- 84
- 2003-5-22
楼主 |
发表于 2003-9-12 10:56:42
来自 日本
回复: 回复: 【推荐】一个考题,赚取分数的大好机会啊!
assassin wrote:
NO ABAQUS to use so can write input file only
don't try to run this input file, haha, it doesn't make sense
*node
*element, type=CPE4R(CPS4R)
*rigid body, Ref=A(centeral of the half circle)
*materila
*elastic
*Surface, name=name_mas
*surfface, name=Name_slave
**set rigid body as the
*contact pair, property=fric_1
Name_slave, name_master
*contact property, name=fric_1
0.5
*boundary
Ground, 1,2, 0
*step
*static
*boundary
A, 1,1,1
*cload
A, 2, -1
*output, field
*Node print
*el print
*end step
看来assassin是ABAQUS大师级的人物哎!欢迎常来指导。。。加分鼓励! |
