- 2012-3-3
帮助文件上写:can be used in planar, axisymmetric, and three-dimensional geometries;
我从帮助上下载铜棒冲击刚体板的仿真,做出的结果和文档不一样.而且帮助上下载的也计算不了.
报错为:***ERROR: The requested number of domains cannot be created due to
restrictions in domain decomposition. The following limitations may
be helpful in understanding this behavior:
1. Contact pair requires that the surface nodes be in the same domain.
In the case of kinematic contact, elements associated with
the surface facets must also be in the same domain.
2. An adaptive mesh domain must be contained within a single
parallel domain. Nodes on the boundary between an adaptive
mesh domain and a nonadaptive domain must not be shared
with other parallel domains.
3. All the nodes involved in a kinematic constraint must
be in the same domain and must not be shared with other domains.
4. Nodes associated with beam elements whose center of mass
does not coincide with the location of the beam node or which
use the *BEAM ADDED INERTIA option must be within a single domain.
我想可能是下面两方面的错误:
1)contact pair 把铜棒的底面和圆周面都建成一个SURFCE就会报错,用全局接触能算.
2)但用全局接触时ALE就不起什么作用.如下是用全局接触算出的图片
//前不久我做一个卡扣扣入橡胶表带的分析,橡胶单元节点挂住,变形严重.所以就想用ALE能否解决这个问题?
另外,我看论坛中都是用在2D单元的,我用3D单元ALE方法好像没什么作用呢?
