- 2015-10-13
新手,求指点!!
%F-P2181103-P2XXTXIX_PACKET_EDTSHAPS, , ,
No names found for BOX in global edit MATBX packet.
%E-GP001403-CONVERT_TOKEN_TO_INTEGER, , ,(05),
UNABLE TO CONVERT AN INPUT FIELD INTO A INTEGER NUMBER
THE INPUT FIELD IS: ""
THE LINE ON THE NIF FILE CONTAINING THE INPUT FIELD IS:
- POINTS,20,RANGE, ,
%E-GP000401-BAD_VALUE_ON_NIF, , ,(05),
THE VARIABLE RANGE TRIPLET HAS BEEN ASSIGNED A BAD NUMBER
CALLED BY P2XXTXIX_PACKET_ALLOCS_RANGE_F
Check Data in Input File.
%C-P2108704-P2_ADD_OR_ACTIVATE_EDIT_VARS, , ,
Illegal edit set definition:
Total number of GRIDPOINTS in edit set = 1
Internal number of all GRIDPOINTS = 0
Last user number of GRIDPOINTS in edit set = 1 |
