abaqus用户子程序安装(2014-3-5) 1.XP系统和Windows7 (32位)均适用 2.需要安装的软件(3种软件): Microsoft Visual studio 2008(英文版)+ Intel(R)Fortran Compiler Professional 11.1.038 + Abaqus 6.10-1 3.安装顺序: ① MicrosoftVisual studio 2008(英文版)+ Intel(R) Fortran Compiler Professional11.1.038 + Abaqus 6.10-1 ② Abaqus6.10-1 + Microsoft Visual studio 2008(英文版)+ Intel(R) Fortran Compiler Professional11.1.038 说明:1.以上两种安装顺序均可。 2.我的Abaqus 6.10-1和Microsoft Visual studio 2008(英文版)安装在D盘,Intel(R) FortranCompiler Professional 11.1.038默认安装在C盘。 4. abaqus与fortran成功链接方法: ①寻找两个.bat 文件所在位置:
(Ⅰ)Abaqus 6.10-1的.bat 文件路径查找:开始→所有程序→Abaqus 6.10-1→Abaqus Verification(右键) →属性:在属性中选择“快捷方式”,目标(T)中的内容(我的计算机)为:D:\SIMULIA\Abaqus\Commands\abq6101.bat-verify-all-log &¬epad.exe verify.log || notepad.exe verify.log file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtml1/01/clip_image002.jpg (Ⅱ)Intel(R) FortranCompiler Professional 11.1.038的.bat 文件路径查找:开始→所有程序→Intel(R) Software Development Tools→Intel(R) Visual Fortran Compiler Professional 11.1.038→Fortran Build Environment for applications running onIA-32 ,(右键) →属性:在属性中选择“快捷方式”,目标(T)中的内容(我的计算机)为: D:\Windows\System32\cmd.exe/E:ON/V:ON/K”” C: \ Program Files \Intel\Compiler\\11.1\038\bin\iforvars.bat”ia32” file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtml1/01/clip_image004.jpg file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtml1/01/clip_image006.jpg ②找到两个.bat 文件并编辑打开看里面的内容: (Ⅰ)Abaqus6.10-1的.bat文件路径为:D:\SIMULIA\Abaqus\Commands\abq6101.bat file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtml1/01/clip_image008.jpg,右键编辑打开file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtml1/01/clip_image010.jpg,里面的内容为: @echo off "D:\SIMULIA\Abaqus\6.10-1\exec\abq6101.exe"%* (Ⅱ)Intel(R)Fortran Compiler Professional 11.1.038的.bat 文件路径为: C: \ Program Files \Intel\Compiler\\11.1\038\bin\ia32\iforvars_ia32.bat file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtml1/01/clip_image012.jpg右键编辑打开file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtml1/01/clip_image014.jpg,里面的内容为: @echo off Rem Rem Copyright (C) 1985-2009 Intel Corporation. All rightsreserved. Rem Rem The informationand source code contained herein is the exclusive property Rem of IntelCorporation and may not be disclosed, examined, or reproduced in Rem whole or inpart without explicit written authorization from the Company. Rem Rem Intel(R) VisualFortran Compiler Professional Build Environment for applications running onIA-32 echo. echo Intel(R)Visual Fortran Compiler Professional for applications running on IA-32, Version11.1.038 echo Copyright (C)1985-2009 Intel Corporation. All rights reserved. echo. if {%1} EQU{vs2008} ( @call "D:\Program Files\Microsoft VisualStudio 9.0\Common7\Tools\vsvars32.bat" ) else ( if {%1} EQU{vs2005} ( @call echo. ) else ( @call "D:\Program Files\MicrosoftVisual Studio 9.0\Common7\Tools\vsvars32.bat" ) ) title Intel(R)Visual Fortran Compiler Professional for applications running on IA-32, Version11.1.038 build environment echo. SETIFORT_COMPILER11=C:\Program Files\Intel\Compiler\11.1\038 SETINTEL_LICENSE_FILE=C:\Program Files\Common Files\Intel\Licenses SET PATH=%IFORT_COMPILER11%\Bin\ia32;%PATH% SET LIB=%IFORT_COMPILER11%\Lib\ia32;%LIB% SETINCLUDE=%IFORT_COMPILER11%\Include;%IFORT_COMPILER11%\Include\ia32;%INCLUDE% ③将ifortvars_intel64.bat文件内容复制粘贴到abaq6101.bat文件开头。如下: @echo off Rem Rem Copyright (C) 1985-2009 Intel Corporation. All rightsreserved. Rem Rem The informationand source code contained herein is the exclusive property Rem of IntelCorporation and may not be disclosed, examined, or reproduced in Rem whole or inpart without explicit written authorization from the Company. Rem Rem Intel(R) VisualFortran Compiler Professional Build Environment for applications running onIA-32 echo. echo Intel(R)Visual Fortran Compiler Professional for applications running on IA-32, Version11.1.038 echo Copyright (C)1985-2009 Intel Corporation. All rights reserved. echo. if {%1} EQU{vs2008} ( @call "D:\Program Files\Microsoft VisualStudio 9.0\Common7\Tools\vsvars32.bat" ) else ( if {%1} EQU{vs2005} ( @call echo. ) else ( @call "D:\Program Files\MicrosoftVisual Studio 9.0\Common7\Tools\vsvars32.bat" ) ) title Intel(R)Visual Fortran Compiler Professional for applications running on IA-32, Version11.1.038 build environment echo. SETIFORT_COMPILER11=C:\Program Files\Intel\Compiler\11.1\038 SETINTEL_LICENSE_FILE=C:\Program Files\Common Files\Intel\Licenses SET PATH=%IFORT_COMPILER11%\Bin\ia32;%PATH% SET