查看: 329|回复: 2
【讨论】abaqus接触的一个问题
xiaolu 该用户已被删除
发表于 2003-9-15 14:32:46 | 显示全部楼层 |阅读模式 来自 安徽合肥
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2003-9-15 16:10:47 | 显示全部楼层 来自 LAN
回复: 【讨论】abaqus接触的一个问题
改了两处,参考一下
*Heading
10000load
** Job name: blockforce Model name: Model-1
** PARTS
*Part, name=block
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=block-1, part=block
*Node
      1, -0.8, 1.
      2, -0.8, 0.
      3, -0.8, -1.
      4, 0.2, 1.
      5, 0.2, 0.
      6, 0.2, -1.
      7, 1.2, 1.
      8, 1.2, 0.
      9, 1.2, -1.
    105, 0.2, 0.
    106, 0.2, -1.
    108, 1.2, 0.
*Element, type=CPS4R
1, 2, 5, 4, 1
2, 3, 6, 5, 2
3, 5, 8, 7, 4
4, 106, 9, 108, 105
** Region: (blocksectionicked)
*Elset, elset=blockbar, internal, generate
1, 4, 1
** Section: blocksection
*Solid Section, elset=blockbar, material=steel
0.02,
*End Instance
*surface ,name=face1
block-1.2,s2
*surface ,name=face2
block-1.4,s4
*surface ,name=face3
block-1.3,s1
*surface ,name=face4
block-1.4,s3
*Nset, nset=forceload, internal, instance=block-1
7, 9
*Nset, nset=fixed, internal, instance=block-1, generate
1, 3, 1
*nset, nset=welda, internal, instance=block-1
105,106
*nset, nset=weldb, internal, instance=block-1
8
*End Assembly
*contact pair,interaction=top1, smooth=0
face1,face2
*surface interaction,name=top1
*bond
welda,1.5e14,3.9e14
*contact pair,interaction=top2, smooth=0
face3,face4
*surface interaction,name=top2
*bond
weldb,1.5e14,3.9e14
** MATERIALS
*Material, name=steel
*Elastic
2e+11, 0.3
*Step, name=Step-1
block force 10Kn
*Static
1., 1., 1e-05, 1.
** BOUNDARY CONDITIONS
** Name: fixed Type: Displacement/Rotation
*Boundary
fixed, 1, 1
fixed, 2, 2
** LOADS
** Name: blockload Type: Concentrated force
*Cload
forceload, 1, 10000.
** OUTPUT REQUESTS
*Restart, write, frequency=1
** FIELD OUTPUT: F-Output-1
**Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
**Output, history, variable=PRESELECT
*El Print, freq=999999
s
*Node Print, freq=999999
u
*End Step
xiaolu 该用户已被删除
 楼主| 发表于 2003-9-15 18:49:18 | 显示全部楼层 来自 安徽合肥
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-4-27 01:53 , Processed in 0.046842 second(s), 14 queries , Gzip On, MemCache On.
