Slave node 699 instance qiti-1 will not be tied to the master surface assembly_m11. The distance from the master surface is greater than the position tolerance value.
Slave node 703 instance qiti-1 will not be tied to the master surface assembly_m11. The distance from the master surface is greater than the position tolerance value.
Slave node 6668 instance qiti-1 will not be tied to the master surface assembly_m11. The distance from the master surface is greater than the position tolerance value.
Slave node 6675 instance qiti-1 will not be tied to the master surface assembly_m11. The distance from the master surface is greater than the position tolerance value.
Slave node 6691 instance qiti-1 will not be tied to the master surface assembly_m11. The distance from the master surface is greater than the position tolerance value.
