/batch,list
/filenam, 2D
/title, 2D
/prep7
/com,
shpp,off
et,1,13 ! PLANE13, AZ dof
et,2,13
ftime=3 ! final time
tinc=1 ! time increment for harmonic analysis
time=0 ! initialize time
delt=0.01 ! maximum delta time step
emunit,mks ! set magnetic units
mp,murx,1,1 ! air relative permeability
mp,murx,3,1 ! coil relative permeability
mp,dens,3,8960
mp,RSVX,3,2e-5 ! resistivity
mptemp,1,25.5,160,291.5,477.6,635,698 ! temps for relative permeability
mptemp,7,709,720.3,742,761,1000
mpdata,murx,2,1,200,190,182,161,135,104 ! steel relative permeability
mpdata,murx,2,7,84,35,17,1,1
mptemp
mptemp,1,0,125,250,375,500,625 ! temps for resistivity
mptemp,7,750,875,1000
mpdata,rsvx,2,1,.184e-6,.272e-6,.384e-6,.512e-6,.656e-6,.824e-6
mpdata,rsvx,2,7,1.032e-6,1.152e-6,1.2e-6 ! steel resistivity
mptemp
mptemp,1,20,100,200,300,400,500 ! 定义与磁导率对应的温度
mptemp,7,600,700,720,742,760,800
mptemp,13,900,1000
mpdata,kxx,2,1,46.71,46.06,45.59,43.47,40.7,37.67
mpdata,kxx,2,7,34.63,31.66,30.57,29.05,27.57,23.92
mpdata,kxx,2,13,26.32,27.76 !定义钢坯料热传导系数
mp,dens,2,7850
mp,c,2,465
mp,emis,2,.68 ! emissivity
/AUX15 !A2
IOPTN,IGES,SMOOTH
IOPTN,MERGE,YES
IOPTN,SOLID,YES
IOPTN,SMALL,YES
IOPTN,GTOLER, DEFA
IGESIN,'special-shaped coils01','IGS','Desktop\'
APLOT
/VIEW,1,,,1 !front
/ANG,1
/REP,FAST
FINISH
/PREP7
RECTNG,-20,20,-20,20, !A4
RECTNG,-18,18,-18,18,
ASBA, 1, 3
RECTNG,-50,50,-50,50, !A3,A5,A6
FLST,3,2,5,ORDE,2
FITEM,3,2
FITEM,3,4
ASBA, 1,P51X
ASBA, 1, 2
FINISH
/AUX15 !A2
IOPTN,IGES,SMOOTH
IOPTN,MERGE,YES
IOPTN,SOLID,YES
IOPTN,SMALL,YES
IOPTN,GTOLER, DEFA
APLOT
/VIEW,1,,,1 !front
/ANG,1
/REP,FAST
FINISH
/PREP7
FLST,5,3,5,ORDE,3 !define mesh attributes
FITEM,5,3
FITEM,5,5
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 1, , 2, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 4
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 2, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 2
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 3, , 2, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SMRT,1
MSHAPE,0,2D
MSHKEY,0
FLST,5,5,5,ORDE,2
FITEM,5,2
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
NSEL,S,LOC,X,-50
NSEL,A,LOC,X,50
NSEL,A,LOC,Y,-50
NSEL,A,LOC,Y,50
D,all, ,0, , , ,AZ
ESEL,S,MAT,,3
FINISH
/SOL
BFE,all,JS,1, , ,114270, ,
ALLSEL,ALL !be necessary
/solu
antyp,harm
harfrq,9500
HROPT,FULL
HROUT,ON
EQSLV, ,1e-008,
physics,write,emag
solve
SAVE
finish
/prep7
lsclear,all ! clear all b.c.'s and options
et,1,55 ! PLANE55 thermal element
et,2,0
et,3,0
finish
/solu
antype,trans
toffst,273
tunif,50 ! initial uniform temperature
cnvtol,heat,1 ! convergence tolerance
kbc,1 ! step loads
trnopt,full
autos,on ! auto time-stepping
deltim,0.01,0.005,delt,on ! time step control
outres,basic,all ! save all load step information
physics,write,thermal ! write thermal physics file
finish
*SET,time,0
*do,i,1,ftime/tinc ! solution *do loop
*SET,time,time+tinc ! increment time
physics,read,emag ! read emag physics file
/solu
*if,i,eq,1,then
tunif,50 ! initial temperature
*else
ldread,temp,last,,,,,rth ! read thermal analysis temperatures
*endif
solve ! solve harmonic analysis
finish
physics,read,thermal ! read thermal physics file
/assign,esav,therm,esav ! redirect files for use in thermal restart
/assign,emat,therm,emat
/solu
*if,i,gt,1,then
antype,trans,rest ! thermal restart
*endif
time,time ! time at end of thermal run
esel,s,mat,,2 ! select billet region
ldread,hgen,,,,2,,rmg ! apply coupled joule heating load from emag
esel,all
solve
finish
/assign,esav ! reassign files to default
/assign,emat
*enddo ! end of solution looping
finish
save
