1 improperly defined surface(s). Please check your surface definitions. Make sure that all surface normals point outward.
Node-based surface ASSEMBLY_JIE-DIAN_CNS_ belongs to the rigid body with reference node 1 instance . A rigid node-based surface cannot be used in a kinematic contat pair. This node-based surface is currently paired with surface ASSEMBLY_SURF-1 in a kinematic contact definition.
Abaqus/Explicit Packager exited with an error - Please see the status file for possible error messages if the file exists.怎么解决呀!