LIB=%IFORT_COMPILER11%\Lib\ia32;%LIB% SETINCLUDE=%IFORT_COMPILER11%\Include;%IFORT_COMPILER11%\Include\ia32;%INCLUDE% @echo off "D:\SIMULIA\Abaqus\6.10-1\exec\abq6101.exe"%* ④验证子程序是否安装成功:开始→所有程序→Abaqus6.10-1→AbaqusVerification(双击),我的结果为: Abaqus Product Install Verification... Wed Mar 5 11:05:58 2014 Running system requirement checks. Requirement: Windows Server 2003, Windows XP, Windows Vista, or Windows 7 Product: All Abaqus Products Status: Pass - Found Microsoft Windows XPProfessional Service Pack 3 (Build 2600) (x86). Requirement: Microsoft Visual C++ 9.0 (2008), or 10.0(2010) Product: Abaqus make utility with C++ Status: Pass - Found MicrosoftVisual C++ 9.0.21022.8 Requirement: Intel Fortran Compiler 10.1 or 11.1 Product: Abaqus make utility with Fortran andAbaqus with user subroutines Status: Pass - Found Intel Fortran Compiler 11.1Build 20090624 Package ID w_cprof_p_11.1.038. Requirement: HP-MPI 01.01.00.00 Product: Abaqus analyses using MPI-basedparallelization and Abaqus/CFD Status: Fail - Unable to locate a supportedMPI implementation on this system. For moreinformation on the MPI-based parallel functionality, see the section'Parallel processing modes in Abaqus' in the Abaqus AnalysisUser's Manual. Requirement: Internet Explorer 6.0 or 7.0 or 8.0,Firefox 2.0 or 3.0 or 3.5, or greater Product: Abaqus Documentation Status: Pass - Found Internet Explorer8.0.6001.18702 Making D:\Temp\verify. All verificationfiles will reside in this directory. ----------------------------------------------------------------------------- Abaqus/Standard ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Standard with user subroutines ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Explicit (single precision) ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Explicit (double precision) ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Explicit with user subroutines(single precision) ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Explicit with user subroutines(double precision) ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Viewer ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/CAE ...PASS Continuing... ----------------------------------------------------------------------------- Geometry Translator for CATIA V4 ...PASS Continuing... ----------------------------------------------------------------------------- Geometry Translator for CATIA V5 ...PASS Continuing... ----------------------------------------------------------------------------- Direct Geometry Import for CATIA V5 ...PASS Continuing... ----------------------------------------------------------------------------- Geometry Translator for I-DEAS ...PASS Continuing... ----------------------------------------------------------------------------- Geometry Translator for Parasolid ...PASS Continuing... ----------------------------------------------------------------------------- Geometry Translator for Pro/ENGINEER ...PASS Continuing... ----------------------------------------------------------------------------- SolidWorks Associative Interface ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/AMS ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus Interface for MSC.ADAMS ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Standard parametric studies ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Explicit parametric studies ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Design ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus Interface for Moldflow ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus make utility with Fortran ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus make utility with C++ ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus make utility with object code ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus scripting interface ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus analyses using parallelization Running thread-based parallel with 2 cpu(s) Abaqus/Explicit domain-level parallel ...PASS Abaqus/Standard direct solver ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/Foundation ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus noGUI (CAE/Viewer) ...PASS Continuing... ----------------------------------------------------------------------------- Abaqus/CFD ...INFORMATION System requires were not met. Verification procedure will be skipped Continuing... ----------------------------------------------------------------------------- Clean-up... Verification directory D:\Temp\verify hasbeen deleted.
