SVN version of Opensees: 5841 OS: Windows 7
Visual studio 2012
The compileration use the attached Microsoft Visual Studio Solution OpenseesVC6.sln directly.
1. Download and install ActiveTcl 8.5 for x86. ActiveTcl 8.6 deletes some class used by Opensees. 64bit ActiveTcl is also not available, at least without much modification in OpenseesVC6.sln.
2. You need add the position of Tcl include and library folder by hand for compilering some of the Opensees library.
3. You need close SAFESEH in linker option for compilering some of the Opensees library.
4. Following files are lost from the compiler list, you must add them by hand.
Pileto3D.cpp, FRPConfinedConcrete.cpp, YamamotoBiaxialHDR.cpp
5. The file /win32/VC2005errno.cpp is also needed to be added in compile list otherwise you would get unrresolved _errono error.
That's all.
原文请见
http://hillyuan.blogspot.jp/2014/11/build-opensees-in-visual-studio-2012.html
