查看: 105|回复: 2
[子程序] abaqus子程序GAPCON的使用问题
发表于 2014-12-18 09:45:55 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
SUBROUTINE GAPCON(AK,D,FLOWM,TEMP,PREDEF,TIME,CINAME,SLNAME,     1 MSNAME,COORDS,NOEL,NODE,NPRED,KSTEP,KINC)C      INCLUDE 'ABA_PARAM.INC'C      CHARACTER*80 CINAME,SLNAME,MSNAMEC      DIMENSION AK(5),D(2), FLOWM(2), TEMP(2), PREDEF(2,*),     1 TIME(2), COORDS(3)      user coding to define AK(1) -- AK(5)      RETURN      END
定义接触热导,帮助文档中子程序的格式如上,其中AK的含义如下
AK(1)
Gap conductance, k. The units of k are energy per time (flux) per area per temperature (JT–1L–2–1).
AK(2)
, derivative of the gap conductance with respect to the clearance between the bodies. If the gap conductance is not a function of gap clearance, AK(2)=0.0. This variable needs to be defined only for fully coupled temperature-displacement and coupled thermal-electrical-structural analyses.
AK(3)
, derivative of the gap conductance with respect to the pressure between the bodies. If the gap conductance is not a function of the pressure, AK(3)=0.0. This variable needs to be defined only for fully coupled temperature-displacement and coupled thermal-electrical-structural analyses.
AK(4)
, derivative of the gap conductance with respect to the temperature of point A on the first surface of the interface.
AK(5)
, derivative of the gap conductance with respect to the temperature of point B on the second surface of the interface.
AK(3)中可以给接触导热系数对压力的导数
那么问题来了,如果接触导热系数是压力的幂函数,能用这个子程序么
发表于 2016-9-27 10:06:37 | 显示全部楼层 来自 北京
你好,你也是用ABAQUS子程序GAPCON来做的吗,可以请教你一下吗?当然有偿解答,方便的话加我QQ962223585.谢谢
发表于 2019-2-26 20:09:22 | 显示全部楼层 来自 上海
请问楼上问题解决了么?同遇到该问题了
GMT+8, 2024-4-24 09:50 , Processed in 0.032293 second(s), 12 queries , Gzip On, MemCache On.
