采用hyperview对ls-dyna进行后处理 对于shell单元的有效塑性应变 一般是看哪个layers的应变?我看选择有很多 默认是Max,什么情况下采用Min Mid 等等 请指教
帮助里面提到如下,Ls-dyna的shell 单元有layer的定义吗?
Allows you to display a contour for a specified element layer when a layer definition is available for an element. The contour will be applied to all layers defined in the model. If an element has no layer definition, as in a mass or solid, the contour is also displayed regardless of which layer is selected.
