- 2015-12-21
我做的是一个带连梁的剪力墙,结果出错Time increment required is less than the minimum specified。警告如下Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
For *tie pair (assembly__pickedsurf172-assembly__pickedsurf171), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf174-assembly__pickedsurf173), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf168-assembly__pickedsurf167), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf170-assembly__pickedsurf169), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
MPCS (EXTERNAL or INTERNAL, including those generated from rigid body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL ACTIVATE ADDITIONAL DEGREES OF FREEDOM
The plasticity/creep/connector friction algorithm did not converge at 2 points
The plasticity/creep/connector friction algorithm did not converge at 1 points
The plasticity/creep/connector friction algorithm did not converge at 3 points
The plasticity/creep/connector friction algorithm did not converge at 1 points |
