求助,希望大家跑跑命令流,给指点一下
希望转动两根轴,带动四个轮子,轮子通过摩擦使放在上面的管转动。
可是结果不转动,并且管子飞走了(已经加重力)
谢谢
/prep7 et,1,45
ex,1,200.e9 nuxy,1,0.3 dens,1,8700. mu,1,0.2
ex,2,300e9 nuxy,2,0.3 dens,2,7850
!!===========build andmesh the pipe========== cyl4,,,0.124,0,0.136,180,0.65 cyl4,,,0.124,180,0.136,360,0.65
vglue,all numcmp,all
lsel,s,,,9,12,1 lesize,all,,,24 !along pipe length
lsel,s,,,2,4,2 lsel,a,,,13,14,1 lesize,all,,,18 ! along pipe circumference
lsel,s,,,1,3,2 lesize,all,,,1 ! along pipe thickness
mshape,0,3d mshkey,1
type,1 mat,1 r,1 real,1 vmesh,all
!!=============buildand mesh all the wheels=== cyl4,,,0.15,0,0.178,180,0.05 cyl4,,,0.15,180,0.178,360,0.05
vglue,3,4 numcmp,all
lsel,s,,,25,28,1 lesize,all,,,2 ! along length
lsel,s,,,18,20,2 lsel,a,,,29,30,1 lesize,all,,,14
lsel,s,,,22,24,2 lesize,all,,,1
type,1 mat,1 r,2 real,2 vmesh,3,4
vgen,1,3,4,,-0.2,-0.2421,0.05,,,1 vgen,2,3,4,,+0.4,-0.0000,0.0,,,0 vgen,2,3,6,,+0.0,-0.0000,0.45,,,0
!!!!!===========definesome node for pipe and wheels alls *get,nmaxtotal,node,,num,max
nd_rb=nmaxtotal+1 n,nd_rb,-0.2,-0.2421,-0.1
nd_nrb=nmaxtotal+2 n,nd_nrb,-0.2,-0.2421,0.075
nd_frb=nmaxtotal+3 n,nd_frb,-0.2,-0.2421,0.525
nd_lb=nmaxtotal+4 n,nd_lb,+0.2,-0.2421,-0.1
nd_nlb=nmaxtotal+5 n,nd_nlb,+0.2,-0.2421,0.075
nd_flb=nmaxtotal+6 n,nd_flb,+0.2,-0.2421,0.525
!** Shaft et,2,188 keyopt,2,3,3 sectype,1,BEAM,CSOLID,Shaft,0 secoffset,CENT secdata,0.05
type,2 mat,2 r,3 real,3 secnum,1 e,nd_rb,nd_nrb e,nd_nrb,nd_frb
et,3,188 keyopt,3,3,3 sectype,2,BEAM,CSOLID,Shaft,0 secoffset,CENT secdata,0.05
type,3 mat,2 r,4 real,4 secnum,2 e,nd_lb,nd_nlb e,nd_nlb,nd_flb
!** bearings radialstiffness modeling
et,4,184 keyopt,4,1,1 r,5
wpcsys, -1 , 0 NWPAVE,nd_rb CSWPLA,11,1 CSYS,11
alls nsel,s,loc,x,0.148,0.152 ! for near right bottom wheel nsel,r,loc,z,0.173,0.177 *get,nmaxnrb,node,,num,max *get,nminnrb,node,,num,min
type,4 real,5 mat,2 *do,k,nminnrb,nmaxnrb *if,nsel(k),eq,1,then e,nd_nrb,k *endif *enddo
alls nsel,s,loc,x,0.148,0.152 ! for far right bottom wheel nsel,r,loc,z,0.623,0.627 *get,nmaxfrb,node,,num,max *get,nminfrb,node,,num,min
type,4 real,5 mat,2 *do,k,nminfrb,nmaxfrb *if,nsel(k),eq,1,then e,nd_frb,k *endif *enddo
wpcsys, -1 , 0 NWPAVE,nd_lb CSWPLA,12,1 CSYS,12
alls nsel,s,loc,x,0.148,0.152 ! for near left bottom wheel nsel,r,loc,z,0.173,0.177 *get,nmaxnlb,node,,num,max *get,nminnlb,node,,num,min
type,4 real,5 mat,2 *do,k,nminnlb,nmaxnlb *if,nsel(k),eq,1,then e,nd_nlb,k *endif *enddo
alls nsel,s,loc,x,0.148,0.152 ! for far left bottom wheel nsel,r,loc,z,0.623,0.627 *get,nmaxflb,node,,num,max *get,nminflb,node,,num,min
type,4 real,5 mat,2 *do,k,nminflb,nmaxflb *if,nsel(k),eq,1,then e,nd_flb,k *endif *enddo
et,5,TARGE170!STIFFER-LOWER ORDER-COARSER-FLAT/CONCAVE-LARGER SURFACE et,6,CONTA174
allsel,all wpcsys, -1 , 0 csys,1
/com,contact paircreation-start r,5 keyopt,6,5,1 keyopt,6,9,0 keyopt,6,10,1 keyopt,6,12,1
asel,s,,,13,43,10 asel,a,,,19,49,10 cm,area_target,area ! close to origin mat,1 type,5 real,5 nsla,s,1 esln,s esurf esel,all
asel,s,,,3,9,6 cm,area_contact,area mat,1 type,6 real,5 nsla,s,1 esln,s esurf allsel
alls vsel,s,,,1,2,1 eslv,s cm,epipe,elem
!**components alls esel,s,type, ,2 ! for right bottom shaft cm,beam_r,elem esel,s,type, ,3 ! for left bottom shaft cm,beam_l,elem
!========================================== alls save fini
/sol antype,trans
/nerr,,1000000
csys,0 !acel,,-9.8 cmacel,epipe,,-9.8
pi=acos(-1) vr_rad=2.0*pi/6
cmomega,beam_r,,,vr_rad,-0.2,-0.2421,-0.1,-0.2,-0.2421,0.525 cmomega,beam_l,,,vr_rad,+0.2,-0.2421,-0.1,+0.2,-0.2421,0.525
d,nd_nrb,UX,0 d,nd_nrb,UY,0 d,nd_nrb,UZ,0 d,nd_frb,UX,0 d,nd_frb,UY,0 d,nd_frb,UZ,0
d,nd_nlb,UX,0 d,nd_nlb,UY,0 d,nd_nlb,UZ,0 d,nd_flb,UX,0 d,nd_flb,UY,0 d,nd_flb,UZ,0
alls NLGEOM,ON
autots,on
time,1 deltim,0.05,0.005,0.5
outres,basic,last allsel,all solve
