- 18
- 2010-4-25
发表于 2016-4-8 14:03:27
来自 广东
As you said, one cycle is the interval of timestep, so you can define the number of cycles to decide the time point where the d3dump files should be created. The number of cycles you decide is a experiential value in general. You can size it up by the last calculation or the termination time/DT or else.
In addition, you may read the "Manual Volume I" to find the difference between D3dump and Runrsf.
By the way, you can use the sense swtich controls (ctrl+C), by which SW3 is also can be used to generate a restart file. |
