- 2013-11-25
发表于 2014-7-27 19:30:05
来自 河北
The latest releases of Abaqus, fe-safe, Isight/SEE and Tosca provide powerful new capabilities and enhancements that will improve your simulation productivity, efficiency and performance-based decision making.
The Abaqus Unified FEA product suite offers powerful and complete solutions for both routine and sophisticated engineering problems covering a vast spectrum of industrial applications. For example, in the automotive industry engineering work groups can consider full vehicle loads, dynamic vibration, multibody systems, impact/crash, nonlinear static, thermal coupling, and acoustic-structural coupling using a common model data structure and integrated solver technology. Best-in-class companies are taking advantage of Abaqus Unified FEA to consolidate their processes and tools, reduce costs and inefficiencies, and gain a competitive advantage.
Customers accessing Abaqus 6.14 through the Extended Packaging (QXT) also have access to Tosca Structure 8.1, Tosca Fluid 2.4, Isight 5.9, and fe-safe 6.5 functionality.
Abaqus 6.14 highlights include:
• Contact
o Edge-to-edge contact for general contact in Abaqus/Standard
o Improved contact at complex intersections in Abaqus/Explicit
• Output
o Abaqus output database in SIM format for use on the 3DEXPERIENCE Platform
• AMS eigensolver
o GPGPU acceleration performance improvements
o Constraint equation handling performance improvements
o Coupled structural-acoustic eigenmodes extraction
• Materials
o Parallel rheological framework enhancements
o Local coordinate system for material in Eulerian elements
o Use of anisotropic materials in Eulerian elements
o Initial conditions on damage initiation
• Crack Modeling and Propagation Jobs
o XFEM enhancements
• Performance
o GPGPU accelerated direct equation solver
o User control of domain decomposition
o ODB API enhancements
• Fluid analysis
o K-e realizable turbulence model
o Prescribed conditions for turbulence models
• Co-simulation
o SIMULIA Co-Simulation Engine API general availability
• Optimization (see SIMULIA Tosca Optimization Technology section for details)
o Sizing optimization
o Optimization with multiple nonlinear load scenarios
o Combining output database files
o New design responses
• Abaqus/CAE geometry and modeling
o Bidirectional support for CATIA V6 Associative interface
o Associate geometric faces with mesh
o Switch context for model instances
• Visualization
o Display group operations on linked viewport
o Free body cut summation at area centroid
o X-Y data from free bodies defined on view cuts
o Free body reports from multiple frames
The Tosca optimization suite provides fast and powerful structural and flow optimization solutions based on FEA and CFD simulations. Tosca optimization suite consists of two products: Tosca Structure is for optimized structural designs, and Tosca Fluid provides optimized fluid flow design concepts.
Tosca Structure delivers powerful optimization solutions for design of lightweight, stiff, and durable parts and assemblies within shorter development cycles to maximize performance, minimize material and weight, and discover new design possibilities.
Tosca Fluid enables topology optimization-driven design concepts for fluid flow systems and components. Use its capabilities to create innovative design ideas automatically for a defined flow task and available package space. Tosca Fluid’s unique technology helps you achieve the highest flow performance, quality and eco-efficiency.
Customers accessing Tosca through the Extended Packaging (QXT) also have access to Abaqus 6.14, Isight 5.9, and fe-safe 6.5 functionality.
Tosca highlights include:
• Licensing
o Tosca technology within Extended Token (QXT)
o “Tosca for Abaqus” (QOX) to replace ATOM
o “Tosca Optimization Pack” (QOO) for non-SIMULIA customers using 3rd party tools
o “Abaqus Compatibility Pack” (S6A) for 3DExperience customers
o “SIMULIA Academic Teaching Edition” (Q9T) for academic users
o “Extended Research” (QRX) for researchers
• Tosca Structure 8.1 enhancements
o Optimization Module within Abaqus/CAE since Abaqus 6.13-AP2
o Full support of fe-safe fatigue analysis to use in shape optimization
o Shape optimization now available within Tosca Extension for ANSYS Workbench
o Improved Tosca Structure internal data handling
o Eased stiffness optimization and adding consideration of thermal loading
o Enhanced mesh smoothing for shape optimization using element correction
o Improved soft delete algorithms for highly nonlinear geometrical modeling
• Tosca Fluid 2.4 enhancements
o Tosca Fluid accessible via Extended Tokens (QXT)
o Supported CFD solver interfaces
o Improved capabilities of Tosca Fluid.smooth
fe-safe is a powerful, comprehensive and easy-to-use suite of fatigue analysis software for finite element models. It is used alongside commercial FEA softwares, to calculate:
• where fatigue cracks will occur;
• when fatigue cracks will initiate;
• the factors of safety on working stresses (for rapid optimization)
• the probability of survival at different service lives (the ‘warranty claim’ curve)
• whether cracks will propagate
fe-safe is used by leading companies in automotive, heavy truck, off-highway, marine, defense, offshore, power generation, wind energy, medical engineering and many other industries. Typical application areas include the analysis of machined, forged and cast components in steel, aluminum and cast iron, high temperature components, welded fabrications and press-formed parts.
Customers accessing fe-safe through the Extended Packaging (QXT) also have access to Tosca Structure 8.1, Tosca Fluid 2.4, Isight 5.9, and Abaqus 6.14 functionality.
fe-safe 6.5 highlights include:
• fe-safe licensing enhancements
• Vibration fatigue
• Theory of Critical Distances (TCD)
• Distributed processing
• Improved material management
Isight provides simulation process automation and design optimization solutions that enable users to reduce analysis time and costs while improving product performance, quality and reliability. When used in conjunction with the SIMULIA Execution Engine (SEE), Isight customers can build a web-based framework for distributing the execution of simulation processes across the enterprise to optimize computing resource and to enable collaboration among geographically distributed users. For Isight, the release further enhances certain components connecting to 3rd party tools and installation procedure. For the SIMULIA Execution Engine, this release enhances infrastructure providing better control over execution of complex processes.
Customers accessing Isight through the Extended Packaging (QXT) also have access to Tosca Structure 8.1, Tosca Fluid 2.4, Abaqus 6.14, and fe-safe v6.5 functionality.
Isight 5.9 highlights:
• Configure DOE from Excel
• Component Updates
o Add support for CATIA V5 R23 and R24
o Enhancement for Mathcad component
o Enhancement for ANSYS Workbench 14.0, 14.5, and 15.0
• Personal SEE bundled in Isight
SEE 5.9 highlights include:
• SEE based on TomEE and Derby
• Configuration of Weblogic Secure B2B in documentation |
