查看: 57|回复: 0
[RADIOSS Block] minimum core问题,
发表于 2014-3-20 17:02:05 | 显示全部楼层 |阅读模式 来自 河北保定
The amount of memory allocated for the run is 2638 MB, which
is larger than the specified (or the default) RAM= 1000 MB.
This run will use minimum core processing in the solver.
我在计算的时候遇到这问题,minimum core处理是什么意思啊?影响计算速度么?我电脑内存32 G,怎么改这个default RAM 1000M啊? 有的说设置SYSSETTING,我看了一下,没看懂,谁能帮助一下?
SYSSETTING(OS_RAM=320,OS_RAM_INIT=32,CARDLENGTH=80)
SYSSETTING(RAM_SAFETY=1.0,RAMDISK=200,SYNTAX=ALLOWINT)
SYSSETTING(SPSYNTAX=CHECK,LOADTEMP=0,NPROC=1)
SYSSETTING(PLOTELID=UNIQUE)
SYSSETTING(SCRFMODE=UNBUFFERED)
GMT+8, 2024-6-2 20:57 , Processed in 0.026256 second(s), 11 queries , Gzip On, MemCache On.
