- 2014-5-21
JMatPro 8.0版本出来了~~~
以下是V8.0的新增功能。
- new modelling of flow stress for Fe, Ni, Co and Ti basedalloys
- advanced TTT diagram calculation for General Steels withintermediate transformation curves
- calculation of aluminium high temperature strength after T5/T6and further heat treatment
- calculation of magnetic permeability of steels in function ofapplied magnetic field
- flow stress analysis for individual phases in General Steels(Austenite, Ferrite, Pearlite, Bainite and Martensite)
- new Fe thermodynamic database with new phase KAPPA carbide andvarious improvements on other phases
- adjustment of thermal conductivity for Aluminium alloyscontaining Cu and Zn
- revised influence of Aluminium and Manganese in the calculationof the martensite transition temperature in steels
- addition of second isothermal stage in Ni alloys heattreatment
- new Ni thermodynamic database (remodelled ETA DELTA GAMMA"phases and A4D_B1 renamed to NI4MO
- new module for Cu alloys with thermodynamics andthermo-physical properties
- calculation of physical properties evolution duringreaustenitisation of steels
- "Welding Cycle" calculation now use heating rate and thereaustenitisation calculation for the calculation of propertiesduring heating
- calculation of the evolution of grain size andrecrystallisation fraction during hot rolling of steels
- compositions can now be imported from a spreadsheet
- export files to Thercast now include flow stress when it ispossible to calculate
- export to Sysweld software for General Steels
- export of data to Novacast casting software
- new dongle licensing framework
- more robust thermodynamic solver
- the compositions list is now automatically sorted inalphabetical order
- addition of summary panels for input when heat treatment filesare used in calculations
- the maximum number of cycles in the "fatigue related"calculation can now be user defined
- pictures can now be copied to the clipboard
- fixed data collection in batch mode
- fixed choice of elements for x-axis missing in "profile"calculation
- numerous small improvements in existing calculations anduser-interface
