s,1
ekill,all
allsel,all
esel,s,live
eplot
!**********施加对流载荷*************
esel,s,live
nsel,s,loc,z,0
nsel,a,loc,z,lz
nsel,a,loc,x,0
nsel,a,loc,x,lx
sf,all,conv,10,25
!************定义数组维数**********
MAX_TIME=1+tm/tinc
!MAX_X=1+(lx-2*remain)/LSIZE
MAX_X=1+lx/LSIZE
MAX_Z=1+lz/LSIZE
!*************定义table数组
*DIM,heatflux,TABLE,MAX_X,MAX_Z,MAX_TIME,X,Z,TIME
*do,n,1,layer,1
m=mod(n,2) !返回n/2的余数部分
*if,m,eq,1,then
!n=1
*DO,K,1,MAX_TIME,1
*DO,I,1,MAX_X,1
heatflux(I,0,K)=(I-1)*LSIZE
*ENDDO
*DO,J,1,MAX_Z,1
heatflux(0,J,K)=(J-1)*LSIZE
*ENDDO
*DO,I,1,MAX_X,1
*DO,J,1,MAX_Z,1
XCENTER=remain+V*(K-1)*tinc
ZCENTER=2*(n-1)*weld/3+(lz-wweld)/2+weld/2
DISTANCE=SQRT(((I-1)*LSIZE-XCENTER)**2+((J-1)*LSIZE-ZCENTER)**2)
*IF,DISTANCE,LE,R,THEN
heatflux(I,J,K)=Qmax/EXP(2*DISTANCE**2/(R**2))
*ELSE
heatflux(I,J,K)=0
*ENDIF
*ENDDO
*ENDDO
heatflux(0,0,K)=(K-1)*tinc
!**********激活单元*********
esel,s,live
nsel,s,loc,x,xcenter-0.002,xcenter+0.001
nsel,r,loc,z,zcenter-weld/2,zcenter+weld/2
nsel,r,loc,y,ly,ly+wheight
esln,s,0
ealive,all
allsel,all
!**********施加热流载荷**********
esel,s,live
nsel,s,loc,Y,ly
sf,all,hflux,%heatflux%
allsel,all
!************求解*****************
time,(n-1)*(tm+tinc)+k*lsize/v
nsubst,2
SOLVE
!*************删除热流载荷***********
nsel,s,loc,y,ly
sfdele,all,hflux
allsel,all
esel,s,live
eplot
OUTRES,ALL,ALL,
/PSF,HFLUX,,2
/REPLOT
OUTRES,ALL,ALL,
*ENDDO
*else
!n=2
*DO,K,1,MAX_TIME,1
*DO,I,1,MAX_X,1
*ENDDO
*DO,J,1,MAX_Z,1
*ENDDO
*DO,I,1,MAX_X,1
*DO,J,1,MAX_Z,1
XCENTER=lx-remain-V*(K-1)*tinc
*ELSE
heatflux(I,J,K)=0
*ENDIF
*ENDDO
*ENDDO
esel,s,live
nsel,s,loc,x,xcenter-0.001,xcenter+0.002
esln,s,0
ealive,all
allsel,all
esel,s,live
nsel,s,loc,Y,ly
allsel,all
nsubst,2
SOLVE
nsel,s,loc,y,ly
sfdele,all,hflux
allsel,all
esel,s,live
eplot
OUTRES,ALL,ALL,
/PSF,HFLUX,,2
/REPLOT
OUTRES,ALL,ALL,
*ENDDO
*endif
*enddo
FINISH
